Dec 18, 2011 15:40:41 GMT
The rear of this rabbit has an interesting air setup that I can't find a photo of at the moment.... But here's a photo of it raised slightly. That is interesting. The rear suspension on a Golf is a twist beam with trailing arms isn't it, so as standard camber would remain the same throughout the suspension travel. But it certainly looks reduced in that photo, so there must be something else very interesting going on there? I'd like to see more photos if you can find them. If it is on air, then I don't see why it would be inherently dangerous I'm willing to bet that he doesn't normally drive it at that ride height. But of course it's much easier to assume straight away that he does without really knowing anything about the car... And: shouldnt be called camber when its not for handling and purely for a stupid scene look in my opinion Camber by definition is the angle the wheel's centre line makes with the ground when seen from straight on. What else exactly would you call it? I'd go for "lots of camber"... ...Anyway. Positivity. Here's a picture of it with a Euro front end: Nick Middletons bagged rabbit by JLOgraphy, on Flickr EDIT: From the comments here: "He built a custom independent rear suspension. It's also on airride, so he can lower it at will. The camber is from the design of the IRS in back."
Last Edit: Dec 18, 2011 15:49:33 GMT by Rich606
CIH
Dec 18, 2011 17:44:49 GMT
I was about to suggest maybe he removed a few washers to reduce the camber.......not for me but power to him for the work put-in. Wonder what the IRS is based-upon/pinched from ?
Jowey
Dec 18, 2011 17:45:20 GMT
excellent. why build custom IRS with more swing in the rear wishbones than the front ? if there is some kind of benefit to the extra swing at the back; what is it? I've explained before tucking the wheel up into the wheel arch on a car that has really round bubble arches never works and is something that causes me great unease I feel to immitate the broken air-cooled look I say he needs to chop the wheel arches off as per this photoshop Or alternately sit some nice wide wheels with lots of rubber BELOW those bubbly arches instead to give a good purposful look.
2000 Mercedes E55 //AMG 1998 Alfa Reomeo GTV 24v 1997 Alfa Romeo Spider 16v 1996 Alfa Romeo Spider 16v 1996 Suzki Swift 1.0 GLS
dw1603
Does anyone know for certain that it has a custom built air sprung rear end? If it is a swing axle set up, then the pivot point must be very low. Wishbones would need some pretty radical geometry to give the range of camber shown in the various pics. The rear spindles on a Golf bolt onto the ends of the trailing arms, the easiest way to get extreme camber is to unbolt the spindle and refit it with spacers of some sort on the lower bolts. Certainly not something I would consider doing.
I can confirm it is a bespoke swingaxle type set up.will try find a pic sometime. It's even gotta engine driven pump for the airride. The front would be lower but he can't get the tyres he needs over there.
muttley racing ftmfwmf
Cambered Rabbitstealthstylz
@stealthstylz
Club Retro Rides Member 174
He looks like he should still be playing with Lego so for him to build a custom IRS is very impressive. As I said before it definitley has an aircooled vibe going on, which is probably why the front doesn't have any camber gain.
Matt
That car was built by a member of VWvortex with the user name Patatron. It is indeed a custom swingaxle airbag setup. He was trying to emulate the look of a slammed bug. No other reason for it, he just wanted it to look cool. Found a pic of the rear suspension Pat was a cool but very opinionated guy who got into a fair bit of trouble with a failed business and dissapeared from the internet after he sold this car to try and get some cash together to make his many wrongs right.
That car was built by a member of VWvortex with the user name Patatron. It is indeed a custom swingaxle airbag setup. He was trying to emulate the look of a slammed bug. No other reason for it, he just wanted it to look cool. That is a good enough reason!
nconst
funky fresh since 89'
Dec 21, 2011 12:47:27 GMT
I love this !! My new desktop aswell don't like it with the euro front end tho.
Dec 21, 2011 14:06:52 GMT
Each to their own but not for me..........too much camber.
VIP
Dec 21, 2011 14:21:29 GMT
I think Dbiz once said; Complaining a car on air suspension is too low is like complaining your dinner is too hot and then throwing it away. Or something. *cough* Complaining that a car on adjustable suspension is too low is akin to throwing away your dinner because it's too hot.
Jowey
Dec 21, 2011 15:06:01 GMT
I guess sometimes your dinner is a salad.
Dec 21, 2011 15:40:19 GMT
I guess sometimes your dinner is a salad. Ha! I like that. The comment that is, not salad, I'm not a rabbit. VIP (Or square I square as it appears on my screen) cheers for putting that right. I think the US front does suit it much better, somehow.
CIH
Dec 21, 2011 19:45:56 GMT
Found a pic of the rear suspension TBH I'm struggling to make sense of that
Last Edit: Dec 21, 2011 23:15:20 GMT by CIH
RobinJI
Dec 21, 2011 21:29:47 GMT
Looks to me like a very primitive (quite extreme angle) semi-trailing arm set-up relying on the compression of rubber bush's to give any movement. Definitely not very well designed, will give rather a lot of toe as well as camber, and as he's made the bush's unstressed at full droop not ride height, the bush's will last about as long as an x-factor winners career, not to mention the pointless lack of bracing between the 2 inner mounting points. However, having said all that, I really don't particularly care , as he clearly isn't bothered about handling, and I doubt the car sees enough miles, or hard enough driving to worry about the bush's wear rate. The car looks very cool, and if you're going to have a cambered car, then I'll give a big 'hell yes please' to the idea of having zero camber at driving ride height, and double-take amounts at 'show' ride height . I'll also admire the fact that he had the balls and ingenuity to redesign the cars rear suspension to make it what he wanted, rather than just bolting on some coilovers/bags, even if he didn't do the best job, it looks safe enough, and appears to serve its purpose. PS, I love the US spec front end.
Last Edit: Dec 21, 2011 21:33:21 GMT by RobinJI
markbognor
Club RR Member Number: 56
Cambered Rabbitmarkbognor
@markbognor
Club Retro Rides Member 56
Dec 21, 2011 21:35:17 GMT
Surely he could have fixed it on more securely than with mole grips though.
RobinJI
Dec 21, 2011 21:38:25 GMT
Surely he could have fixed it on more securely than with mole grips though. ;D haha, yeah, surely everyone knows brightly coloured zip-ties in a criss-cross pattern are the best method for this type of thing?
Dez
Club RR Member Number: 34
Cambered RabbitDez
@dez
Club Retro Rides Member 34
Dec 21, 2011 23:56:29 GMT
Looks to me like a very primitive (quite extreme angle) semi-trailing arm set-up relying on the compression of rubber bush's to give any movement. Definitely not very well designed, will give rather a lot of toe as well as camber, and as he's made the bush's unstressed at full droop not ride height, the bush's will last about as long as an x-factor winners career, not to mention the pointless lack of bracing between the 2 inner mounting points. However, having said all that, I really don't particularly care , as he clearly isn't bothered about handling, and I doubt the car sees enough miles, or hard enough driving to worry about the bush's wear rate. The car looks very cool, and if you're going to have a cambered car, then I'll give a big 'hell yes please' to the idea of having zero camber at driving ride height, and double-take amounts at 'show' ride height . I'll also admire the fact that he had the balls and ingenuity to redesign the cars rear suspension to make it what he wanted, rather than just bolting on some coilovers/bags, even if he didn't do the best job, it looks safe enough, and appears to serve its purpose. PS, I love the US spec front end. well put. i did wince when i saw those shameful attempts at inner pivots though, or more imagining what they look like when fully dropped.
CIH
Dec 22, 2011 22:39:42 GMT
However, having said all that, I really don't particularly care , as he clearly isn't bothered about handling, and I doubt the car sees enough miles, or hard enough driving to worry about the bush's wear rate. The car looks very cool, and if you're going to have a cambered car, then I'll give a big 'hell yes please' to the idea of having zero camber at driving ride height, and double-take amounts at 'show' ride height . I'll also admire the fact that he had the balls and ingenuity to redesign the cars rear suspension to make it what he wanted, rather than just bolting on some coilovers/bags, even if he didn't do the best job, it looks safe enough, and appears to serve its purpose. PS, I love the US spec front end. Totally. He had an idea and saw it through to completion.
Cambered RabbitRobinxr4i
@robinxr4i
Club Retro Rides Member 143
As others have said it's not at all refined as suspension setups go and the inner pivot bush is almost comical in how primative it is. However the simplicity of the design is quite excellent. It's clear this isn't a mega budget build, but the desired effect has been achieved. I love it!
