Oct 25, 2017 18:27:37 GMT
Last Edit: Oct 25, 2017 18:42:50 GMT by jim
Oct 25, 2017 19:31:47 GMT
Nice job. Very good looking shell
79cord
Lots of work there, good to see you've survived the ordeal to show it off! Must buy similar paint myself.
Last Edit: Oct 26, 2017 5:13:24 GMT by 79cord
Oct 26, 2017 14:02:34 GMT
Epoxy is great stuff, easy to spray, waterproof and sands back to a superb finish, also not a cynate so easier to use on a diy basis. (Still needs a good filter mask, epoxy coated lungs can't be good for you!)
Its been used on boats for years, my dad was buying it a £50 a litre 20 years ago, every year when we pressure washed the boat the anifouling would come off to reveal a perfectly intact epoxy layer.
Dec 17, 2017 21:18:11 GMT
Thanks for the comments guys - it keeps the motivation up! Since last time I've been working on the rear seat belts I've welded the plates on underneath it was one of the last jobs to do before paint. I tried to sort the underside of the seat but in my haste I blew through the "steel" and made a right mess so I had to go bigger The 1st version had a folded edge but it looked shocking so I cut it off and made the profile which I drilled for plug welding I have ground it back since but forgot to take a picture, my bare metal work had now bought me to the front footwells but I got quite angry as I paid for work to be done a few years ago to do the jacking point on the passenger side - this is their handy work! Just chopped it and left it! And there's 2 holes in a leg next to where they worked - I'd name and shame but it's not worth it as I should have checked all their work and they no longer exist so I'll sort it as best as I can
Dec 28, 2017 19:26:30 GMT
Merry in between Christmas and New year! Finishing off from last time - the repair piece in the chassis leg has been cleaned up. I bought myself a few bits for tina that arrived just before Christmas I've got enough bits to get the car epoxy primed, filled and high build primered and stone chipped. One of the toys I bought was a 5m endoscope that can be used through my phone- today I shoved it up the chassis legs to see what the condition is like before cavity wax goes in. I can use the photos for reference. Seems to be good for a 50 year old! Is it best to prime the underside before injecting the dinitrol? So the plan tomorrow is to tidy some welds up on the inside and check for pinholes in the welds before spraying epoxy. I'll also get the interior ready for epoxy too as I'd like get this going asap!
Dec 29, 2017 15:21:10 GMT
Today has been quite productive considering I was only in the garage for a few hours! I've been working on getting rid on the red oxide inside the car so I can spray epoxy in here. I will start the outside but I'm considering lead loading so it would mean leaving it bare for longer. The new da sander is cutting through nicely I just have the channels to do by hand I removed the dash top and found it to be quite crusty so god knows what's happened as the a pillar is fine where it's rusted as was the floor?! I pulled the front and rear screens too - I'm quite excited to start the bodywork as it's not something I've done before plus it's a hint of light at the end of a very long tunnel. Dusty! I'm going to try and get in the garage more as I've been slack over the last few weeks so hopefully I can get more updates in
Dec 29, 2017 15:40:16 GMT
The rust on the underside of the padded dash top will be a combination - it looks like the windscreen has been leaking slightly but also you will be surprised has to how much condensation occurs in hidden areas like this - dash areas can get quite warm and retain heat for a while once the car comes to a stop - plus metal panels that weren't particularly primed if primed at all when the car was new so it's not that surprising - having said that looking at your pics you appear to have a very sound & original bodyshell on which to base the restoration
Jan 14, 2018 20:34:34 GMT
wow!...very thorough work...nicely done.
JP
I had my mk2 Cortina sand blasted and then immediately epoxy primed. This stops any moisture getting to the metal. You can fill straight over the epoxy. The body shell is in remarkable condition. As you said you want it to look original in the boot are you going to replace the repair in the tool well side? It looks a solid repair but the panels are available quite reasonably priced from the owners club.
Personally on bare metal restorations I complete all my filler work before applying any polyesters / primers or epoxy - that way you complete 95% of the dust making processes prior to starting with paint - obviously paint & dust don't go well together so it's nice to get to a stage whereby you can draw a line under it - It can be difficult though depending upon your storage conditions for the car / panels whilst in bare metal - the slightest dampness in the air and surface rust will appear - ideally a dry workshop with a airflow through it is the route to take but from what I can see in your images you don't have a problem - nice to see the progress.
Last Edit: Jan 15, 2018 13:37:55 GMT by Deleted
Jan 15, 2018 12:44:22 GMT
That makes sense - I've started the inside as my plan around the car is;
Inside epoxy Underneath epoxy Inner wings epoxy Seam seal Outside epoxy Then follow suit for high build primer apart from the underside. Upol raptor the underside Paint inside Paint engine bay.
The doors will be off and primed and painted separately if I'm off somewhere I'm all ears as I've only painted airfix models up to get! Ill try and do tge prep myself and see what the result is before paint as I don't think I'll be able to lay colour at home.
The garage is pretty dry but I have a small dehumidifier that can sit in the car and run between filling and epoxy I suppose.
turbom
Jan 15, 2018 18:56:42 GMT
Nice shell you have. What make is the sander you have in the pic???
Jan 15, 2018 19:38:14 GMT
Jan 15, 2018 19:54:03 GMT
Jan 21, 2018 20:17:32 GMT
I've had sanded the areas I couldn't reach with the DA, I found a few pin holes where repairs had been made but no photos as it's nothing amazing. After clearing up the dust and curse word inside the car i made up a first batch of filler I used the plastic lid - it's been a long time since I did filler repairs so I don't think I out enough hardener in so it felt soft after a few hours so I hope it sets! I found a bigger plastic lid to use I used more hardener and that's set fine- I've started to sand it after an hour of cleaning and fighting spiders! PHOTOS!
Jan 21, 2018 20:38:24 GMT
Jim - Guide coats will help you with the filler & sanding - before you rub the filler down just mist over the top of the filled areas with a cheap tin of matt black aerosol - you will be surprised has what a difference this makes when it comes to sanding back by highlighting the areas that require further sanding or filling whilst also indicating the areas that require no further work - image attached below - hope this helps - Chris
Last Edit: Jan 21, 2018 20:39:11 GMT by Deleted
Jan 21, 2018 20:58:27 GMT
I'll do this too, I bought some guide coat powder but I thought that's more for filler primer?
Do you think I'll be ok with the filler that doesn't have as much hardener?
Jan 21, 2018 21:12:44 GMT
turn your wire speed down a bit less build up of weld
