mr
my car has a drain plug too.........................just haven't found out where it drains from yet to tighten it back up as it would appear to be loose. bummer bout the diff,can the CROWNwheel and pinion be bought from motomobil and swapped or would it be too much money and agro?
Got the car from 105 bhp at the crank to 152 at the wheels.nitrous going on next.....if it ain't broke,keep bolting on go faster parts until it is........ www.fordgranadaclubuk.freefo.de![](http://i986.photobucket.com/albums/ae345/granadaclubuk/NEWSUG.jpg)
Phil H
Club RR Member Number: 133
CWP swaps involve a lot of measuring and adjusting from what I've read in an article called "the magic and witchcraftery involved in building a quiet differential".
mr - you appear to have the optional extra self-rustproofing liquid dispensing system (TM) rather than the cheaper drain plug version?
mr
that's the one,i believe it was standard on all 80's fords . when the engine was swapped my mate rob must have been near the dispenser nozzle cos when he climbed out the engine bay , he looked like a seagull on a beach after an oil spill.
mk2cossie
Club RR Member Number: 77
May 22, 2016 13:15:51 GMT
Friday evening after gettting home from work was the start of the strip down of the rear end of the ole bus for the bodywork to get some attention. So the boot was stripped out and the rear seats along with the parcel shelf and C pillar trims for good measure Started off like this ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160520_192406_zpsv3v1hfjg.jpg) And ended up like this (not sure how noticeable a difference in height it really is!) ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160520_192406_zpsfhqmttyw.jpg) Got to my friends workshop after work yesterday and removed the rear bumper end caps, think one has seen better days though ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160521_145808_zpsvatfcgg4.jpg) and inside of it ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160521_152636_zpsjonxehog.jpg) The rear screen still needs to come out to cut out and cure this ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160521_131314_zpss0e2qk7n.jpg) ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160521_131319_zpsgitt4vdg.jpg) And a bit more in here again ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160521_131328_zps5wu5q33n.jpg) And the main thing being both the ear wheel arches at last nearside rear ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160521_131257_zpsqnrckabr.jpg) offside rear ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160521_131257_zpsqnrckabr.jpg) And how the bus was left at the end of the day before the major surgery ![](http://i1214.photobucket.com/albums/cc488/mk2cossie/24v%20granada/20160521_152623_zpszzzkyk6f.jpg)
mr
May 22, 2016 13:34:32 GMT
When the rear screen is out you'll probably find that the metal the screen rubber sits on is rotted away too.....suprised bout the wheel well,thought that was only made a couple of years back.I've got a drain hole in mine just in case of leaks.never had a water issue in the boot luckily,is the boot rubber seal damaged or have the sunroof drain channels rotted right through into the boot area under the rear screen.
mk2cossie
May 22, 2016 13:54:19 GMT
When the rear screen is out you'll probably find that the metal the screen rubber sits on is rotted away too.....suprised bout the wheel well,thought that was only made a couple of years back.I've got a drain hole in mine just in case of leaks.never had a water issue in the boot luckily,is the boot rubber seal damaged or have the sunroof drain channels rotted right through into the boot area under the rear screen. thats why the screen is coming out to get the bits on the rear scuttle cut out and repaired mr ![:D](//storage.proboards.com/forum/images/smiley/grin.png) I know full well its rotten out under the rear screen and letting water in. Has swollen the MDF parcel shelf as well as rotting out the spare well agian. Although the well is just the inner upright as the bottom and outer section was made from thicker metal than Ford used originally and is probably good enough to jack the back up on ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png)
May 22, 2016 16:01:40 GMT
I actually really like the way that looks without the bumper extensions wrapping around the sides. It accentuates the body lines of the car and cleans it up nicely.
JP
mk2cossie
May 23, 2016 12:44:40 GMT
I actually really like the way that looks without the bumper extensions wrapping around the sides. It accentuates the body lines of the car and cleans it up nicely. JP I know what you mean there. Always thought the mk2 looks better at the rear without the massive bumper ends ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Something about it that makes it look a bit more banger racer ready ![:-X](//storage.proboards.com/forum/images/smiley/lipssealed.png)
mr
ages ago wen fitting new wings on my car ,instead of drilling holes in them as is required for facelift models, I toyed with trying some satin black mk2 escort quarter front bumpers on. and the rear end fitted with prefacelift Granada ones.
mk2cossie
The olde bus has been worked on this week, and the rear screen is also out as well ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Shall try and upload some links here tomorrow lunchtime of the progress and how bad some parts are ![:-X](//storage.proboards.com/forum/images/smiley/lipssealed.png)
Last Edit: Jun 1, 2016 21:17:00 GMT by mk2cossie
mk2cossie
mr
nice progress
mk2cossie
hamps
www.medwayrscentre.co.uk
Nice work ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Safe to say you found the leak alright ![8-|](//storage.proboards.com/forum/images/smiley/nerd.png)
mk2cossie
Jun 15, 2016 12:35:53 GMT
No pics on this update I'm afraid to report ![:(](//storage.proboards.com/forum/images/smiley/sad.png) Should be some by the end of the week hopefully. Was at my friends workshop last night whilst he was doing some overtime on a time attack car, and I set to the nearside rear wheel arch well and spare wheel well with the angle grinder with a massive wire wheel attachment ![:-X](//storage.proboards.com/forum/images/smiley/lipssealed.png) Safe to say that now both wheel wells are more or less devoid of 32 year old seam sealant and grubbiness ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Was also shown the new panels for the side portion of the spare wheel well and the new stainless rod that the towing eye will be made from ![8-)](//storage.proboards.com/forum/images/smiley/cool.png)
mk2cossie
Jun 22, 2016 22:53:56 GMT
Was over at my friends workshop tonight, and he has been busy working on a 4.0l Wrangler with a turbo attached to it trying to get it to run properly ![:-X](//storage.proboards.com/forum/images/smiley/lipssealed.png) I can confirm that it sounded pretty awesome ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) Oh, and the spare wheel well is complete with massive towing eye and the nearside rear wheel arch is on mine ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
mk2cossie
Jun 27, 2016 19:49:24 GMT
hamps
Jun 28, 2016 19:26:08 GMT
Looking good ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
mk2cossie
Jun 29, 2016 17:12:27 GMT
Looking good ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Thank you hamps ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Would love to have learnt to weld earlier on in life and be at least half as good as Dave is! Would save a pretty penny on repairs that way as well ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png)
