I just cannot wait to see how this ends, it's looking great so far... I have to say that a Daimler Double Six Vanden Plas (I had to write it in full!!) is one of my dream 70's motors. They just seem to have it all and scream 70's like nothing else (espeically in Coral)... I have always wanted one of these XJ's and will have one one day (I'd even plump for a low-rent XJ 3.4)...!!! P.S. extra points for the whitewalls sir...!!!
***GARAGE CURRENTLY EMPTY***
foxy99
Oct 22, 2012 10:00:54 GMT
Cheers grifterkid. I have to say I hankered after one of the other colours, especially Coral but the old Caramel has grown on me. I saw Goodfellas years ago and towards the end of the film Ray Liotta has a sort of similar colour Cadillac with black vynil roof and I thought it looked good so mine does too sorta thing. My niece saw the car the other day and said 'it's like a toffee colour' so I guess it does what it says on the tin
naki
Oct 22, 2012 11:24:08 GMT
i have heard its easier to extract a broken bleed screw, after the caliper has had a deox-c bath? in theory the bath will remove the corrosion even down between the threads. should help anyhow?
90 Range Rover Vogue SE 3.9 V8 LPG, Lifted & modified for Off Road 93 XJ40 3.2s- awaiting 4.0 Manual conversion 91 XJ40 3.2 Sport Pack MANUAL (project) 93 XJ40 4.0 Sovereign- Daily Driver 91 XJ40 4.0 Manual 92 XJ40 4.0 XJR Manual 93 XJ81 6.0 Daimler Double Six
naki
Oct 22, 2012 11:25:54 GMT
someone did it on the xj40 forum, and says the screw came out very easily after the bath.
foxy99
Hi again naki. I could have tried the DeoxC but for some reason I wanted to attack it with the heavy artillery and it came out. Ironically the caliper is now in the DeoxC - to get it nice and clean for painting. First of all I sandblasted around the thread, which shifted a fair bit of rust then I heated it with oxy-acetylene(I never enjoy using that as it feels very dangerous and seems to cost you £20 every time you light up plus It doesn't seem to actually heat the component that much.... I should perhaps crank up the regulators) which seemed to draw in the WD40 then it was the tried and tested MIG blob on the end which usually works but failed completely on my original caliper. This time it worked but it's hard to say if it was the blasting, heating or MIG that did the trick. Maybe they all helped. Main thing is it is out. I had a go at getting the pistons out but it was nearly 1 am by that time so I'll get back on it on Wednesday (watching the Barcelona - Celtic game on Tuesday ) good old MIG blob was final stage in the task cone end of nipple has slight step in it. over-tightened?
Last Edit: Oct 23, 2012 1:22:32 GMT by foxy99
naki
Oct 23, 2012 10:31:37 GMT
all guns blazing! good effort to to get it out. think i may have given up before then and got a new caliper, so good on you for persevering. i have a couple of calipers with snapped bleed screw too, which i keep thinking i will get around to extracting one day
foxy99
Ok, after a night off watching Celtic have a heroic battle against Barcelona it was back on it tonight. Was quite impressed at how well the new caliper cleaned up in the DeoxC after only a day or so. It wasn't fully submerged so you can see the difference on the part that hasn't been in. I spent the evening getting the pistons out. My approach was a bit crude in welding blobs onto the pistons to give me something to lever and chisel against to loosen them enough to pull out with pliers. I had tried popping them out with the compressor but even at over 100psi they weren't moving. The other night I had welded a bar to the pistons to lever them out but for some reason tonight the bar would not weld. It just kept breaking off so I gave up on it. I also include a picture of the state of the broken bleed nipple on the original caliper. I can't see it ever coming out now. And lastly there's a pic of the exhaust-to-IRS-cage brackets after a couple of days in the DeoxC. ready for paint now new caliper cleaning up well in the DeoxC bath compare against area not yet submergedpistons come out with a bit of encouragementoriginal driver's side rear caliper bleed nipple stuck forever?over-axle exhaust pipe brackets ready for paint
foxy99
Ok....I got nothing done Thursday night as my brother didn't get home till around 11 so was too late realistically to go to the barn but tonight, as I am off work tomorow, I went down till about 2 in the morning. Didn't really get much done but in this cold weather you have to keep going as even small steps are better than none. I basically rinsed, dried, examined & scraped the caliper from the other night then put it back in the bath as there are still a few bits of rust on it then I did the same with the wishbone and that is now ready for paint and I also got my original passenger-side caliper ready to go into the bath. This has not seized fittings and the pistons were taken out some time ago but it has been sitting in limbo whilst I sourced a partner for it. The DeoxC is expensive and loses its strength after a while so I feel it's best to clean the parts up to some extent before you immerse them so the solution is clean for longer. 2nd wishbone finally ready for paintclose up cleanchemical cleaning gets into pits which grinding or mechanical methods would fail tooriginal passenger side caliper ripe for refurbishment now that I have a pair no seized fittings on this onenot obvious in this pic but these early calipers have two grooves in the bore. top one still has remains of rubber boot in it
Last Edit: Oct 27, 2012 3:11:18 GMT by foxy99
foxy99
These aren't the best pictures but I got to the barn on Saturday afternoon and finally got some paint on the newest caliper. The other ones are still in the bath but I think the mixture has lost it's strength and it's a bit of a palaver mixing up new stuff in hot water which I didn't have time to do on Saturday. Also got some epoxy on the other wishbone and a couple of small pieces. Would be nice this week to get them all top coated andhave a set of calipers painted. Next step will be to order pistons, seal kits, bleed nipples and a few bearings and things for the wishbones. I have also seen a set of Series 1 XJ cradle mounts. Seems a bit crazy to buy used mounts but I'm curious as to whether these ones will fit so will prob buy them. ready(?) for paint. this Halfords caliper paint was bought around 10 years ago to do the front calipers some slight traces of rust left behind. no-one will see it painted but not the best pic paint dried quickly in cold temperature. tin says re-coat after 20 minutes or wait 6 weeks if 1st coat dries!! epoxy mastic brushed onto wishbone. not the best finish. chassis parts only I reckon. caliper paint can be seen better in this shot
eurogranada
Nice steady progress.... Good for you! You're working on a beautiful car!
foxy99
Thanks eurogranada. I was looking at your thread the other day. Mk1 Granada also a stunning car but it's dawned on me that, at 42, and still never having totally finished a project I'll never have time to own/rebuils all the cars I like (Humber Imperial, MkIV Zodiac, Mk1 Granada GXL, SD1 VDP, etc etc) so I'm just going to enjoy this one. Which isn't bad really Anyway. Back to the job in hand. Yes, predictably, more caliper pictures. I have just won two more series 1 XJ rear calipers. Having took nearly 2 years to find one I had to buy two I saw on Ebay for £0.99 Ended up paying £10 each but I'm happy with that. I have also nearly got a pair of the series 2 ones. I got one a while back of Ebay for £3.50 and I believe they are interchangeable so I've always got spares. More on that when the time comes but the 2 I dropped in the DeoxC bath on Saturday were somewhat surprisingly ready for paint tonight. They are both passenger side. One early & one late. The late one is the one I got for £3.50 as the seller had listed it as a driver's side one when I was desperate for a driver's side one. When we realised it was the wrong side I thought I'd buy it anyway as it was so cheap. The early one is the manky original I posted some pics of a few days ago. There's not much to say really apart from the very tips of the mounting lugs were not submerged so they haven't been de-rusted and it highlights a point about these chemical dips. You get a very aggressive reaction where the chemical meets metal and air at the same time and it etches a groove into the metal. So, if you are planning to dip large items bit by bit they will end up with deep lines etched into them. original passenger side rear caliper after a couple od days in DeoxC bathacid etch lines at point where part poked above surface of bath are visible herecoat of caliper paint on early NSR caliperand on later NSR unitNB I know it's a big subject but does anyone know what typ of paint this caliper paint is? cellulose, enamel, acrylic, none of the above.....
Last Edit: Oct 30, 2012 2:40:27 GMT by foxy99
foxy99
Last Edit: Nov 2, 2012 3:23:24 GMT by foxy99
foxy99
Last Edit: Nov 7, 2012 3:07:35 GMT by foxy99
naki
its true, rust spots can creep back in, in damp climates like ours, unless the area is fully sealed, straight away. the impossible battle against the brown stuff.
only thing i can think those captive nuts are for, is some sort of fixing for shipping the cars abroad? the xj40 has a shipping loop further forward on the chassis rail. these lugs could be something similar to fix a bracket to. top detailed work you are doing. what blasting set up do you use out of interest, or has it all been discussed already?
i am following this thread with interested, and am still amazed each time you find yet another new rusty area. surely the rust areas must be nearly complete now?
foxy99
Hi again naki. As far as I'm aware that is the last bit of rust on what I'd call the body tub. The blasting was actually done a year ago, this is me just getting round to putting the plate back on. The front wings and doors still need repaired but I don't really count them as part of the main body. The idea about shipping brackets is good. I thought perhaps it was a facility for bolting something like the 'auto gearbox advance transmission rear left carb brake servo boost balancing tool' but whatever they are for at least they're still there. Anyway. The plate is back on and I'm a bit disappointed as my plug welds weren't good. Not exactly sure why but I think the cable on my welder has become frayed and not getting full power through. The bracket won't fall off and the floor is firm again in the pedals area but after all the work and the length of time it's been off the car I would've been much happier if all the welds were great. Two or three look good. The others are a mess plate plug-welded back onto floor panel and bracket back in place good plug on right and rubbish one on left plate finally back on mixed reults with plug welds from below. ones on left look good. those on right are a pointless pile of weld blobs similar results on inboard end of plate Lastly. You asked about rust.... well I've never looked right into the footwell at the transmission tunnel but after taking a picture of the plug welds there I found some crustiness. I'm pretty sure it's superficial, probably caused by soggy carpets from British rain, but I'll have a better look next time. My lamp is about 4` high so to get it into the car the seats need to come out. what's this?
Last Edit: Nov 9, 2012 3:23:20 GMT by foxy99
foxy99
These arrived this morning. Was £38 inc P&P for the pair and they are the early type - with no broken nipples ;D Also have some parts of the handbrake calipers still attached which might be handy as the long screws which hold the arms to the brake caliper bodies are about £20 a set and one of mine broke and the others got a bit bent in my struggle to remove them when the IRS cage was still in-situ. Same with the spreader forks. They are about £20 a pair and one of mine has a broken finger. Rebuilding these calipers can be quite pricey if you have to replace everything so saving on a few of the smaller bits could save you best part of £50 after looking for more than a year for an early driver's side caliper and finding one I now have a spare pair too wonder what they'll be like under the paint
Last Edit: Nov 15, 2012 2:48:13 GMT by foxy99
foxy99
Nov 13, 2012 10:51:21 GMT
Last Edit: Nov 15, 2012 3:30:22 GMT by foxy99
foxy99
Please don't shout at me but here we have more pictures of............................. brake calipers Basically the 1st one I stripped has been in the Deox-C for a day or two and looks about ready for paint. The solution is supposed to be spent when it goes black but it still seems to be doing it's work which is a pleasant surprise and saves me mixing up the other half of the bag I bought recently. It's expensive & I'm poor The second one I stripped had a more or less complete handbrake caliper attached while the first one only had one arm. Everything is in pretty good nick under the silver Hammerite/Smoothrite(?) paint that was on them but I don't think they were an actual pair as this one is almost rust-free and also had black paint under the silver which the other one didn't. Of the 4 early rear calipers I now have these two are in the best condition so would make sense to put the new pistons etc on these ones. my 3rd driver's side early rear caliper turns out to be clean as a whistle under the black and silver paint that was on it bore and boot retaining lip in good order. quite good for £10.50
Last Edit: Nov 15, 2012 2:34:20 GMT by foxy99
Cor, I wish I had half your drive to get on with my own projects right now. Work seems to really be taking it out of me lately so it's heartening to see someone else plugging away and getting stuff done on their car.
foxy99
Thanks Volksangyl. 'drive' sort of sums it up. It's all psychological. As I don't have a car just now I'm using my brother's car at night to go to the barn and that isn't as straightforward as when I had my own wheels.
As I spend Saturday & Sunday with my girlfriend it's imperative I get down Monday to Friday. I finish work at half 7 and walk home by about 8 and my brother usually gets home before 9 so I'm usually on the way down by half 9 which is ok but an example of 'drive' is that he got home very late the other night but I forced my self out to the barn after 11 pm - just to keep up the momentum.
It has been a very mild November tho so I can't complain too much. Friday was good. I got there about 11 and worked away till 3am.
I can relax at the weekend if I've done a minimum of 4 nights. You have to keep driving yourself no matter how cold it is or how good the TV programmes appear. It's also hard when everyone at work is going for a pint on a Friday and you have to give it a miss to go to the barn.
Last Friday was a weird example. My team mates went to the pub early afternoon. I went through my usual routine and got to barn about ten but the electric had run out so I gave up and went to the pub with at 11 but I felt that at least I tried.
Back again tomorrow
