mk2cossie
Club RR Member Number: 77
May 30, 2013 18:14:44 GMT
I'm running 205/55r16 tyres on my rims, as they are the same rolling radius as the old balloon tyres on the 14inch rims it came with Mr on here runs 205/50r16 on his without hassle though. but the 205/55 is more plentiful and cheaper than the 205/50 I've found And the Granadas don't look right without a decent amount of sidewall in my opinion
mk2cossie
Jun 12, 2013 23:53:15 GMT
Well, the MOT and tax were due at the beginning of the month. So, just get it tested and I can get it taxed I thought Except it failed on a front ball joint and these bueaties Thats the end of the nearside inner sill, and these 2 are either side of the diff mounting Ball joint was easy enough, just waiting to get it welded up on the bits above at the mo
mk2cossie
Jul 15, 2013 21:51:46 GMT
It's all taxed and tested now, didn't get any pics of the finished bits of MOT welding, but I did get some of the new spare wheel well And I've even been getting up to 23mpg with the warmer weather lately A little while ago (with the standard ecu and wiring from the mk3 Granada) i went to Track and Road for a power run. Other than the comments about it not being a manual from the operators, they are a nice bunch of guys there. Shall be going back to get the Emerald ecu properly setup and hopefully have an improvement from the 1st dyno printout
mk2cossie
Sept 22, 2013 14:19:20 GMT
well, a fortnight ago I decided to change the CV joints on the drivers side driveshaft. All went well, new parts sourced and the clicking noise reduced a considerable amount (passsenger side still to do) Until the next morning on my journey to work, when pulling out of a junction (too enthusiastically) the outer CV joint decided to let go with an almighty bang and lose drive Replacement CV joint was sourced in a last minute hurry and seems to be working fine so far. Must've just had an iffy joint
Last Edit: Sept 22, 2013 14:19:54 GMT by mk2cossie
mk2cossie
Jan 15, 2014 22:05:51 GMT
Driveshaft CV joints holding up well on the offside Ought to get round to doing the 2 on the nearside shaft I guess, and find out which wheel bearing is grumbling Any one on here have any good suggestions for rust prevention for the underside? Got an oily type of bodyshultz (I think) at work, that the old boy I work with seems to love. But think it best to ask for any ones experience on here before applying that
Good output for a "1900cc" though!
mk2cossie
Jan 16, 2014 13:42:09 GMT
Haha, I hadn't noticed that on the dyno printout It is meant to be 2995, so I guess that was a hastie wrong button press when logging it on
mk2cossie
After a few hiccups with an intermittent washer fault (to the point of working fine whenever I went to check what the problem was), I decided to just get a replacement pump. On removing the old one, I was suprised to find that both terminals had corroded off New pump fitted and all ok there. Wonder if the new un will last 30 odd years like the last Also, the autobox is suspended on a Vibratechnics mount for a T5 Sierra box. After the 2nd set of rubber inserts died from that, I found out that my useful and ever resourceful friend had some nylon sprod, and a lathe Some cursing a choice words later about nylon being a tad awkward to machine down, the rear mount is now suspended beautifully. A tad more noise transmitted in to the cabin area, but thats only more noticeable when the box is in 1st. Don't appear to have any pictures of the old rubber or the new nylon mounts to upload it seems
Interesting you had it run up at Track and Road. I enquired with them about mapping my project when its done ( automatic and turbo and Emerald ECU ) and they were less than keen saying under load in the higher gears it would just kick down not allowing them to map it correctly Did they express the same to you
Track n Road had my astra mapped there, steves are legends
mk2cossie
Interesting you had it run up at Track and Road. I enquired with them about mapping my project when its done ( automatic and turbo and Emerald ECU ) and they were less than keen saying under load in the higher gears it would just kick down not allowing them to map it correctly Did they express the same to you They weren't that impressed at 1st, and it did kickdown when loaded up in 3rd gear at low rpm But, I'm currently not running a kickdown cable or the original kickdown solenoid. The Emerald currently has 4th gear inhibit below 45degrees coolant temp, and the torque convertor lockup is mapped to throttle position and rpm. So I can drive it normally and get it in 4th with lockup as low as 1500rpm and give it full throttle without it kicking down at all Which should prove very handy for the two Steve's with the mapping when I return to Track n Road with the modified inlet manifold Most autos as standard won't allow just a single gear run though, which is what the mapper is after so they have a consistent speed window for mapping the various load sites at varying rpm. Which from what I've heard, the two Steve's are very good at. If you know that you can get your box to stay in gear at different loads and rpm regardless of throttle position they should be able to do a pretty good job though
mk2cossie
Feb 10, 2014 22:42:35 GMT
Finally got an update with the spare inlet manifold I got over a year ago. Apparently the insides are a restriction, so I've tapped the end plates off and I'm getting some new ends made up with more volume that bolt on Both the sides are roof shaped, so machined flat is the 1st step
mk2cossie
Feb 28, 2014 13:33:04 GMT
Well, the inlet mods haven't progressed lately, so I thought I ought to replace the nearside driveshaft joints as I had them sitting around for a few months now And also check and replace the nearside rear wheel bearing as there has been a terrible whining from the back lately So, whipped off the driveshaft and could spin the rear wheel up to listen to the rumble from the bearing, righto get that changed then! 2.5 hours later and the swine of a thing was out a changed Think its safe to say that it was past its best And the CV joints that I took apart a couple of years ago to clean up and regrease were quite slack and tired looking too And after all that, whilst doing the driveshafts back up, I discovered that the offside rear wheel bearing is also noisy So that's another bearing to look forward to changing
mk2cossie
Apr 22, 2014 12:17:19 GMT
Well, both rear wheel bearings replaced after getting a new one for the offside from Kent Bearings as no-one else could supply one for me (and I don't like Ebay for el cheapo parts as a general rule!) Can't recommend them highly enough with their service, as it was bloody marvellous All going well up until last Wednesday, when I asked my friend to switch on the ignition on over run in the ecu settings. And that corrupted the map somehow An enquiry to Emerald suggests the lead may have been the cause, and to try a different lead. Luckily said friend has a brand new bagged lead at his work to try, but with no luck either. So the ecu is out at the mo to be sent away
mk2cossie
Apr 30, 2014 23:36:58 GMT
A call to Emerald and they reassured me it wouldn't be the ecu, and to try another laptop with the software on to try and upload the map again. A quick uninstall and install of the software on my mates laptop, plugged in and as if by magic the bally thing worked and fired up the ole girl again No pics of progress of late though, so have a pic from an icy morning a few weeks ago
Cripes, this car is just darn superb!
***GARAGE CURRENTLY EMPTY***
mk2cossie
Aug 26, 2014 12:39:42 GMT
Cripes, this car is just darn superb! Thank you grifterkid No real progress to report of late though. MoT was sorted a few months ago, with a new lower ball joint, track rod end, sorting out a broken coilover spring and an iffy fog light switch Got a spare front subframe to modify for some proper size coilovers instead of the current 1.9inch gaz ones that have survived for over 5 years now. And my modified inlet manifold is nearing completion also, so pics of that when its arrived
mk2cossie
Sept 3, 2014 19:49:39 GMT
Well, finally got round to starting the front subframe tinkering tonight. need to source some new tie rod arm washers or get some made up by my friend with a lathe as the original ones are almost rotted through But I started out with this (already cut as I haven't got any pics of it as it was made ) As the 2.25inch coilover springs don't actually miss the standard spring top cups, they came out And a bit of CAD for adding a touch of strength back in And a bit of fine tweakage to get the 3mm cutouts lined up and ready for welding in
Last Edit: Sept 3, 2014 19:52:22 GMT by mk2cossie
Sept 3, 2014 20:56:20 GMT
Read through the whole thing so far. What's a granny like round Brands? I've never seen it in that light?
Twitter @w0rd5w0rth
1957 Ford Prefect 1965 Austin 1100 4 door 1968 Fiat 500L 1969 Ford Escort Super 1971 Vauxhall Viscount 1974 MGB GT 1978 Vauxhall Cavalier GL 1981 Ford Capri GL 1982 Ford Cortina Crusader 1985 Vauxhall Cavalier L 1987 Austin Maestro City 500 1987 Ford Fiesta 1.1L 1988 Volvo 240GL 1989 Ford Sierra Cosworth 1991 Fiat 126 BIS 1993 BMW 740i 1997 BMW M3 Evo 1998 Ford Transit Beavertail 2002 MINI Cooper S
mk2cossie
Sept 3, 2014 21:04:54 GMT
Apart from the current coilovers being to soft, it's actually quite good Managed to post times a few seconds slower than my friends turbo'd Corsa C sri, so I'm quite happy about that Not sure how to resize the pics, as I think they look a tad too big in my posts, but what do you lot think? It's a tad over the place as I don't often get the chance to work on it to get a major job just done and finished :/
