This Is a dream car. Just read the entire thread, much thanks for posting here. My US spec 75 is sitting in my driveway waiting to be recomissioned. It's at that critical point where it could be scrapped or brought back to life, each option having equal merit based on its needs.
I've actually managed to come out of my recent divorce money-ahead, and I've got some plans for for the Alfa...
k18nob
Jul 21, 2015 23:19:11 GMT
This Is a dream car. Just read the entire thread, much thanks for posting here. My US spec 75 is sitting in my driveway waiting to be recomissioned. It's at that critical point where it could be scrapped or brought back to life, each option having equal merit based on its needs. I've actually managed to come out of my recent divorce money-ahead, and I've got some plans for for the Alfa... Good to hear! They are very nice cars although they are very overlooked. Should see a lot of progress on mine over the next few weeks, hopefully will have the engine running pretty soon.......as long as I can get to grips with the Ecu once it arrives.
1989 Alfa 75 Veloce 3.0V6 24v
2008 Alfa 159 TI 1.9JTDM
k18nob
Jul 21, 2015 23:22:30 GMT
Beautiful! Who makes the throttle body kit? I can't make out the name on the castings. The throttle bodies themselves are Jenvy but the manifolds were made by A H Motorsport
k18nob
Jul 21, 2015 23:24:24 GMT
lovely looking engine! what sort of power are you hoping for Not sure really, the original engine was around 220ish I believe, I don't think it would be un-reasonable to expect around 250? Depending on the map of course
k18nob
Jul 21, 2015 23:31:04 GMT
So I pulled a late shift on Friday night, got the flywheel from the old engine fitted to the new one..... Then came the bell housing and starter motor..... Then came the fun bit...............engine in time!!! Once in I got on with re-building the injectors and fitting the fuel rails...... A lot of other work has gone on but nothing really noteworthy, I will keep you updated when it does
how in the hell have I not seen this before, absolute porn
k18nob
Jul 22, 2015 19:48:53 GMT
Had the fun of this arriving today, it's a semi made engine loom. Just have to add in what's required for your specific requirements then trim/terminate the leads And so began the fun of wiring in the injector/coil pack leads. I also added a shift light, fan controller, lambda sensor and something else which evades my memory Wasn't much fun trying to feed it all through the firewall. But got there in the end and very loosely layed out the route for the wires in order to plan how many branches will be required from the main bulk of the loom once it's all terminated and tidied up That's all for now! Next part should see the wiring finished, oil cooler fitted, hopefully I can work out a decent routing for the throttle cable as it's currently very poor and sticks a lot.......who said customising wasn't fun?
luckygti
I need to try harder!
Jul 22, 2015 20:23:21 GMT
The kit went together very nicely indeed I think I just had a bit of an accident! That looks incredible! Cars looking pretty tasty as well.
Jul 29, 2015 16:34:52 GMT
some serious cash is being spent here..... note the difference in flywheel (nevermind the greasy engine)
-charles- maserati biturbo alfasud sprint 16v clk55 amg
k18nob
Jul 29, 2015 19:40:19 GMT
some serious cash is being spent here..... note the difference in flywheel (nevermind the greasy engine) Oooooh you had it lightened, How much was removed?
Jul 30, 2015 18:08:44 GMT
i do not know exactly, 2~3kg i think
Jul 30, 2015 18:09:31 GMT
got it balanced also
k18nob
Feel like ive been working my fingers to the bone but cant see a huge amount of progress, anyway here goes..... Front bumper fitted, Only to get an idea where to mount the oil cooler which is now done but i seem to have forgotten to take pictures of that :/ Fuel hose is plumbed all the way into the engine bay (didn't calculate the right amount of connectors when i ordered them so haven't gone any further yet) Wired in a live and ground to the ecu to check it actually works.....Pleased to report it does Wired in a shift light.... Then came the part ive been dreading for a while, Making the engine loom All went really well, I havent wired in the sensors yet as I'm sadly cursed with the need to sleep. Should get it sorted though and then..........first start
k18nob
Sept 6, 2015 19:39:02 GMT
Well its been a little while again as usual. I have reached the point in the build where i can spend days working on it with no real noticeable change but finally there is something worth showing. Been working away trying to set the ride height, Not much fun playing around with torsion bars and the add on coilover kit which ive fitted but it can be fun laying with different heights. This was the first attempt, Sitting ever so slightly lower than id like..... Offered up the front bumper, lights and grille (not bolted in) just to see how it all sits Rear bumper is now fitted, car will be going away to have a full custom exhaust built a week tomorrow I did manage to get the engine started the other day, not very good with videos but if i can work it out ill upload one. Was running with no manifolds so sounded like a single cylinder generator but it idled very well and seemed to be all working well enough.
Sept 6, 2015 19:50:15 GMT
That is 'stupenda!' It translates to something like this...
stupenda {adjective} wonderful · gorgeous · fantastic
Well done, a truly quality build.
luckygti
Sept 6, 2015 20:02:59 GMT
Stunning looking car! Can't wait for the engine video.
k18nob
Sept 6, 2015 21:34:45 GMT
I think I am officially a youtuber??
I forgot to press record when I was starting the engine though so sadly it's already running as the video starts but here it is.....
You will see what I mean about it sounding like a single cylinder generator at the moment......will be sure to do another few once the exhaust is done
sounds good, nice evenly "thump" each cilinder is playing along
neil79
Sept 7, 2015 10:12:21 GMT
Oh my word, that is stunning!
dikkehemaworst
Club RR Member Number: 16
Sept 7, 2015 11:04:55 GMT
One of the first times the term automotive porn is used correctly. this really looks better than the nipples on a chocolate dipped supermodel!
