mk2cossie
Club RR Member Number: 77
Jan 10, 2021 16:08:00 GMT
mk2cossie
Jan 10, 2021 16:10:43 GMT
And the front coilver springs for comparison (Although I didnt take any pics of the work as its a bit of faff and was flowing well with coming apart and going back together)
mk2cossie
Yesterday I finally got around to getting my calipers painted up! Still need to sort the leaky door seals and send the alternator off for rebuild tho So starting at about 9:30 yesterday morning, I managed to remove 3 of the 4 calipers, and both rear caliper carriers. One front caliper had 2 sticky pistons in it, so that was the first challenge of the day. And both front brake pipes were siezed in to the unions and consequently sheared off! And the nearside rear handbrake caliper had been giving me grief so decided to sort that too. Got that off and on the bench to clean up and strip down, which went surprisingly well. Think I discovered the issue as well! So all cleaned up and "just" rebuild it The internal circlips literally just came out with a pick, getting it all back together again by myself was a different challenge. As the main body has a spring that needs to be compressed to get the circlip back in! After several unsuccessful attempts with circlips pliers, I devised a devious plan! As you may be able to work out, there isn't a lot of room to operate in there! But the valve spring compressor tool worked a treat So today is brake pipe making and painting the last caliper . And a teaser of one caliper back on with its new pipe support bracket (and I know there's no transfer pipe fitted)
Looking good! And smart work with the valve spring compressor. Will keep that in mind if I come across a similar problem...
mk2cossie
Jan 25, 2021 13:26:52 GMT
So back to the workshop Sunday to get the blimmin thing finished off! Replaced the front flexible hoses when I found them (safely stored in a jiffy bag in the car!), finish off the caliper painting and make the replacement brake pipes. Offside front caliper with new link pipe fitted Also drilled and tapped the upper wishbones each side to accept a P clip to run the flexible lines through and keep them out of the way of the tyres on full lock And whilst the last caliper was drying, I refitted all the pads, and refitted the nearside rear caliper that had given me all the grief on Saturday! The brakes were a bit of a fox picture to bleed out when all was assembled, but got there eventually. And had a very good brake pedal and functioning handbrake and no fluid leaks either! So all good there And an bit of an arty pic as well
mk2cossie
Feb 25, 2021 17:48:16 GMT
Not a proper update, as nothing to report really. However, managed to sneak Monday lunchtime working on my own car for a change Had a suspicion that the rear anti rollbar (or sway bar for other countries) was the wrong way round After undoing the droplinks, and hoiking the ARB from its brackets, it would appear that it only fits one way up and the little curve in one section must be to miss the fuel system on factory injection models And at around the same time as I got my car in the workshop, these strange marks appeared on the floor! No idea how that occurred
mk2cossie
Mar 14, 2021 14:21:57 GMT
Another week, another pain in the curse word day at work! Yesterday was spent rewiring the power steering pump so that the relay for it isnt next to the pump, and instead up in the add on fuse and relay box. So I started out with it looking like this And too many hours later, it looks like this Still need to sort out the drivers door skin, and speaker component placements so they match the passenger door. And sort out the leaky door rubbers, the leaky steering rack, transmission leak from the speedo cable, and the newest discovery of the coolant leak at the rear of the left hand cylinder head Oh, and replace the main alternator cable, as there appears to be many amps missing between alternator post and distribution block on the inner wing
Sounds like fun and games leak chasing...
Wiring looks much neater! Is that PS pump standard fitment or from a different car?
gess
Mar 15, 2021 10:53:13 GMT
Always a lot to do on old cars, you fix one problem and another one pops up. These rear brakes you have, what car is it from, Scorpio, Audi, Mercedes? Is it easy to get approval for homemade brackets to mount calipers on? I don't think I would get away with it here in Norway. The PAS pump, is it a good location in front of the wheel, what if it spring a leak and pour oil all over your wheel. That could potensially get messy.
mk2cossie
Mar 15, 2021 12:18:20 GMT
Always a lot to do on old cars, you fix one problem and another one pops up. These rear brakes you have, what car is it from, Scorpio, Audi, Mercedes? Is it easy to get approval for homemade brackets to mount calipers on? I don't think I would get away with it here in Norway. The PAS pump, is it a good location in front of the wheel, what if it spring a leak and pour oil all over your wheel. That could potensially get messy. The rear brakes (handbrake cable, discs, pads, caliper, and caliper carrier) are all mk3 Granada/mk1 Scorpio. The brackets between wheel bearing carrier and caliper bracket are made of Dural ages ago from a sheet of 10mm I got from the UK Kit car show many years ago. The power steering pump is from a Saxo/106, with the main pressure line made up by Pirtek. All been through many MOT tests no worries, but we don't have TUV style testing standards in the UK
mk2cossie
Mar 15, 2021 12:45:29 GMT
Sounds like fun and games leak chasing... Wiring looks much neater! Is that PS pump standard fitment or from a different car? Thank you very much The pump is standard fitment on Saxo/106 with PAS, at the time of engine install it seemed easier and tidier for the engine bay to have the pump mounted out the way of the possibly hitter engine bay Probably would've been easier to have retained the standard bracket with alternator and PAS pump on one belt, but then hindsight is a wonderous thing
Mar 15, 2021 12:55:39 GMT
Ah I thought it looked familiar. I've got the same one fitted to the XJ40 TD. In that case it's because the BMW PS pump puts out way too much pressure for the Jag rack so you'd either end up with super-light steering or blown seals. There's possibly a way of modifying the pressure the BMW pump puts out (old pumps have a relief valve spring you can shim to different preloads), but likewise it seemed easier for packaging as well.
Is yours mounted in the wheel well? I've found a place to mount mine but I'm not particularly happy with it as I think it might cause noise issues in the cabin (it's mounted above the passenger's footwell). Is it a particularly noisy pump in use?
mk2cossie
Mar 15, 2021 17:21:48 GMT
Is yours mounted in the wheel well? I've found a place to mount mine but I'm not particularly happy with it as I think it might cause noise issues in the cabin (it's mounted above the passenger's footwell). Is it a particularly noisy pump in use? It is in front of the nearside front wheel, it was noisy. But since sorting the wiring it has become almost silent! And it will whine a bit when the fluid is low The mount is mostly welded to the inner wing/subframe mount area, with the stainless steel bracket triangulating it. And it uses the original PSA pump mounting bracket with rubber inserts and has never vibrated though the car in use (only aurally hear the pump, even when it was at its loudest) The main issue i have is the steering rack wasn't rebuild properly, and now fills the bellows with fluid if full lock is used! So thats high on the priority list to sort really, and theres no core units to exchange with.
eurogranada
Good luck on the rack mate! My worst nightmare and single most expensive issue bar the repaint.
In the end I ended up putting in a different rack as three rebuilds had not fixed my original mk1 rack.
I do presume you to have a more servicable item than that particular mk1 rack, but still... Hope you get it sorted easily enough!
mr
Mar 16, 2021 12:53:14 GMT
someones been busy,makes me want to get back on my garage dweller...... have you asked vic regarding the rack. he knows pretty much everyone with a granada. or you could try the bathside garage. they sorted me out with pas pipework when i needed some. they have entire cars.
Got the car from 105 bhp at the crank to 152 at the wheels.nitrous going on next.....if it ain't broke,keep bolting on go faster parts until it is........ www.fordgranadaclubuk.freefo.de
mk2cossie
Mar 16, 2021 21:09:01 GMT
Good luck on the rack mate! My worst nightmare and single most expensive issue bar the repaint. In the end I ended up putting in a different rack as three rebuilds had not fixed my original mk1 rack. I do presume you to have a more servicable item than that particular mk1 rack, but still... Hope you get it sorted easily enough! Looking back, the biggest mistake was replacing the rack that was in there for a worn right hand,inner track rod joint. Supposedly unavailable separately, I should've chased up other avenues for a supplier of them to set dimensions. Thankfully, it isn't too tricky to replace. Just a slight annoyance I'd be willing to buy a set of BOB camshafts off your good shelf if you have a set to sell
mk2cossie
Mar 16, 2021 21:10:27 GMT
someones been busy,makes me want to get back on my garage dweller...... have you asked vic regarding the rack. he knows pretty much everyone with a granada. or you could try the bathside garage. they sorted me out with pas pipework when i needed some. they have entire cars. I wouldn't mind being busy, but I didnt get half of what I wanted to done on Saturday Blimmin wiring takes up far too long to do well i find
mr
no jobs ever go as planned,on the up side, practice makes perfect lol. it took me 4 1/2 hours to swap my sump over with the engine still in the car. 3rd and final time i did it, i had it down to 40 minutes. there used to be a place in charlton/greenwich that reconditioned racks. i had mine done there years ago. they do taxis mainly.i'll see if i can find that place and get you their details if they're still there
mk2cossie
Mar 17, 2021 18:49:07 GMT
Second hand rack secured via ebay Hopefully fit that and forget, or send one off for refurbishment
eurogranada
As I have a spare engine I do in theory have a set too many. In the end I only need one engine under the bonnet.
I'd love to build a fresh bob out of my spare this year and use the fall season for changing it over. But it's a costly thing... And I've also been offered many bits of an LPG system for free needing to only add the missing bits myself. But that in and of itself is also still costly and there's a challenge of getting it certified if you do the work yourself. Our DVLA is known for hardly ever approving of diy installs. So best et would be to find a friendly installer willing to sign off and register the change at a reasonable fee).
What I'm saying is. It'll probably be a while before I know if I can sell you a set.
Although the aim is to start stripping the spare engine as soon as it gets a little warmer.
