foxy99
It can be a bit confusing working out which is left and right with these once they are off the car so I'll put a pic of mine up to help. one on LHS of picture is driver's side My car is a 1974 Daimler Double Six but I think the part is same for 6 cylinder models and the XJS but possibly different for Series 3. They must've changed to metric threads at some point..... bleed nipple on mine well and truly stuck. now has extractor snapped off inside it too
Last Edit: Feb 27, 2012 2:49:42 GMT by foxy99
foxy99
bump
foxy99
I took a chance on a very cheap passenger side one which the seller listed as XJS and all the threads are the same but the pistons are different and there are no 'cut outs' at the mounting holes. I reckon they would be interchangable... NSR calipers. one on RHS is later type. only visible difference is the skimmed areas at mounting lugs on LHS oneone in right is not actually bigger. optical illusion?pistons differ
foxy99
still looking for one. XJ or XJS is fine. Any condition
foxy99
Found some new pistons for the later type caliper very cheaply on Ebay. Was a bit dubious they'd fit as not OEM but they look spot on. Still need a driver's side caliper tho....
foxy99
Still looking for a driver's side rear caliper.....any condition
