mk2cossie
Club RR Member Number: 77
Nov 26, 2023 10:33:16 GMT
Yesterday at work, all on my lonesome. So decided to have a go at welding up a few bits that needed attention myself There was a bit of the offside inner sill that had a pin hole, so I filled that in, and put a few tacks on the overlapping panels on the inner sill (no pics of that, so you'll all have to use your imaginations) Tapped a repair panel gap up close on the inner wing, and joined that up And tried to fill in the gap just behind the headlight, and promptly gave up I did manage to open up the holes in the front valance to better match the brake ducts, and filled in the now surplus to requirements holes
mk2cossie
spot
Jan 12, 2024 11:28:29 GMT
Always satisfying to be sticking fresh metal back in the the places where fresh-air and rusty bits once lurked.
mk2cossie
Jan 30, 2024 19:19:10 GMT
teaboy
Make tea, not war.
Jan 30, 2024 20:56:44 GMT
That's looking super.
I really don't like doing the wiggly dance when a hot spark goes through the trousers, it isn't much fun.
mr
Fair play, that's serious effort going in there. Guess I now know a welder😎.... Keep your phone handy, I'm taking some time out for the rat rod soon lol
Got the car from 105 bhp at the crank to 152 at the wheels.nitrous going on next.....if it ain't broke,keep bolting on go faster parts until it is........ www.fordgranadaclubuk.freefo.de
mk2cossie
Fair play, that's serious effort going in there. Guess I now know a welder😎.... Keep your phone handy, I'm taking some time out for the rat rod soon lol Don't confuse any of the above with me knowing how to weld I've only shown the good bits, and none of the misery of blowing through tissue paper thin stuff. Nor any of the massive frustration caused by my lack of patience and not letting the metal cool down Although I did get huge satisfaction making the holes and swaging them in the panel that will never be seen again
mk2cossie
That's looking super. I really don't like doing the wiggly dance when a hot spark goes through the trousers, it isn't much fun. I decided against standing up and doing the dance, as I knew the spatter would've travelled down in to my boot. And there's no way I can get out of them quickly
vitesseefi
South West
I use the elastic sided boots these days ‘cause I can get out of them quick. 🙂
That’s a big job / keep up the good work.
kh97
Nice work, i'm currently busy with exact the same spot on my granada
mk2cossie
Nice work, i'm currently busy with exact the same spot on my granada I did see your build thread the other day. Thats quite a lot of rust hidden on yours with previous repairs Also didn't realise how similar the inner wing area is between mk1 and mk2 Granada
kh97
I thought the body of a mk2 was mainly the same as a mk1, only the rear quarters, front and rear valance and hood hinges differ.
mk2cossie
Where are my manners? Its been 4 days since Saturday, and I didn't update my build thread on Sunday After fretting about the apparent lack of gas in the welder, my welding friends suggested I just got on with it, as the flow gauge was still pointing in the right direction! So I drilled all the holes in the sill upright for plug welding that in place, and did a bit of preemptive prep work to make the welding go better. Drilled all the holes to 5mm to start with, only to discover that was difficult to plug weld and get the upright to remain stuck to the inner sill. So the 2mm to 2mm side of the upright had the holes taken out 7.5mm, and that seemed to work very well... Had a slight issue with one of the lower ones midway being a git to hold, but got there with a bit of patience. And before end of day on Saturday, flap disced all those welds back ready for the outer sill panel, and gave them a quick weld thru primer as well
Last Edit: Feb 7, 2024 22:56:26 GMT by mk2cossie
mk2cossie
Feb 11, 2024 21:20:33 GMT
Only a small update from me this week. Helping out others at work instead of just getting on with my own thing. Managed to get the sill upright fully plug welded in, flap disced back, and just given a squirt of weld through primer
mk2cossie
Feb 18, 2024 23:40:29 GMT
mk2cossie
Feb 28, 2024 18:21:00 GMT
mk2cossie
Feb 29, 2024 17:29:35 GMT
What day are we on now? Thursday, and the second day in a row of faff. Too many dead ramps at work with jobs waiting for parts, so I was chucked off the 4 poster. Managed to get the doors on Tuesday before being moved, and now know I need to give the outer sill panel an almighty tweak with a lump of wood and a BFH, as it heads upwards at the middle section around the bottom of the B post (I'm really not impressed with the quality of the outer sill panel, especially for how much it cost!) Although I did fit my coolant header tank bracket in place And today was spent fitting up some bits to the drivers door whilst I was floor bound 🙃 not taken any photos of todays shenanigans tho. You'll just have to wait til tomorrow for those
teaboy
Make tea, not war.
Feb 29, 2024 20:47:30 GMT
It's all good progress, mate.
Block of wood and BFH are pretty much routine when fitting panels.
I had to use that technique when fitting a very expensive genuine Porsche sill to my 911.
It will be worth the effort when it is done.
mk2cossie
kh97
Great work! Can't keep up with your progress.
I'm still working on the same section aswell. I did also spend too much time with trying to get my sill aligned with the doors. My reproduction sill was also a bit curbed which resulted in oneven panel gaps with the door bottoms.
Did you have to remake the dogleg panels or could you just reweld them on?
