jonomisfit
Club RR Member Number: 49
May 12, 2019 20:34:27 GMT
I was looking at the bolt holes and think they need toughening up a bit. P1020334 by jono_misfit, on Flickr I was thinking of doing something like this P1020336 by jono_misfit, on Flickr but then came to my senses and decided penny washers will be more than enough. P1020337 by jono_misfit, on Flickr so that leaves one thing to do. weld it. I want to make sure its all nicely locked square before welding, so drilled and tapped the bench plate. P1020338 by jono_misfit, on Flickr drilled some 19mmk box as spacers P1020339 by jono_misfit, on Flickr welded on the penny washers and welded the back seam P1020340 by jono_misfit, on Flickr plug welds P1020341 by jono_misfit, on Flickr and not shown stitched the seam on the inside. Furk me that suddenly got very very stiff, the lower half is very difficult to flex now. back rest in P1020342 by jono_misfit, on Flickr plugged and stitched P1020343 by jono_misfit, on Flickr start on the side plates P1020344 by jono_misfit, on Flickr relieved for the bolt head, and then plug and stitched P1020345 by jono_misfit, on Flickr and the other side P1020346 by jono_misfit, on Flickr bottom of the seat now solid. P1020347 by jono_misfit, on Flickr one shoulder rest in P1020348 by jono_misfit, on Flickr I was going to set the left hand should so it'll work for the passenger side, however having tried to put it in place it's struggling to fit, mainly due to be mounted about 8" lower. will have to consider what i'll tweak for the passenger one. So welded the existing one in P1020349 by jono_misfit, on Flickr shoulder / head support welded on P1020350 by jono_misfit, on Flickr harness guides welded in on the front after flaring P1020351 by jono_misfit, on Flickr I'm pleased with the result. it is absolutely rock solid, like 0 flex. Much much stiffer than the fibreglass seats i've got. I was also impressed that it didnt warp all over the place. only question... how much does it weight? As it stands, 7kg. How much does a normal GRP race seat weight.... about 6-7kg including covers / cushions. Carbon ones more about 4.5kg. So mines not too bad. I could probably swage out a few more holes to get the weight down. A few bits to do to finish it up, mainly do the wire edging in a few places and a few more welds. Then its clean it all up.... and the nightmare of the job that will be painting it. Till next time.
sonus
May 12, 2019 20:57:37 GMT
Impressive, but is it comfy? 😉
jonomisfit
May 12, 2019 21:09:39 GMT
It doesn't look it but it's not bad.
Once it's got some neoprene mat in key places it should be pretty comfortable.
May 12, 2019 21:11:38 GMT
Will you have it painted or Powder Coated when done?
jonomisfit
May 12, 2019 21:17:49 GMT
Still undecided.
This is the prototype so probably just paint it.
Although there's a new powder coating place just opened near me, so may enquire as to the cost.
I'm thinking white so I can hydrodip it leopard print :-)
May 12, 2019 21:58:26 GMT
Oooh classy finish nice.
jonomisfit
May 19, 2019 20:13:26 GMT
The steel rod I ordered for the wire edging didnt turn up on time. I put the seat in the car to see how it fitted with it. P1020352 by jono_misfit, on Flickr not too bad, and should fit better once I wire edge the ... um.. edges. I think overall it fits in with the look of the car. P1020353 by jono_misfit, on Flickr thought i had better check it with the wheel in position to make sure the seat position was ok first. P1020354 by jono_misfit, on Flickr lines up fairly well P1020356 by jono_misfit, on Flickr took some measurements from the seat, then started having a think about how the seat mount will need to go P1020357 by jono_misfit, on Flickr which then progressed onto a full size doodle P1020358 by jono_misfit, on Flickr the seat needs to be offset over by 55mm v's the vertical plane the seat mount bolts to, the front bolt holes on the seat sit 75mm behind the centre of the chassis bolt hole, and the base of the seat is 120mm above the chassis mount bolt hole centre line. this was taking some thinking about, so doodled some more P1020359 by jono_misfit, on Flickr then started on the seat base mount P1020360 by jono_misfit, on Flickr then notched to clear some of the swaged holes P1020361 by jono_misfit, on Flickr and tigged together. P1020362 by jono_misfit, on Flickr I changed the ceramic shield to a gas focussing one, what a difference! so much easier to weld! i then clamped the seat mount jig to the bench as a basis of where the bolt holes are P1020363 by jono_misfit, on Flickr and started bending up some starts to hold it all the right height / position P1020364 by jono_misfit, on Flickr and on the other side P1020365 by jono_misfit, on Flickr you can see the offset clearer here P1020366 by jono_misfit, on Flickr Its all to help me get a visualisation for how i'm going to make this. I suspect it'll be made with sheet metal and swaged holes.
Plenty of clearance for under seat audio by the looks of things!
*guessing the floorpan and tunnel adjustments will have something to say with that though..
May 20, 2019 12:03:12 GMT
That's not a seat, it's Roboseat!
May 20, 2019 13:27:32 GMT
You own this style of fab! very cool work on the seats. as I was scrolling through the pics, I thought that you might have flex in an area or two, then your gussets addressed any concerns as the pics scrolled by. very nice!
JP
May 20, 2019 14:54:57 GMT
Is it Comfortable?
jonomisfit
May 20, 2019 17:01:56 GMT
Surprisingly so. I appreciate you only have my word for this but it is. Possibly not for 8hrs cross UK trips but general drives should be.
I do like my Swiss cheese look on things. Others are a tad more restrained in their application.
I think the car is more likely to flex than the seat.
There should be enough room under the seat for a battery or amp. Passenger seat sits lower so probably not much space under it.
jonomisfit
May 28, 2019 20:16:38 GMT
So only a very very short session as had family events on. I bought a cheap Chinese made tube bender as it was on special and looks handy. I wasnt expecting great things. I needed to make a holder for the vice P1020367 by jono_misfit, on Flickr It does 10 - 25mm tube, so thought i'd try out the range. 25mm, which I then squashed in the press to see how an end would go P1020368 by jono_misfit, on Flickr and some 10mm P1020369 by jono_misfit, on Flickr It works quite nicely. Will need to see where I can start making swoopy tube bits to go with my swaged holes. the instructions were interesting. P1020370 by jono_misfit, on Flickr on the actual morris I started making a template for the side of the seat mount, P1020371 by jono_misfit, on Flickr this was as far as I got as with a night deprived of sleep by toddler_misfit my enthusiasm for anything other than sleep had waned...
Last Edit: May 28, 2019 20:17:23 GMT by jonomisfit
jonomisfit
today did not go as i hoped. I put it down to having a cold. took the template, marked it out onto a bit of tin P1020372 by jono_misfit, on Flickr applied some holeyess to it P1020373 by jono_misfit, on Flickr folded, swaged, and adjusted... and forgot to take any pics roughly in position to try mounting the seat. P1020374 by jono_misfit, on Flickr the other side is a flat plate P1020375 by jono_misfit, on Flickr i footered about for ages trying to get it in the right position, it wasnt having it. the biggest restriction is the notch in the seat back needs to be bigger, and the edges for the legs need to be rolled over still. Better do that then. Attack the seat with the grinder P1020380 by jono_misfit, on Flickr P1020381 by jono_misfit, on Flickr cut a piece of metal to the right shape and weld in and dress back P1020382 by jono_misfit, on Flickr then start on the front edges Cut some wire and bend to shape. P1020376 by jono_misfit, on Flickr pushed into position, then tacked in a couple of spots so its fixed solid. P1020377 by jono_misfit, on Flickr then dress with the hammer, gently. gave a very surprising amount of stiffness to the edge P1020378 by jono_misfit, on Flickr and the other side P1020379 by jono_misfit, on Flickr a few extra welds added to some low points so I can dress it back. having done these bits I went back to trying to fit the seat. I was struggling with the way I was doing it. So spent about an hour musing on different approaches. Eventually I decided i'm going to have to make it from 19mm box / tube, for stiffness and ease of manufacture. But i've run out of time, so thats for the next session.
jonomisfit
Jun 21, 2019 19:35:54 GMT
right, Back onto the seat mount, i'm pretty certain there's only one way I'm going to end up with a nice mount and thats build a prototype mount thats functional, and then at a later point use that to make a jig that I can then build the seat mount to. prototype mount it is I bent up a couple of pieces of 19mm tube in the bender, flattened the ends in the press, then drilled a hole. P1020383 by jono_misfit, on Flickr then got carried away and forgot to take any pictures for a while.... put the seat in temp to try and work out the location P1020384 by jono_misfit, on Flickr tack in the front mount, then the seat mount rails to the cross rails P1020385 by jono_misfit, on Flickr the seat is now rigid, in a position that aligns you to the steering wheel and pedals axis, P1020386 by jono_misfit, on Flickr P1020387 by jono_misfit, on Flickr it can only go fwd though on the mounts not back any further. If anyone is taller than me (5ft 10) they'll struggle to fit. P1020388 by jono_misfit, on Flickr and this is the not particularly pretty looking mount. I feel bad showing it P1020389 by jono_misfit, on Flickr P1020390 by jono_misfit, on Flickr rounded off the tube ends P1020391 by jono_misfit, on Flickr and start making some gussets to tidy it up P1020392 by jono_misfit, on Flickr Once i've got the prototype made I may take some measures and mock something up in CAD to try and get a better design.
jonomisfit
Right, on with trying to make this less ugly. mark out a template, make it more awkward by starting in one place with one colour pen, then changing place and pen colour.. P1020393 by jono_misfit, on Flickr turn into a template P1020394 by jono_misfit, on Flickr turn into steel P1020395 by jono_misfit, on Flickr roughly in position P1020396 by jono_misfit, on Flickr weld on P1020397 by jono_misfit, on Flickr then neaten up this bit. card P1020398 by jono_misfit, on Flickr steel P1020399 by jono_misfit, on Flickr swaged and welded steel P1020400 by jono_misfit, on Flickr bolted in P1020401 by jono_misfit, on Flickr bit of clearance here for a bit more space in an side hit P1020402 by jono_misfit, on Flickr not so much here P1020403 by jono_misfit, on Flickr it is absolutely rock solid when bolted down, and the seat is super stiff. in terms of where you sit P1020405 by jono_misfit, on Flickr Whilst its not a normal sitting position, its not that uncomfortable P1020406 by jono_misfit, on Flickr Looking at it, passenger seat will sit down here somewhere P1020407 by jono_misfit, on Flickr But that can wait for a bit, as I fancy a change of projects for a while.
How's your vision? Are you going to see that side hit coming with your pillar in the way?
Very similar postion to mine - I'm a little further back.
You might need to angle your seat back a bit as you need more thigh support to avoid a numb bum when driving.
jonomisfit
Visibility is surprisingly ok...ish, but I suspect parking will be fraught with concern as you have no idea where the exact front is.
Thanks. I can see there being a lit of tweaks to seating position once the thing is mobile.
jonomisfit
Mrs_misfit wanted peace in the summer palace so I tidied the workshop a bit, contemplated for a while, then decided to make a start on seat no.2 as it was quiet work. start with the template P1020418 by jono_misfit, on Flickr mark some lines P1020420 by jono_misfit, on Flickr mark some more lines P1020421 by jono_misfit, on Flickr and some more P1020422 by jono_misfit, on Flickr and some more P1020423 by jono_misfit, on Flickr some slight changes to the seat v's the drivers one, to sort it being lower, to give some extra space for a wider range of passengers (about 35mm wider on the base), and to clear some other obstacles the other seat didnt have to. Will see how it goes.
