jonomisfit
Club RR Member Number: 49
Nov 14, 2017 21:34:54 GMT
Its very very tight trying to get it in in one go. Mainly due to the transverse chassis member that goes under the gearbox.
The easiest way I've found to get in so far is split the engine and box. Hence the bolt access hatch.
Nov 15, 2017 13:23:17 GMT
cool idea...nice to have the option in case you need it. does the gearbox slide out from under okay?
nicely done...love the shaping and template work...
JP
jonomisfit
Nov 15, 2017 19:06:44 GMT
The gearbox has to go in from the engine bay.
To get the maximum internal space everything is very tight to the gearbox so there isn't space for it to be drawn back through the bulkhead.
The compromise of custom vintage cars!
jonomisfit
Nov 18, 2017 19:58:50 GMT
I continued on with the base plate Tacked it in. Well, tacks a bit more. It'll take a few visits to get it all welded in without distorting. so thought I'd start another plate to go here. so the outside edge of the throttle foot has something to stop against and not go into the gap between the door bars A plain sheet would be a bit dull though into steel and cut the holes clean up the metal and trim a bit swageyness start bending up the return goes in here like so clears the throttle and will help guide the food down i didnt weld it in as i'm ot sure if I really need it, and if I do, am i better making it bolt in. So onto some other metal work. Back to the tunnel forget to take pics for a while Bit of metal cut to shape with some lines on it goes here but needs some depth to give it some stiffness. Bead rolling time. Or rather stepping roller time. Que nervous period as its been so long since ive used it! came out ok prime it tack it in End of this weeks progress.
Nov 18, 2017 20:25:12 GMT
Good stuff.
I’ve got a spray booth exactly like that! 😂
jonomisfit
Nov 26, 2017 20:13:25 GMT
So i'm starting prep for the migration from Phuckyoubucket. They really are trying to shaft people to make it really hard to move from them! I've noticed the "Download album" button is now no longer available for your own albums! I emailed them and got an email back saying basically "tough" download one at a time. With 3000 photos this is some effort! F*ck you photobucket. I checked my photo archives and had everything other than the first 200 photos or so. I've now manually downloaded the first 900 from my phuckoffbucket account, so will begin the slow process of re-populating the thread with pictures hosted elsewhere. Flickr most likely. Anyway, less of the moaning and on with todays work. Need a cover for here PB254196 by jono_misfit, on Flickr Start a template PB254197 by jono_misfit, on Flickr cut some holes PB254198 by jono_misfit, on Flickr will fit like so PB254199 by jono_misfit, on Flickr more lines PB254200 by jono_misfit, on Flickr some steel PB254202 by jono_misfit, on Flickr with added lines PB254203 by jono_misfit, on Flickr some steel PB264204 by jono_misfit, on Flickr fits like so PB264205 by jono_misfit, on Flickr start the second half of the template PB264206 by jono_misfit, on Flickr goes here PB264207 by jono_misfit, on Flickr mid cut out, and looking like an iron cross... PB264208 by jono_misfit, on Flickr mid way through being hit with a hammer PB264209 by jono_misfit, on Flickr and tacked on PB264210 by jono_misfit, on Flickr PB264211 by jono_misfit, on Flickr and in situ PB264212 by jono_misfit, on Flickr PB264213 by jono_misfit, on Flickr] i then gave it a quick lick of paint and put it to one side onto the next bit of the pedal box, the supporting foot plate. The temporary bit is a tad heavy.... PB264214 by jono_misfit, on Flickr some steel PB264216 by jono_misfit, on Flickr initial mark and trim PB264217 by jono_misfit, on Flickr starting to put some shape to it PB264218 by jono_misfit, on Flickr fits in like so PB264219 by jono_misfit, on Flickr however it needs stiffening up a bit so think i will bead some longitudinal beads in it. Which will have to miss the floor bracing. Start marking up PB264220 by jono_misfit, on Flickr and run out of time :-) I shall continue it next weekend. There may be some attempts starting now to begin migrating the pictures over.
tristanh
Routinely bewildered
Nov 26, 2017 22:40:58 GMT
I really like your piece around the gear lever. top notch metalworking.
Nov 27, 2017 14:08:28 GMT
I really like your piece around the gear lever. top notch metalworking. ditto here...very nicely done JP
jonomisfit
Nov 27, 2017 18:16:56 GMT
Cheers.
I'm still in two minds on it.
It might look better tapering up from either end rather than just the centre.
I was a bit concerned about elbow clearance doing this though.
joeytalent
ITB Everything.
Nov 27, 2017 18:44:35 GMT
Great stuff, love this build.
Re: Photobucket - not sure how tech savvy you are, but this page has some great instructions for grabbing all your images: https://gist.github.com/philipjewell/a9e1eae2d999a2529a08c15b06deb13d
PM me if you need any help.
jonomisfit
Nov 27, 2017 21:03:48 GMT
Thanks. I shall give that a go :-) Baby_Misfit was being very cooperative tonight as went to sleep without much fuss, so i snuck out the garage for a bit. Bent the flange down PB274221 by jono_misfit, on Flickr then gave the panel a trip to the bead roller PB274222 by jono_misfit, on Flickr PB274223 by jono_misfit, on Flickr and in situ PB274224 by jono_misfit, on Flickr i then drilled off some mounting holes. PB274225 by jono_misfit, on Flickr I just need to make the short tabs to bolt it to.
jonomisfit
Nov 28, 2017 19:50:15 GMT
Great stuff, love this build. Re: Photobucket - not sure how tech savvy you are, but this page has some great instructions for grabbing all your images: https://gist.github.com/philipjewell/a9e1eae2d999a2529a08c15b06deb13d PM me if you need any help. Thanks for the link. Very helpful and very very simple to get the pics, no coding needed. Basically select all the files in the photobucket, get the HTML link, paste into a text file, open the file as a webpage, and save as offline content. Done. 3500 pics copied back to my computer :-) I "just" need to re-host and rebuild 31 pages of thread :-) Then I can say so long and phuckyoubucket.
joeytalent
ITB Everything.
Nov 28, 2017 20:12:27 GMT
Great stuff, love this build. Re: Photobucket - not sure how tech savvy you are, but this page has some great instructions for grabbing all your images: https://gist.github.com/philipjewell/a9e1eae2d999a2529a08c15b06deb13d PM me if you need any help. Thanks for the link. Very helpful and very very simple to get the pics, no coding needed. Basically select all the files in the photobucket, get the HTML link, paste into a text file, open the file as a webpage, and save as offline content. Done. 3500 pics copied back to my computer :-) I "just" need to re-host and rebuild 31 pages of thread :-) Then I can say so long and phuckyoubucket. Glad it helped! Now you have more time for the swaging and beading 🤣
CaptainSlog
Club RR Member Number: 180
Snip
Then I can say so long and phuckyoubucket. The sad thing is that so many fora are now broken, people's threads that were built up over years and so full of priceless information are now screwed, posters have moved on, died or whatever. These bastewards are responsible for so much content being lost - the whole internet should boycott them and force them out of business. ABC hosting (or whatever they are called) lost loads of stuff in a cock up of biblical proportions that completely deleted some of the fora I follow, these forums have never recovered and have gone from thousands of active members to just a few, Photophuckit's move will possibly be worse. Pity there is no watchdog to police these things - private, not for profit, users should only pay for bandwidth used at the worst, not fourfrigginghundred dollars! Rant over (for now). Sorry jonomisfit
jonomisfit
Yep, photobucket have decimated the forums of the world. Hopefully there's some smart people like Hotwire out there working out how to re-host it all and bring back the dead threads. I was looking at the footplate and thinking wouldnt it be nice to recess all the bolts PC024226 by jono_misfit, on Flickr to the lathe PC024227 by jono_misfit, on Flickr tool made PC024228 by jono_misfit, on Flickr some of the trial holes PC024229 by jono_misfit, on Flickr I tweaked it lots but it still kept drawing in the edge badly. I think it was too tight a step on too small a diameter to give the step without doing this. it works, but i have quite a large concern that it will badly distort the plate, so i decide to not recess the holes. I'll use rounded edge bolts. Mounting tabs. PC024230 by jono_misfit, on Flickr with captive nuts added PC034231 by jono_misfit, on Flickr i need some more PC034232 by jono_misfit, on Flickr tabs welded in PC034233 by jono_misfit, on Flickr plate bolted down PC034234 by jono_misfit, on Flickr gives a nice base for my feet. Should work well. where too next? Ah yes, you my friend PC034235 by jono_misfit, on Flickr CAD time PC034236 by jono_misfit, on Flickr piece of steel PC034237 by jono_misfit, on Flickr marked up PC034238 by jono_misfit, on Flickr start trimming to shape PC034239 by jono_misfit, on Flickr folded flanges PC034240 by jono_misfit, on Flickr starting to dress the rounded corners PC034241 by jono_misfit, on Flickr rounded PC034242 by jono_misfit, on Flickr trimmed the edges down PC034243 by jono_misfit, on Flickr and give the top a little bend PC034244 by jono_misfit, on Flickr I ran out of time then. Will hopefully get back onto it next weekend. I already thing though that i'll need to cut it and make it in two pieces and weld it back together. The shape is going to be awkward to do.
jonomisfit
Dec 16, 2017 18:54:29 GMT
only a short session in the workshop today. Started making a new flange PC154245 by jono_misfit, on Flickr to replace the end of this PC154246 by jono_misfit, on Flickr mainly as getting it all to work in a oner was proving impossible for me adding some shape PC154247 by jono_misfit, on Flickr the two pieces in situ. I drilled one hole on each, then used ball bearings to mark the other holes out PC164248 by jono_misfit, on Flickr tacked together PC164249 by jono_misfit, on Flickr filling the gaps PC164250 by jono_misfit, on Flickr and after a first rough pass with the grinder PC164251 by jono_misfit, on Flickr and in situ PC164252 by jono_misfit, on Flickr starting to get some of the gaps filled. PC164253 by jono_misfit, on Flickr It'll all be under carpet once done though Then i started looking at the fuel tank mounts, which need sorted properly. PC164257 by jono_misfit, on Flickr I contemplated for a bit and have worked out what i'm going to do. I just eed to do it now :-)
jonomisfit
Dec 27, 2017 21:35:07 GMT
I got out the workshop for a bit this afternoon Started making the tank upper mount Some steel cleaned up PC274258 by jono_misfit, on Flickr marked out PC274259 by jono_misfit, on Flickr some holes cut PC274260 by jono_misfit, on Flickr a few additional holes drilled PC274261 by jono_misfit, on Flickr and in one picture jump on nearly 2 hours of effort bending this up.... PC274262 by jono_misfit, on Flickr then swage the holes and re-straighten PC274263 by jono_misfit, on Flickr goes in here like so PC274264 by jono_misfit, on Flickr and the fuel tank sits against it like so PC274265 by jono_misfit, on Flickr meaning the top of the tank is nicely support, as its at an angle. I primed it but as its cold it hadnt dried for me to weld it. Start making the base for the removable cover one side PC274266 by jono_misfit, on Flickr goes in here PC274267 by jono_misfit, on Flickr and the other side PC274268 by jono_misfit, on Flickr got to make the top and bottom, then an absolutely mahoosive lift off cover and better tank straps.
Dec 28, 2017 18:39:10 GMT
great metal fabricating!
Dec 28, 2017 18:58:09 GMT
Have you made the tank yet Jon?
jonomisfit
Dec 28, 2017 19:24:49 GMT
4th last picture.
It's the fuel tank from a kit car.
Although I need to mod it a bit to make the filler work better.
