Jan 26, 2012 17:22:24 GMT |
Saab engine?  Actually I know they are heavier than the redtop so thats out. But doesnt a TD lump weigh more than a redtop? Ive seen the saab engine done and its very wide so you end up cutting chassis legs etc so a c20let would be less hastle for that power plus as you say they are heavy too. As would be the TD but going that route would be aimed more to the side of economy than power or fastness (although it would be quicker than the GTE or GSI nova with loads more torque), meaning i may not begrudge driving it regually. Hhhhmm food for thought!
Jan 26, 2012 17:40:01 GMT |
Go Derv please go Derv...........
Jan 26, 2012 21:39:47 GMT |
TD doesnt weigh more than a redtop, same footprint in the block, alloy head. infact you could argue its lighter, one less camshaft as associated drivetrain.
would be a cool project, what about a tuned 1.5TD isuzu unit from a late nova or corsa B ? direct fit, and still unique
Last Edit: Jan 26, 2012 21:40:25 GMT by darrenh
TD doesnt weigh more than a redtop, same footprint in the block, alloy head. infact you could argue its lighter, one less camshaft as associated drivetrain. would be a cool project, what about a tuned 1.5TD isuzu unit from a late nova or corsa B ? direct fit, and still unique The TD's are quite heavy but i could'nt be sure which is the heavyest - it would be interesting to weight them. Why go for the 1.5? The 1.7 is the same other that the CC.
why not go Y20DTH then? why anything lol
my logic is as above, 15 is already native, was just thinking of simplicity
Jan 27, 2012 10:54:08 GMT |
luks cool dude i loved your loon got my own loon allways wondered where did u get the exhaust id love 1 of them mine its unreal
Jan 27, 2012 10:56:37 GMT |
ps i hate you for owning a shovel nose wish i cud find 1
Jan 27, 2012 11:39:50 GMT |
why not go Y20DTH then? why anything lol my logic is as above, 15 is already native, was just thinking of simplicity All i was saying is that the 1.7 td is the same as the 1.5 so if your going 1.5 then you might as well go 1.7
Jan 29, 2012 19:51:21 GMT |
Jan 29, 2012 20:04:10 GMT |
dtvracing
On the diff....
Jan 29, 2012 22:52:50 GMT |
Liking the use of the plasma, never actually thought of using one but when you think about it it stands to sense, all those fidly bits can be cut out neatly. Top job so far, keep up the good work
I love these, they have the "hooligan" look about them straight from the factory!
Jan 30, 2012 10:14:46 GMT |
Cheers Chap. Yer the plasma makes short work of most cutting and you down have to go at it cutting bit by bit with the grinder
Jan 30, 2012 10:56:52 GMT |
very thorough work sir, i like it.
brace bars are good, although that assumes the car was square in the first place hehe !
Jan 30, 2012 11:14:55 GMT |
very thorough work sir, I like it. brace bars are good, although that assumes the car was square in the first place hehe ! Thanks Darren, when the car was still in one piece i stuck some drop lines on it and had a quick measure up all seemed as it should for a nova. no unusual tyre wear and it steered in a straight line which is always a positive start lol
you have some mad fabrication/welding skills! great to see a nova being restored!  dad still has his b reg one thats been in the family since 1992! apart from the engine, are you restoring the interior/exterior back to standard? or going to modify?
My god man, your welding skills are ridiculous! Really like the derv route you're going down too.
My god man, your welding skills are ridiculous! Really like the derv route you're going down too. Cheers Arkle i'm not 100% set on the 1.7 TD route however it looks like a good option, i have been toying with the 1.6 16v on bike carbs route too ;D you have some mad fabrication/welding skills! great to see a nova being restored!  dad still has his b reg one thats been in the family since 1992! apart from the engine, are you restoring the interior/exterior back to standard? or going to modify? Thanks Chris, i have a few ideas (nothing boy racer before anyone starts  ) i had originally thought i might go down the rounded nova saloon arches route. I even destroyed a rotten saloon for the rear quarter panels but I'm now undecided as they box arches are so typically nova. What ever i do it will be staying the original colour and look pretty standard. As for the interiour i was considering a cage and bucket seats but we will see. i started by cleaning off the edges of the bits to make up the front lower cross member so i had a nice clean surface for weldage   Clamped them in place to keep everything were it should be   Applied a few tacks of weld   Giving me this  Then the first run of weld   Both sides welded  Cleaned off a bit  And ran a grinding disc through the centre of the weld on the top facing surface to V it out a little so i could run a cap weld over the to so it will smooth out flat.  Caped  V'ed the other top facing surface  And capped  Smoothed  Primed    And tried it for visualisation     I'm happy with that
