69 Herald 13/60 with Turbo 1600 MX5 engine, Lexus 5 link rear end, 17in wheels,300mm ventilated disc's and subaru 4 pot calipers
Onne
Sounds like a great plan! There is a thread up on the FAQ section on how to post up pictures.
Keep us up to date!
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
Seth
Nice plans! Engine and box fit a treat I know that the seats have been fitted by people over here. Going to be interesting to see how you get on fitting the rest of it.
Yeah, a bit of lateral thinking going on at the moment. I like a challenge. So far I have a link to Picasa up. Still trying to load photos directly onto thread. I'm a blog/thread new boy so advice is welcome.-Finally worked out how to down load photos-old dogs do learn new tricks. ;D The Wheel/tire will tuck up under the arch abit more when the car is at it's proper ride height. I had to cut holes in the garage floor so I could pour some level concrete. Made up 3 x frames to level & clamp chassis at ride height. I welded car Chassis to the frame before cutting the back end out ready for new suspension locations. I planned to use the lexus diff & suspension but will now use the MX5 diff but keep Lexus 5 link set up. I just like the configuration and it works quite well with the chassis. The lexus unit is pretty heavy and the ratio is not quite right. I found a guy who will weld the MX5 (diff end)and Lexus (wheel end) axles together in a two Chuck Lathe. He has welded axles together on a Mini with a twin cam Suzuki engine before and reckons they are strong as the axle itself. I wont have much more than 200HP so it should cope. He's also making me some new alloy front hubs to take the 300mm 350z disc and adaptors to fit the STI 4pot calipiers to MK4 Cortina stubs. Going to make custom A-frames and relocate mounting locations and alter geometry a little. Using eccentric cams from MX front suspension so I can easily adjust camber/caster. It should stop OK I think.
Em
Fuel Injected? Carb Infested!
Dec 12, 2011 13:08:11 GMT
Wow! Sounds like a very cool project! Best of luck with this, will be following very closely!
Dec 12, 2011 13:34:18 GMT
This is right up my street! Brilliant project. Keep the progress, pics and info coming! Welcome to Retro Rides
1974 Skoda S100 tarmac car 1998 BMW 750 daily 1994 Mitsubishi Evo2
Dec 12, 2011 16:33:00 GMT
A Herald engine swop ;D right up my street, book marked
Thanks for the "Ups" on this project guys. I've seen Seth's car before and Em's car is just insane in a nice out there way. So I feel mine is somewhere between the two. I'm pulling the drive train out of the MX over the Xmas break and will have it sitting in place so I can get an idea how to fit the Subaru STI Brake booster & MX heater core around the motor & Gearbox and mount the diff around the suspension which should offer some interesting challenges
Seth
I think it looks a bit like Em's car in those pictures It might be that you could mount the Mazda heater core in a similar position to the engine as it is in the MX5 which would place it somewhere around where the battery is. (and move the battery to the boot?) Don't try and pull the hoses off the pipes at the bulkhead as they are exceptionally thin and made from licorice. Better to cut the hoses. Great project - will enjoy seeing it come together.
Hi Seth, thanks for the advice. So true mate!! I managed to get the hoses off with a bit of twisting & no damage but yeah, very thin metal. I am moving the Battery to the boot (and use MX battery boot mount-another win from donor car) so plan to put the heater fan in the passenger foot well (modify the bulkhead to raise up fan). Heater core should fit above gearbox as per MX5 as the gearbox is quite narrow (but long). Going to weld in a gearbox tunnel so hopefully blend this with the heater core unit & controls. Once I get the engine/gearbox/driveshaft/diff assembly in it should be a lot more clear.
Em
Dec 13, 2011 13:26:14 GMT
I think it looks a bit like Em's car in those pictures Heh heh, looks a bit more complete than mine! Really like the idea of integrating Mazda parts like the heater into the Herald, should create a complete 'package' where everything works together like it was designed to! Yet to think about this kinda stuff on mine, will be watching your progress like a hawk!
Dec 13, 2011 15:40:02 GMT
Wish in some ways l had started with a MX5 donor vehicle in some ways but there you go. Nice to see you are keeping within the herald foot print, but they are bloody narrow had to shorten the sierra track by over 200mm to make mine fit! l used the old heater turned it arond and fitted it where the battery used to be with a polo blower for more omff!
Great project ;D
Dec 13, 2011 16:53:00 GMT
This looks like a whole lot of fun!
Dec 13, 2011 19:16:15 GMT
Dec 14, 2011 19:13:12 GMT
Very interesting project, makes me want to get back onto my Piazza/Simca project (very much the same idea, has been sitting for a couple of years now while I finished uni)
Remade In Australia thereimaginarium.com.au
jbeenz
Looking good dude! Where abouts in NZ are ya?
Cheers mate-in the Waikato dude
tontoe
Enter your message here...
Dec 16, 2011 20:22:11 GMT
I'm liking this building a modified herald my self so will be watching this
life is just a game we play
