foxy99
Aug 25, 2012 21:25:24 GMT
Thanks dbdb
Am really enjoying this stage of the project. Was a bit hungover today but went down and did the other shocks today
foxy99
Well. No visit to the barn since Saturday (as spent the whole weekend with my very understanding girlfriend) but have got a couple of pics from Saturday to post. Nothing of great import - but interesting to me. I noticed one of the shocks has different collets from the others and when you add that to the issue of the missing collar at the top eye of one of them and the series 1 exhaust downpipes its gets you thinking that the cars may not have been put together as carefully as you'd imagine. The odd shock and older downpipes aren't safety issues but it does give the impression there might have been a bit of parts bin rummaging going on. When I was compressing the springs it got me wondering how much damage they might do should the collets slip off the rather small retaining circlip so I measured a fully relaxed spring against one in situ and there is only about one coils worth of compression. I'm not physicist but I'm thinking they are probably not under extreme load. old springs fitted to new shocks. 3 shocks have the flat collets on RHS of this picsprings in-situ don't seem to be under a lot of compression
foxy99
Last Edit: Sept 1, 2012 2:45:16 GMT by foxy99
foxy99
Sept 10, 2012 1:14:14 GMT
Ok. Its been a week since my last post but I've made some progress in a couple of small areas which strangely I'm fine with. This is the first time I remember that I've felt relaxed about the project. I feel like I've been racing against time and now I can finish it off at a jog Apologies to anyone who is fed up seeing IRS mounts but there are some more picture and no solution but I still feel I've made progress: In the last post I said I'd need to buy 4 more which I could do for about £10 each plus P&P but I saw a single one for sale on Ebay with the later part no. CAC3067 and I thought I'd get that and see if it fitted or not instead of buying 4 more wrong uns. It turns out to be exactly like the 4 newer ones I have and doesn't match my originals. Checking the parts lists I see that the chassis leg part no's ( 12135 & 12136) didn't change from series 1 to series 3. This leaves the cage as the only other component in the equation that could necessitate different positions for the holes on the brackets old and new. The parts list shows the cage part no changed from C.24994 to C.41996 then to CAC2177. I assumed this would've been due to minor differences in the captive nuts for the exhaust hangers or something but it is possible that the holes for the IRS mounts were in slightly different places needed different mounts. Seems a bit unlikely but at the moment it's the only logical conclusion. None of the listings I've seen make mention of old & new mounts either. I doubt 4 old type mounts C.29344 will surface any time soon so it looks like I'm going to have to adapt the ones I have. I'm not keen on just making the holes larger and don't want to drill the cage so it may need to be 16 new ears welded on then drilled to suit The brackets seem to be the same thickness as some 3mm plate I bought recently so it seems the best course of action. solitary mount bought on Ebay for £5 clearly shows late part no. made some time in the 80sbolted up against an original we see a repeat of the issue encountered with the other 4 new ones I haveOn a more positive note but also containing old/new part no. anomalies I got 2 new rear brake discs. There are so many of these for sale at varying prices it's hard to know which ones to buy and I'd noticed that some have 2 large holes in them and some don't. Per the parts lists the early ones C.26779 had the holes and later ones C.46113 didn't. The rusty originals on my car are the later type. Anyway I saw a new pair listed for £20 on Ebay and took the plunge despite them being being the type with the two weird holes in them. On receipt I found they have the exact same casting numbers on them so I'm pretty sure they are interchangeable. original discs have no holes other than bolt holescasting no. on old discs C20326/Ccheap new shop-soiled discs are older typebut have same number cast into themThe next issue was with the lower rear quarter panels. A few posts back I was messing about with lots of new screws etc fitting the passenger side one and was a bit surprised to find the drivers one didn't want to go on at all. This week I spent a bit of time tweaking it and got out the original to check for differences etc. Its fitting pretty well now but the original perhaps fits slightly better and I'm toying with the idea of cutting the new one to use the front flange to repair the original. A job I said I'd do once the car was on the road - not now. More importantly this led to a repair I'd been putting of for ages due to huge 'issues' and, typically, it was done in about an hour and it's pretty much spot on. The issue was that when I repaired the edge of the wing then offered the bumper bar bracket up to weld back on to it there seemed to be a huge gap. With a little clamping and hammering this disappeared along with some other fit problems. Anyway it is done now and I left the barn about midnight on Friday well chuffed newer panel has slots at 2 rear fixing points where original has holes. newer one also has additional wiring(?) hole up top original panel (bottom) a bit flatter here and seems more generously proportionedrear wing bracket separated from wing some time ago for blasting/repair/priming being offered up to check alignmentseems to have grown whilst it was off carsome of the spot weld holes now slightly out of alignment toobut pressed on and plug-welded up nicelythen a little encouragement with a clampand finally back section welded then ground down at top face for tank cover-panel to sit flush on
Last Edit: Sept 10, 2012 2:10:32 GMT by foxy99
foxy99
Sept 11, 2012 1:33:52 GMT
Well. I started on the somewhat unchartered territory of making my new brackets more like my originals. It could be a long process. Cutting shapes out of 3mm plate with a hacksaw blade is quite time consuming. The welding took a few seconds but I spent about 4 hours on this tonight and didn't get a full mount finished. I reckon it will take 5 hours for each one and there is still the positioning and drilling of the new holes to do. Also slightly worried that the metal might harden up a bit and be harder to drill than normal plus the heat could damage the rubber to metal bond. We shall see..... new blank ears cut out of 3mm steel plate and welded to bracketswelds done on both sides for max penetration then roughly ground down There has also been a little development on the fuel pipe saga retrorides.proboards.com/index.cgi?action=display&board=techni&thread=132468&page=2
Last Edit: Sept 11, 2012 2:06:34 GMT by foxy99
Sept 11, 2012 9:35:35 GMT
Keep on keeping on.
Currently: 1974 Beetle - Golf -
Previously: e38 735i, e34 525iSE, 1972 Beetle, 1991 Scirocco Scala, Morris Minor, 1983 Polo Breadvan, 1991 Mazda MX6
foxy99
Sept 17, 2012 1:11:57 GMT
Thanks doctorblack. I spent most of the week on the IRS mounts issue and am not really any further forward despite taking my time and working sensibly. I got the mount with one set of new blank ears and trial fitted it, front and rear on the passenger side, to mark it up for drilling but the punch marks I made were all over the place. Miles out (I was putting the punch through the bolt holes in the chassis leg) Its reminding me of an old Candid Camera sketch where a joiner was trying to put shelves up and they kept moving the outer supports. Except this is for real! Anyway. As this wasn't working I went back to measuring. Comparing old v newer v NOS and couldn't really come up with anything definite but eventually drilled two holes with a 7/16" drill bit in what I thought were the right locations and they were miles out. Really weird. I think a combination of slight play in my drill and not starting with a small drill then working out could be factors but I was amazed at how poor it turned out. Wasn't really worth posting pics of it. Have had the weekend off but will return to it tomorrow. I was toying with the idea of making up dummy chassis legs out of wood to mock up the situation and try again but that's perhaps a bridge too far. I've learned that the solution always comes in the end so just need to keep at it.
foxy99
Sept 19, 2012 1:42:13 GMT
Apologies before I start but I can almost hear the groans. Yes, more IRS-mount ramblings I've spent so much time fiddling with these things and bolting them together (5 tonight - nearly forming a ring) that I'm starting to think I'm to blame and there is no problem with the brackets but I began knocking up a crude dummy chassis leg in wood and despite only getting it half finished it seems to show there is a problem. One thing I did notice the other night, and examined further today, was the pointed end of the brackets: As I was jacking the IRS up and down a few nights ago I noticed the forward edge of the rear mount looked like a little arrow guiding you into position. The rear one is not as pronounced but is still like a point and I found today that if you draw a line from each point through the middle of the bolt hole they form a right angle. There must be a reason for this and it could help me in making new holes, I'm sure. wooden copy on inner chassis leg area. all bolts in place but bottom front one in from other sidefitted to first bracket in-situ on IRSholes out of line at other bracket re-enforces that error present on bracketsI'll be back on it on Thursday as having a night off tomorrow to watch Celtic v Benfica
foxy99
Sept 26, 2012 2:20:28 GMT
Well. I've given up on the wooden dummy chassis legs (for time being) as it wasn't proving to be too accurate since the drill couldn't be guaranteed to go through at right angles and a few degrees off could be quite exaggerated over a thick part so I decided to do some measurements. I measured the distance between the holes in the chassis rails outer and inner and top and bottom so that was 8 measurements (same front and back so only 4 shown below - passenger chassis rail top: 262mm
- ........................bottom: 321mm
- ...driver's chassis rail top: 262mm
I then measured the same datum points with the new mounts bolted to the cage so that was another 8 measurements - passenger side top outer: 260mm
- ......................top inner: 265mm
- ................bottom outer: 319mm
- .................bottom inner: 326mm
- .....driver's side top outer: 262mm
- ......................top inner: 268mm
- ................bottom outer: 320mm
- .................bottom inner: 328mm
Lastly I measured the same points with a pair of old mounts bolted to the cage. This was the set up least likely to be accurate as the metal plates have came away from the rubbers but I tried to put them on as accurately as possible. That's another 4 measurements. Would be 8 if I tried all four old mounts but a pattern was emerging so I didn't bother - driver's side top outer: 263mm
- ...........side top inner: 271mm
- ...........bottom outer: 321mm
- ............bottom inner: 330mm
So I've sorta established that the holes on the chassis legs do not vary from front face (ie outer) to back face (ie inner) but they do on the mounts old and new. If you look at all the lime green which are the outer ones they are all within 1mm or so of each other but the teal measurements which are inner ones are 5, 6, 7 or even 8mm out which equates to a few mm out at each bolt hole which matches the pictures I've been taking. I was kinda hoping the originals wouldn't show this anomaly so I could blame the new ones. Then again if the new ones are the same as the old ones I should be able to force them to fit. Now I'm really confused, new mounts bolted to cageold mounts bolted on too but rubbers have came away from metal partsI decided therefore to leave that issue for another day and started sanding filler on the wheelarch repairs that I put on a while back. They've had two applications of filler but the second didn't harden properly despite using the recommended pea to golfball ratio. I scraped the soft stuff off with a chisel. Put a black guide coat on and found a few hollows so have put some more filler on with extra hardener and the filler has came out rather bright! Hope this isn't a problem. Incidentally the hardener I used is Plastic padding brand and the filler is Isopon P38. Does this matter? Reason I did it is that I have lots of tubs of filler lying around and various tubes of hardener that don't always match. passenger sidedriver's sidedoes mixing brands matter?
Last Edit: Aug 14, 2020 23:57:22 GMT by foxy99
Sept 26, 2012 8:27:22 GMT
With the IRS mounts I think you may be trying too hard to get something millimetre perfect that never will be. The rubber takes up any slight variances with the radius arms being the dimension that makes sure the whole thing stays where its supposed to be. The IRS mounts top and bottom brackets move a lot in relation to each other when the cage weight is hung on them, and also when in compression if the weight of the car is on the suspension. They also twist quite a bit on a quick take off (on a V12 you can wind them up hard enough to tear them). Bolt the mounts to the cage, then getting a friend to help move it about bolt it up to the car. The rubber mounts will be under slight tension, but not enough to worry about. Measure from the radius arm mount to the mount on the wishbone. Any variance here is bad as it will cause a thrust angle. Bear in mind, Jaguar/Daimler built the XJ from hundreds of small panels, and if you look hard enough you will find factory bodges to make things fit... the S2 being the worst of the bunch, with the Coupe taking the honours. Thats why things like the doors are shimmed in all three dimensions, and the striker plates have about a half inch of adjustment. Front wings are a swine to line up again even if you've just taken them off the car and put them back. Remember the story about coachbuilder that asked Jaguar for one that was the same size on both sides? Its not a myth. Stay positive, it will all come together... but maybe not to the tolerances you want just yet. Regards, Rich (ps. Rear brake disc difference - holes vs none? Its due to which diff you have, and how the brake caliper bolts on to it. The holes are for access to the caliper bolts.)
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
foxy99
Sept 26, 2012 10:00:36 GMT
Hi again richw82. That's interesting about the brake discs. I hadn't thought of that.
As for the mounts I'd be happy to force them on but all that was happening before is the threads on the bolts were getting damage due to the tension & levering and I just couldn't get the last couple through.
I'll try again with the cage empty as it'll be even trickier with everything in place as there is all the extra weight to deal with and it's hard to even see the inner bolt holes.
Sept 26, 2012 17:21:54 GMT
Mount them on the cage, but loosely. It should give you enough adjustment to play with. Try to do one bolt in each mount to get it on the car (all the outers) then jacking it carefully should line the others up.
Last one I did was on an XJS a while back, and I'm sure there were shims between the IRS mounts and chassis too.
foxy99
Last Edit: Oct 11, 2012 11:46:44 GMT by foxy99
Oct 10, 2012 16:48:04 GMT
Ive always burned them out in the past, didnt know about the dangers!
Oct 10, 2012 17:34:43 GMT
I did all the bushes on my 110 .... i got a dab hand in cutting them out with a jigsaw with the finest 'metal' blade i could get. Just a bit of caution when cutting thru the outer steel ring where its against the suspension component, couple of blow with hammer and punch, and roberts you mothers brother.
Ref you irs cage issue, i would get a second pair of eyes to have a look, sometimes when you have a job that does you head in, it helps to get another opinion.
foxy99
jimspolicev8sd1 I don't know the facts on the matter but have definitely read something about it. Can't remember if the burnt rubber had to get into a cut or something but I've always steered away from doing it just in case and as optimusprime says once you've done a few manually it gets easier. I first tried it years ago with the swing arm bushes on an old motorcycle (Yamaha AS3). The manual would say remove and replace with some suitably sized sockets. This is always a bit hit and miss because the socket needs to be the exact same size as the outer casing of the bush on the 'push' side and you need one just a little bigger on the other side for it to be pushed into, but not bigger than the diameter of the eye you are pushing it out of. I've never got it to work for me so hacksawing it is. One time I took a swingarm (Yamaha CS3) to a local engineer to get them out with a press and he bent the arms with the pressure, and still couldn't get them out As for a 2nd pair of eyes on the IRS mounts.... no-one I know would be interested I'll get there in the end.......surely!
Last Edit: Oct 11, 2012 2:05:43 GMT by foxy99
foxy99
Ok. There's been a bit of a gap in the proceedings as I was ill Wednesday/Thursday last week, watched Scotland get beat on Friday and spent Saturday & Sunday with the gf...... but I got back on it last night managing to remove the large bush from the other radius arm then took a couple of parts out of the DeoxC bath, rinsed/dried/wire-brushed them and brought home to paint tonight after watching Scotland get beat....again So here are a few of pics of one of the wishbones & the bracket which mounts it to the diff. As you can see the DeoxC pickled them pretty damn clean. I painted last weeks' parts with enamel primer but am treating these ones to some epoxy-mastic paint as I am curious as to what difference in rust-beating skills the two approaches will have. bracket which holds wishbone to diff casing bearings etc removed before dippingclose upThis Rustbusters stuff is expensive. It comes in 2 small tins which you mix in equal proportions then can thin slightly with a special thinner. Rustbuster's Epoxy-Mastic starter kitI used two tablespoons of each component and a drizzle of thinners to do these two parts but could have done it with half the amount. I'll know next time to mix up less.
Last Edit: Oct 17, 2012 19:26:04 GMT by foxy99
foxy99
Well. As I said, i took Tuesday off the project to watch Scotland get beat but got back on it last night and tonight. Last night I got the other wishbone and bracket stripped and degreased and and into the DeoxC bath along with the radius arm which has been in since Monday. Tonight the radius arm and cast bracket were ready for some epoxy mastic after the usual rinsing with water, drying with hot air gun then a quick wire brushing (to get any powdery residue off). The wishbone and another little bit will need another day or so in the bath then I get get back to putting the enamel paint on all the IRS bits. radius arm and wishbone bracket after being in DeoxC bath then rinsed and dried. wishbone in epoxy-mastic at rearDeoxC does great job removing rust but nothing can really get this stuff out seams. not viable to split the radius arm
sonus
Nice job!
You could submerge the arms in Brunox which would eat into the seams of those radius arms
foxy99
Hi sonus. I've never heard of Brunox before but thanks for the heads-up. I just had a look on their site. I'm not sure if anyone's product would get that rust out tho as I've used several good rust removing immersion type fluids and that type of thing is beyond them. Anyway. Back to more IRS related goings-on. Some time ago I put a thread in the 'wanted' section for a driver's side rear caliper retrorides.proboards.com/index.cgi?action=display&board=want&thread=124115&page=1 and I didn't mention it on the main thread as it was a sort of unresolved side issue but I think the issue night now be solved. Basically I stripped down the old calipers successfully (pistons/threaded unions etc) apart from shearing one bleed nipple. This was on the driver's side and I've seen quite a few 2nd hand passenger side ones coming up on Ebay but never a driver's side. Out of desperation I bought another one with a broken nipple in it. This might seem a bit mad but it was only £10 and I figured one of them would come out. Mine is well and truly stuck now below the surface with a thick extractor in it and I've had oxy-acetylene heat on it and everything but it's not budging. The new one however has a lot more of the nipple above the surface and the extractor stuck in it is much thinner so I'm confident this one will come out. It's taken since the start of September for the parcel to actually reach me but I'm not bothered about that now as I'm confident I'll get the nipple out tomorrow night (Monday). my car has early type calipers with different pistons. externally only difference is these machined areas on mounting lugs part is dirty etc but threads for handbrake caliper arm pins are ok. broken bleed nipple is visible hereclose-up the broken extractor is visible inside the nipple
