foxy99
bstardchild I just ended up centre punching the spot welds and using a normal 5.5 or 6mm drill and found it much quicker and getting really neat plug welds afterwards in the smaller hole. gn3dr I would like to try one of those flat tipped cobalt drills. Have seen them in the FROST catalogue but will maybe leave that for my next (last) project theonlyhillmanimppickup.wordpress.com/ as the body repairs are nearly finished on the Daimler
Last Edit: Jan 3, 2012 17:52:26 GMT by foxy99
foxy99
Right. Am still trying to find my bearing as to what came first, in the early repairs. I started keeping as log of what work I did round about 2006 which makes for some pretty dull reading at times. It actually turned into more of a diary so where it was meant to be recording hours spent on jobs I find I'm writing about things that happened in work To keep myself right here I'll post any entries I made, relating to the Daimler, in the log and it will help get this thread posted in the right sequence. October 2006- Saturday 21st 'took closing panels off sill'
- Sunday 22nd '....worked on sills rest of day....'
- Sunday 29th - 'did Jag sill'. I reckon this meant working on removing the old outer sill
November 2006- Monday 20th 'started removing bumper bolts (Jag) '
- Thursday 23rd 'got big screw off passenger side of bumper'
- Monday 27th 'welded square bar between passenger side A&B posts'
December 2006- Tuesday 5th - 'welded bar to seat bracket'
- Tuesday 12th - 'started taking off radius arm panel'
April 2007- Sunday 2nd - 'welded bit onto Jag box section. long bit'
- Monday 9th - 'drilling spot welds from sill rear top edge'
- Friday 13th - 'sawed curved part of radius arm panel away from inner arch'
- Sunday 15th - 'drilled spot welds. seat pan to rear inner sill top face'
- Wednesday 18th - 'removed rear sill end'
- Thursday 19th - 'drilled radius arm bracket off old panel'
Things go kinda quiet after this as I spent the next 7 months or so welding up my daily driver (M reg Suzuki Swift) to get it through the MOT so was cycling about town and work on the Daimler went on the back burner. I also got caught up in some tiling work to make ends meet. I got my car MoTd/taxed etc on 4/12/2007 so was mobile again and the entries I find on the 'Jag' are.... November 2007- Saturday 24th - 'started drilling out the spot welds @ front of the passenger side sill'
December 2007- Saturday 1st - 'major turning point with Jag sills. got the bit out @ A post'
- Saturday 29th - 'started on radius arm panel. it looks like it will be a straightforward swap for the bolt on boss thing. did lots of measurments then started grinding panel to fit space on car'
January 2008- Saturday 5/1/2008 - 'spent afternoon measuring for wedling radius arm boss and grinding bits off car & box section'
- Sunday 6/1/2008 - 'got back to work on box section. drill 3 plug weld holes for bit at seat pan. cut some steel and put in rust remover ready to make repair at seat pan vertical face'
- Tuesday 7/1/2008 - 'fished out metal plate cut for seat pan repair. cut it shaped it and tacked it in'
- Saturday 12/1/2008 - 'welded rest of seat pan repair & ground welds down. cut jacking point out of old box section and put in rust remover. did more measuring and adjusting on box section. put new box section in rust remover'
- Sunday 13/1/2008 - 'put primer on nose of box section. trial fitted radius arm boss with bracket to box section'
- Tuesday 15/1/2008 - 'welded radius arm boss to box section'
- Saturday 19/1/2008 - 'lit up oxy/act gear to get one of the screws out of the box section jacking point then acytelene ran out'
- Tuesday 22/1/2008 - 'cut strips for floor edge repair and put them in rust remover'
- Saturday 26/1/2008 - 'took floor strips out of rust remover and shaped bends in them but they started to curve. bit disheartening. did more measuring for box section'
- Sunday 28/1/2008 - 'cut bar to size to weld into seat pan to front seat crossmember area. maybe cut bar on Saturday and welded it Sunday!'
- Monday 28/1/2008 - 'welded bar in. started grinding at middle post to inner sill area'
- Tuesday 29/1/2008 - 'straight onto sill work. grinding area to separate inner sill from middle door post. cut 4 spotwelds with hacksaw at same place. prev night had did bit that goes over bracket for seat'
- Thursday 31/1/2008 - 'drilled spot welds at seat pan and ground away sill to door pillar area'
February 2008- Friday 1/2/2008 - 'finished taking sill off'
Last Edit: Jan 14, 2012 17:53:04 GMT by foxy99
foxy99
Last Edit: Feb 16, 2018 3:13:05 GMT by foxy99
dbdb
An excellent thread for a beautiful car.
David
dggp
I'm really enjoying this thread, i need to do all the same bits on my xj coupe so its nice seeing the path being trodden before me. Top work
foxy99
dggp glad you're enjoying it and hopefully it will be of some use to you but its been pointed out to me recently that the coupe rear wings/arches and parts of the sills differ so may not be quite the same path. Any pics of your project? Have you seen the thread started recently on the red coupe? by phil2600s I think. Anyway....back to the thread. I realise now that I definitely did the rear box section before the floor edges so that last post was a bit back to front. I'm there fore going to check my diary/log and put it up here for reference before more pictures. March 2008- Friday 14th - 'cut last seam out of Jag sill'
September 2008- Tuesday 9th - 'brought Jag sills (old & new) into garage to start putting holes etc in for fixing'
October 2008- Monday 13th - 'spent day preparing back part of floor repair strip & cutting floor edge to accomodate it'
- Tuesday 14th - 'started work on Jag 5ish. in at 9.30 for dinner. back out for a couple of hours to finish off rear repair'
- Wednesday 15th - 'worked on front part of floor edge till about 8. back out 11ish - worked till 3.30 on front edge'
- Thursday 16th - 'up 11ish and out to barn for a bit grinding repairs to front edge. in for tea 2ish back to finish welding. gas acting up. until 5.30'
- Monday 27th - 'cut away front 'toeboard' area of passenger side'
- Tuesday 26th - 'cut new toeboard panel to fit repair area'
Friday 31st - 'did more fettling of toeboard repair & drilled holes to match old bit & separating upright bit'
November 2008- Saturday 1st - 'worked on welding upright part of toeboard and final trimming'
- Sunday 2nd - 'barn after dinner. welded toeboard repair (90% - still a few bits to do) and trial fitted inner sill - getting there'
- Monday 3rd - 'ground down welds on toeboard from last night. cut inner sill at rear join & cut half moon shapes in top lip to replicate original. for some reason inner toeboard has moved! but everything else still exact. miraculously solved 'height' problem on rear jacking point box section with some hammering on top flange. also brought in the repair at seat pan vertical as it was kicking sill out'
- Tuesday 4th - 'drilled new inner sill to match old one & did the small floor edge repair between main floor & seat pan'
- Monday 10th - 'spent some time 'reducing' height of inner sill at rear then unbelievably got box section tacked in!!!'
- Tuesday 11th - 'did more welding on the box section & added lip to rear-cut-off-from-inner-sill'
- Tuesday 18th - 'worked on pinning inner toeboard back to 'original' position (put a bit more weld in some of the plug welds done on the jacking point) then drilled holes in inner sill to match its new position. also sawed some weld remains off inner sill from where it met inner toaboard at top (where I damaged loom)'
- Thursday 20th - 'rubbed paint from inner sillwhere it will weld to floor. ground some welds & did much offering up'
- Wednesday 26th - 'trial fitted doors. not good fit'
- Thursday 27th - 'did some more adjusting and measuring of doors'
December 2008- Thursday 4th - 'took Jag off jacksand pumped up tyres and door gaps improved significantly - woohoo'
- Wednesday 10th - 'took driver's side wing off'
- Thursday 11th - 'got driver's door aligned perfectly & both doors pretty good on passenger side'
- Monday 15th - 'sanded inner sill & areas needing plug welds. filled in all plug welds (about 90% of them). cut out large brace between seat xmmbr & rear seat pan. started cuttin intermediate one from xmmber to B post'
- Tuesday 16th - 'cut off bracing where it meats seat crossmember'
- Wednesday 17th - 'got internal brace off then started drilling spots from A pillar. stopped at 3 on back flange as prob best to take doors off again'
- Friday 19th - 'took rest of spot welds out & got large brace off. did final plug and seam welds on innrer sill. still a couple to do on B post. loosley fitted outer sill. will need a lot of work'
- Saturday 20th - 'started spotwelding the floor to sill - getting there . wasn't too hard!'
January 2009- Monday 5th - 'sharpened tips on spot welding arms. spot welded rear box section to inner sill and some at intermediate floor panel'
- Tuesday 6th - 'welded floor to inner sill/box section from rear to front seat xmember roughly (sharpened both ends of both tips) also ground inner sill bottom lip where it meets rear box section and did bit of vertical lip on B sect. (where it meets outer sill)'
- Wednesday 7th - 'finished spot welds to front of sill'
- Saturday 10th - 'spent day sanding paint off inner sill'
- Monday 12th - 'painted passenger inner sill then went to do driver's but car was soaking on that side so moved it over a few feet'
- Tuesday 13th - 'started black Blog about the VDP resto' jaguar-daimler-vdp-66.blogspot.com/
- Wednesday 21st - 'did rust encapsulator on driver's side box sections after sanding then did 2nd coat on passenger inner sill and started preparing end cap against old panels'
- Friday 23rd - 'drilled front end-cap andtrial fitted outer sill. looks like caps have to go on last. picked remains of outer sill from rear wheelarch area. drilled sill for seatbelt mount'
- Saturday 24th - 'spent evening making series 3 bracket into suitable copy of series 2. got it welded on. drilled rear end-cap'
- Sunday 25th - 'freed stoneguard from driver's-side wing and one of the 4 headlamp self tappers which are badly corroded. put wing up in loft with RHS outer sill andbrought remains of passenger outer sill down. finished welds on passenger rear seat belt fixing'
- Monday 26th - 'worked on tidying up welds on inner sill inside face and bit where braces were welded on. did bit on A post but still need to do front face of it'
- Tuesady 27th - 'cleaned up/welded front flange of A post to inner sill. sanded burnt areas of red oxide and touched them in. also painted bare areas on seat pan vertical face and rear floor pan inner. trial fitted sill and end caps'
- Thursday 29th - 'worked till 5:30 welding up voids in A & B posts and drilling top lip at area in front of A post and trial fitting end caps. played fives then back for 8 to finish sanding flanges for welding and drilled area at rear wheelarch. can't get spot weld arms into bottom lip so that will need to be drilled. also drilled both outer-sill curved flanges'
Last Edit: Jan 14, 2012 18:58:30 GMT by foxy99
Last Edit: Jan 8, 2012 15:28:46 GMT by Phil2600s
foxy99
Last Edit: Feb 17, 2018 13:50:31 GMT by foxy99
bstardchild
Club RR Member Number: 71
Jan 13, 2012 18:33:31 GMT
Sheesh -what a lot of rust and fabrication!!!
I've always reckoned Opels to be the worst in the world for tin worm but I've found minis to be dreadful and now I've seen worse!!
foxy99
Last Edit: Jan 18, 2012 1:50:59 GMT by foxy99
foxy99
Last Edit: Jan 20, 2012 2:38:46 GMT by foxy99
Jan 19, 2012 11:45:47 GMT
Those sills are vast! This build thread really is demonstrating how much work I'm likely to be taking on when I eventually buy my own Jag, and weirdly my mind is put at ease, not scared off, by the work you're doing.
foxy99
Volksangyl Hi. I find the car pretty easy to work on. Not sure why as all cars of last 40/50 years are basically same construction. Maybe its the room you have.... I remember Practical Classics did a full restoration of a pale blue SWB series 1 and in their article about the inner sill replacement is said it was a 3 day job. The company still took about 2 years to finish the car right enough As I'm nearing the end of this rebuild I can say with some certainty that I could do another one in perhaps 1/5th of the time it took to do this as a lot of the time is wasted planning and pussyfooting around a job you haven't tackled before. If I had to do a full sill replacement now I'd attack the job and maybe do it in 3 weeks but that's easy to say in hindsight. I would probably approach it something like:- - day 1 - grind remains of outer sill bottom from floorpan (3 hours)
- day 2 - drill out all spot welds from outer sill to inner sill & A/B/C posts (3 hours)
- day 3 - cut bars & weld them from A to B post and seat crossmember to rear seat pan (3 hours)
- day 4 - drill out inner sill spot welds & cut away seam welds at A & B posts (5 hours)
etc etc. You can see it still takes time and you might miss days inbetween but we're talking periods of weeks rather than months/years to finish jobs. An example of this is the rear wheelarch repairs. My first attempt was held up for about a year deliberating about where to cut and crying that the panels didn't fit properly but once I knew thare was no way round it I had the other one done inner & outer start to finish in less than a fortnight. Also the IRS. It seemed like a mysterious unit that would need a team of skilled technicians to work on but you could easily get it off and back on again in a weekend. I spent several nights trying to get the calipers off with it in situ but its quicker to take the whole thing off. It also gives much better access for welding repairs to the rear end.
Last Edit: Nov 16, 2012 2:04:01 GMT by foxy99
Jan 20, 2012 10:13:44 GMT
loads of work done there, looks like you're trying to rebuild the may rose! Atleast you will not have to touch it again with a welder for a very very long time ;D
Jan 20, 2012 16:25:05 GMT
Getting stuck in is vital to keeping a project moving. As long as you're sensible I've found a job gets done far faster by getting into it rather than fannying about with overplanning. Sometimes mistakes are made, but usually with a car, mistakes are easy to rectify if you notice them when you make them.
If it weren't for build threads like this I doubt I'd ever even pick up a power tool to have a go at the jobs I've done on my own car.
foxy99
Rob It is a great feeling to know I'll be packing away the MIG soon but I have got it all to do again on my Hillman Imp pick-up theonlyhillmanimppickup.wordpress.com/ although I am considering using Oxy Acetylene on that where possible. It's pretty hard to use on thin metal I believe but I've also heard that it is softer and more malleable afterwards and doesn't upset the metal and promote further corrosion. I have heard MIG can/does do this Anyway this post concerns a small but fiddly job I carried out one evening (24/1/09). As mentioned before, the sill you get when you order a series 2 sill is actually a series 3 one, which fits fine but is slightly different. As well as the oblong holes along its length, that the series 2 doesn't have, the mounting bracket for the outer rear leg of the front seat was nothing like the original one from my car and neither was the mounting for the seat belt inertia reel. After fitting the inner sill I was peeling the part no. sticker off and found it read AKP381, which is the part no. for the series 3 model. Looking now at my invoice it shows ' JS600 supplied as AKP381'. It would appear the same panel will be supplied for Series 1,2 & 3. I took both the series 3 brackets off the sill before fitting it but needed to create a mount for the inertia reel. I considered just welding a nut to a metal plate and putting this on but read somewhere that the heat of welding can distort the threads in the nut. I therefore decided to make one from the bracket which was removed from the new panel. The thinking behind this was that it a had a top quality nut of the right size and was mounted on a thick plate but was a weird shape so cannibalised it and its ok. inside face of series 3 and series 2 inner sills at B post showing some differences. series 3 inertia reel bracket was mounted on top of sill directly above anchor point for fixed end. on series 2 the inertia reel is fixed a few inches behind the fixed end series 3 inertia reel bracket hammered flat and part with captive nut cut out to make new partnew part being measured up against surviving plate from driver's side inner sill taking shapefinished item not too pretty but thicker and with better nut than I could have fabricatedseries 3 front seat outer-rear-leg bracket was removed from sill as I retained original series 2 bracket which differed slightly but was in same location
Last Edit: Feb 14, 2012 1:58:56 GMT by foxy99
foxy99
Last Edit: Feb 14, 2012 3:05:14 GMT by foxy99
foxy99
Last Edit: Feb 16, 2018 18:41:42 GMT by foxy99
More great work there! sometimes you just seam to follow a trail of rot in a car until it runs out of metal! Is the carpet good enough to put back in or are you getting a new one.
foxy99
Thanks Rob. It might sound strange but I still think I was lucky with this car rotwise. I've seen XJs much worse than this but generally speakin...yeah - the rust trail sometimes feels like it will never end The pics above show the amount of panels that can be affected by, what is at first sight, just one rust bubble but if you can cut everything back and repair the 'deepest-in' panel first then work your way back out there's no real reason things can't be fixed. I tried to capture in the pictures the stages of removing each corroded bit. Don't know if it worked really but I basically retained all the bits I cut out then clamped them back where they'd came from for the pictures. For some reason I don't have pics of the reverse journey apart from the new horizontal bit in the last 2 pics - which is actually part of the rear seat pan which sits on top of the inner sill Anyway...back to the log March 2009 - Monday 16th - 'hungover to f**k. long day at work....went to barn to fix welder but gate shut so turned home'
- Wednesday 18th - 'barn at night. sanded faces of outer sill and endcaps. took flywheel off compressor motor and stripped weld torch down to find cause of problem. at home found manuals for welder & compressor but not much help'
- Friday 20th - 'on way to barn stopped in Village for chips and saw Jillianne L****aw out for fag with mini skirt. really questioned myself on arrival at barn: what the f**k am I doing here. sanded top and bottom flanges of inner sill. measured RHS endcap against left using paper. LHS seems bigger so why not file the hole. spent a while trial fitting outer sill etc and also drilled out the 2 failed spots'
- Tuesday 24th - 'took welder home to check it. got email from SIP place re (compressor) pulley'
- Wednesday 25th March - 'paid for pulley by Switch'
- Sunday 29th - 'took welder apart. put welder back together. nothing obvious broke'
- Monday 30th - 'took home compressor belt for examination and torch liner with some spanners. went on web which said all SIP welders curse word. arseholes. found suppliers of belts dead cheap too '
- Tuesday 31st - 'started fitting liner to MIG. still no sign of pulley in post '
April 2009- Thursday 2nd - 'still no pulley '
- Saturday 4th - 'took wheels to barn. also took a few more loads (Jag wheel, Polo wheels, bike racks, old tool box, grey tubs, compressor rad, Imp bonnets & bootlid) had major sweep up. just can't be bothered sorting it all out. why did that welder need to break!!'
- Monday 6th - 'emailed Irene from SIP power place cos pulley still not here'
- Tuesday 21st - 'up to Dundee for welder and back to barn to try it out at night. live torch & no settings plus 'no gas' so not sure what to do with it'
- Thursday 23rd - 'spent afternoon trying (to contact) sellers re Clarke/Sealey welders. guy from Wishaw phoned when I was painting ceiling'
- Friday 24th - 'down to barn to get regulator etc. Wishaw for welder. put Migmate 100 back in boot to take back to barn'
May 2009- Wednesday 6th - 'down to Post Office for belt'
- Thursday 7th - 'fitted belt & pulley to compressor'
- Wednesday 13th - 'sandblasted valance spot welds'
- Thursday 14th - 'loaded car with tools etc after dismantling Jag rear bumper partially'
- Thursday 21st - 'cut all side and bottom spot welds from valance'
- Friday 22nd - 'cut rear valance off'
- Saturday 23rd - '....finished night by removing rivets from exhaust tunnel heat shields & putting them, plus all the stuff from Jag boot, up loft'
- Thursday 28th - 'sandblasted quite alot of RHS valance'
So....basically got nothing done mid March to end of May. From the log it looks like I spent most of my spare time decorating the spare room and doing some jobs in barn like putting loft flooring up in the rafters and I also decanted all the curse word I had in a council lock-up (which had housed my Hillman Imp pick-up for 20 years or so theonlyhillmanimppickup.wordpress.com/the-story-originally-submitted-toprinted-in-impressions-mayjune-96/) as I felt it was time to get the Imp shell to the barn as it had been in exile too long. It was a depressing time as I wasn't getting any work done on the Daimler and the barn was chock full of curse word including a ton of junk I inherited when my friend's Dad died. Boxes of screws and broken tools basically. Also because I couldn't weld I've moved over to sandblasting. This leads to taking the badly corroded rear valance off to clean up the lightly corroded areas behind and see what needs welded.
Last Edit: Feb 15, 2012 23:58:47 GMT by foxy99
