Jonah - I always assumed that the rubber would melt, will have to try that the next time Well went into the garage tonight to see what had happened with the Hammerite Gel, and it would seem that apart from drying out and going hard, not a lot, so ordered some of the Bilt Hamber Gel as recommended by Sphinx, hopefully it will be here before the weekend
mirafioriman
My next project.......
I've used the Bilt Hamber gel. It's pretty good, wrap it with cling film to stop it drying out and leave it 12-24 hours
dbdb
Its great to see another thread Tony, they're always excellent. My dad had an E28 in this colour combination in the mid 1980s. Lovely cars.
David
Looks familier my old e28 went pretty much in the same place. Bookmarked for another tonybmw thread
The louder you Scream the faster we go
Great work as usual Tony and grade a results too! i will also be promptly book marking this
will
Great stuff, watching and learning all the way
Kedge
These are the kind of threads that make me really wish I knew how to weld. Will be following this thats for sure.
1983 Mk1 Golf GTi Mars Red
1986 E30 316 Polaris Silver (M20B25 Project)
2013 Triumph Street Triple R
2005 Seat Leon TDi FR Grey
L. Ron Cupboard
75 Landrover lightweight,88 BMW535i
This is a joy to read, your patience and attention to detail is inspiring! As regards rust killers try machine marts it's dirt cheap for a litre, dilute a bit in an old jar, drop in rusty bolts or small parts and by the morning they're clean.
Jan 15, 2012 20:00:24 GMT
Got some of the Bilt Hamber Gel and it did an Okay job, not as good as the DEOX C liquid, but due to the size of the part, it could not be soaked overnight, but a quick wizz over with the wire wheel on the drill, and it came up nice and clean So painted the inside of the panel, just to try to make sure it had paint in all the tricky to reach places Sprayed the rear flange with the Zinc weld thru Primer and then tried the panel on for size there was still the problem of the seam having to have been cut away, because of the rust, so that will need to made back up again, decided to do it like this Weld in a bit of 16swg, it needs a fair chunk of weld to fill the gap But once its trimmed down and ground It should be okay and then repeat for the other side So then clamp the panel in place, after marking and drilling the holes to be pool welded and weld it all up and then after a bit of Grinding and DA action and the Dremmel into the tight spots, we're all done I'm going for the Factory look, so the part welded and overlap is how its supposed to be
Last Edit: Jan 16, 2012 18:53:05 GMT by tonybmw
Mart D
Jan 15, 2012 20:06:26 GMT
Good work! Sending some E28 love
sphinx
Jan 15, 2012 21:09:09 GMT
Awesome repair skills! love how you built that corner back up.
stefan
If it isn't broken fix it till it is
Jan 15, 2012 21:28:45 GMT
The master of the invisible repair strikes again, great work as always
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
Jan 15, 2012 22:31:42 GMT
Your work gives me butterflies. On one hand I can't wait to start practicing your techniques on my own cars, on the other hand I'm still scared of doing bodywork stuff.
Do you take work in Tony? I'd pay to get a few spots on the Viva welded but I want it to be a seamless invisible repair so it looks factory fresh and have no idea what body shops to trust.
Project Diary1975 Viva / 1988 T25 Camper / 1989 Mini / 1991 MX5 / 1992 Mini / 1994 Saab 9000 / 1997 Saab 9000 / 2008 Saab 9-5
Mark
Just out of interest Tony, where did you learn to weld etc?
dbdb
Jan 16, 2012 15:15:22 GMT
Truly excellent and like all things of great quality, a pleasure to see.
David
Jan 16, 2012 17:45:31 GMT
I'll be following this with great interest! Lots to be learned here
Jan 16, 2012 19:00:28 GMT
Your work gives me butterflies. On one hand I can't wait to start practicing your techniques on my own cars, on the other hand I'm still scared of doing bodywork stuff. Do you take work in Tony? I'd pay to get a few spots on the Viva welded but I want it to be a seamless invisible repair so it looks factory fresh and have no idea what body shops to trust. Oli My Advice would be to give it a go, what the worst that could happen ?? And sorry no time for any more projects for the foreseeable future Just out of interest Tony, where did you learn to weld etc? Mark As far as working on cars goes I started by buying a welder and teaching myself, but then got a job as a sheet metal worker, working in thin Gauge stainless steel, so I've had plenty of opportunity to hone my skills
Jan 16, 2012 22:41:14 GMT
Looking good Tony. I like that trick with welding in a small sheet of steel to fill in the gap. Very clever.
Jan 17, 2012 16:58:33 GMT
Another ace repair great work
johnrh
Jan 19, 2012 13:57:21 GMT
You work is looking great Tony, as always. And I love the e28 M5.
John
