Sept 23, 2012 18:24:50 GMT
Last Edit: Sept 23, 2012 18:26:42 GMT by Crallen
Sept 23, 2012 18:48:50 GMT
Awesome build Them white Wellers will suit it down to the ground.
Sept 23, 2012 18:50:11 GMT
what a great build thread. looking forward to seeing more from this
Sept 23, 2012 19:02:17 GMT
yea the white ones are awesome but they are tiny! 13 x 8 so really small in the arches and stick out a mile! The back ones are my preferred choice but I need to redrill the PCD fist...Apparently I don't like to do things the easy way.....
Sept 23, 2012 20:49:46 GMT
Your front suspension is exactly the same set up as the Vivas. Interesting to see as I want to fit coilovers to that. Bookmarked
Project Diary1975 Viva / 1988 T25 Camper / 1989 Mini / 1991 MX5 / 1992 Mini / 1994 Saab 9000 / 1997 Saab 9000 / 2008 Saab 9-5
Sept 23, 2012 20:50:04 GMT
Lovely car and stance mate, tbh love all the sets of wheels lol
Sept 24, 2012 11:57:53 GMT
Cheers for the replys guys, hopefully the stance will be spot on with the coilovers and new wheels. The wheelarches are pretty big so the 15" steels should fill it better than the 13s and i can adjust the rideheight to be spot on with the coilovers!
Doea anyone know the best way to repair the sills? I thought a cut out the rusty bits and drill out the spotwelds along the lower joint and weld in a repair panel?
Sept 24, 2012 19:13:19 GMT
i like this lots...old fords and rust, my sierra likes rot too. if you are wanting to avoid replacing the sills you are right in what you say, drill out the spot welds and try and pull the inner outer and intermedite sill apart and then chop and weld a new bit in. I'm in the process of doing just that on my sierra I'm in Norwich if you wanted to see the mess it makes
mk2cossie
Club RR Member Number: 77
Sept 24, 2012 21:13:29 GMT
very nice looking and cool sounding motor ;D should be a nice grunty 180bhp when the megasquirt gets mapped i'm running Gaz coilovers on the front of my granada (pretty much the same setup, but longer arms ), and currently have the lower mounts on some angle iron and bolted to the original damper mounts. been ok so far, but waay to soft on the springs at the mo what size coilovers are they, and what kind of spring rate are you looking to use?
Sept 24, 2012 21:18:49 GMT
Haha, yea rust is a curse word! Not living in norfolk anymore but my rents still live up there. So more happened tonight, I borrowed a lathe and parted off some some tube to be welded into the wishbone, ill let the pics do the talking.... Tubes aligned in position Tacked And welded And finally shock test fitted.. More when I do it!
Sept 24, 2012 22:27:25 GMT
the tubes want supporting at the shocker end, as the leverage is going to crack around those welds.
theres more to life than mpg & to much power is just enough.
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
Sept 24, 2012 22:53:59 GMT
looks good , but as said above it needs a bit more strength on the bottom arm ,
id weld a thickish washer each side to be safe,.
facebook: rodney dean / rd transport
Sept 25, 2012 7:20:21 GMT
Yea the ends of the tube are going to be supported by a brace which is welded to the lower part of the wishbone so when its done I don't think its going anywhere!
Sept 25, 2012 16:15:20 GMT
single sheer its called when only supported at one end, although not quite the same as the bolt goes through both sections.
might also find it will need little spreader plates round the tubing outter ends.
its gonna be awesome though, double wishbones and spring/damper acting on the same points. cant really get much better on a road car.
Last Edit: Sept 25, 2012 16:15:39 GMT by darrenh
Oct 11, 2012 19:18:12 GMT
Wooo...so heres an update! Got the coilovers finished, reinforced the mounts and fitted them with some uprated springs (30% more than the 30% prated ones I had already as it still handled like a boat! Cranked the shocks up to max and very happy with the result! The final ride height isnt set yet but Ill do that when I get the new wheels sorted (Being drilled at the moment, cant wait!) So with that done its time to move to the rear..... Had the rear damper off and springs out (forgot photos here...) and started checking the mounts and making some measurements...looking at the top damper mounts I don't know if they are going to be strong enough on their own, even seam welded to the body (separate thread in Technical!) Wanting time to ponder I decided to take on the wheel arch rust...started a little bit better than this but I got carried away before taking pics: Some sparks later.. It got worse though... Saw a little patch on the end of the sill...it turned to a hole.. Which then found its way to the rear jacking point as well: RUBBISH....I've never really done body work and not that keen on it so debating weather to just pay someone to fix the rusty bits! While I was packing the car to go home I caught a glimpse of the cortina through the half closed door, with the dark outside and light in the workshop I couldn't resist..... More later!
slot
Oct 11, 2012 20:41:13 GMT
Nice work on the coillies bud What sort of money are we talking from Gaz for the whole front set up ? If yeh don't mind me asking of course Dave
Oct 11, 2012 22:01:15 GMT
No probs Dave, the shocks are £50 each plus vat and the springs are about £15 plus vat so the lot cost £180 (postage and stuff too) from rally design. The reason I went to the bother (and expense!) was now I can adjust the ride height very easily and also different springs are cheap with a massive range rather than just floppy or slightly less floppy!
This looks awesome! hadn't realised the coilover units were that cheap from Gaz either, might have to have a look see for the sierra methinks at some stage... Keep up the awesome work!
slot
Oct 12, 2012 10:43:20 GMT
Cheers Chris, this is gona help me no end, when I get round to doing mine on the ever expanding list Keep it going
Oct 12, 2012 13:48:20 GMT
Cheers for the comments guys, keeps the motivation up when you keep putting a screwdriver through the body! The coilovers are cheap cos they are the universal kind, think car specific ones are probably a bit more expensive bit havent looked into it myself!
