remmoc
May 27, 2013 15:32:56 GMT
I always thought my Imps were low until i saw this in N. Wales a few years ago , it truly is in the weeds. No piccys of mine as cluttering up other peoples thread with other peoples cars isnt fair.
![](http://i579.photobucket.com/albums/ss233/UKRUSS1960OLDS/squashed_imp.jpg) Cheers. Russ.
duk
Kinda New
Jun 15, 2013 21:05:17 GMT
Surprisingly Russ that's not the only flatmobile imp, there's a batmobile inspired jet powered imp thing aswell! To be honest at first I had that mentality then 2 years on I'm that used to hitting things it doesn't really bother me unless something stops working ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png) I once drove into the carpark at work (the same carpark I'd driven into for a year!) must have hit a lump at an odd angle and smashed the corner of the gearbox casing, unfortunately it knocked the adjuster bolts out aswell so couldn't select any gears! (the bolt on the front edge of the box is supposed to be flush with the bottom of the box ![>:D](//storage.proboards.com/forum/images/smiley/superangry.png) ![](http://i48.tinypic.com/2133km1.jpg) Yep, that's knackered. . . . ![](http://i49.tinypic.com/k0kec1.jpg) Anywhoo done a little bit more, as some of you will know Imps suffer from the dreaded donut/rotoflex/drive coupling disease and the standard imp items (and even the lotus replacements) are plain rubbish for any low imp. I've been running around with bmw 3 series propershaft couplings on instead which handle the angles far better. Unfortunately not well enough so seen as I'm doing this properly, I cut a hole here and there so I could raise the box so the output/driveshafts are back in their original horizontal position ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Cutty Cutty roughly ![http://image.yogile.com/hkd3w8x5/sbmegx3wwfeegazbkc9bur-large.jpg](http://image.yogile.com/hkd3w8x5/sbmegx3wwfeegazbkc9bur-large.jpg) Wasn't neat enough, cut some more ![http://image.yogile.com/hkd3w8x5/sbmegxcc84w59qumrf5bns-large.jpg](http://image.yogile.com/hkd3w8x5/sbmegxcc84w59qumrf5bns-large.jpg) Engine crossmember no longer fit as the crank pulley got in the way, nay problem just made a hanger instead like the race imps. One advantage of a light engine! ![](http://image.yogile.com/hkd3w8x5/bhgsamvutiuowy7qwb14ur-large.jpg) Covering over the big hole ![](http://image.yogile.com/hkd3w8x5/bhgsamoanitfiglo6h0wfa-large.jpg) Spring cup repaired/reinforced/tied in with new frame, just the other side to tackle next ![B-|](//storage.proboards.com/forum/images/smiley/notamused.png) ![](http://image.yogile.com/hkd3w8x5/bhgsamfxkixllmsvgkbxwm-large.jpg) Pretty much where it's upto at the moment, if/when I remember and have updates I'll bob them on Ash
uncle silvia
Datsun Club UK - Devon & Cornwall Rep
Jun 16, 2013 17:29:03 GMT
Both Imps look awesome and love the ongoing developments just to keep it low ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
1981 KE70 Corolla - 1978 B310 Sunny Coupe - 1977 Pink Clubman Mini Shorty
unitybonez
Blowing Pintos
Like where this is goin, but i still think youre mad ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Sent from my ouiji board.
Jun 17, 2013 20:00:09 GMT
Hey Ash,
Good to see photos of what you have been upto with your Imp. Looking good mate & hope to see it in Perth & have a beer with you . Nice work as expected from you.
Cheers Col.
duk
Kinda New
Jun 22, 2013 18:25:23 GMT
Thanks Col, I daresay the car may still be a bit unfinished on the top half/interior at national. Rolled it onto the other side and poked around to be greeted by this!! At least it's not really much more than I cut off the other side anyway. The sill outer wasn't even welded to the inner it just folded upwards! Just goes to show eh? That was the side that looked strongest when I bought the car so apart from a quick check haven't ever welded it up before. Cutting it a little close for a month and a bit when the engine isn't even put together yet either ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png) ![](http://i44.tinypic.com/de4ndv.jpg)
duk
Kinda New
Aug 20, 2013 23:24:12 GMT
Well I didn't get the car done for the august imp national at perth, sort of glad as I don't have to rush bits now. Anyhow: Floor ribs/plates/captive nuts full shenanigans on ![](http://i41.tinypic.com/24odqvq.jpg) Original footwell floor completely cut out and replaced with solid 3mm steel skid plate, hopefully wont dint like the original! ![](http://i44.tinypic.com/az6na0.jpg) Gearbox cover made/seams and spring tops reinforced with 3mm plate ![](http://i43.tinypic.com/2qsmo35.jpg) Front/Rear suspension back on to check things still fit, slight adjustment to the steering shaft but apart from that all okay, front springs not all the way down otherwise it just sits on the floor ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png) completed the sill and front arch but no pics of this side ![](http://i42.tinypic.com/1znswsz.jpg) Who says an 8j doesn't fit the front of an imp! ![](http://i41.tinypic.com/2ylts9i.jpg) Nothing much else done, not finished the front frame or passenger side front arch yet!
May 23, 2014 17:15:38 GMT
Any more got done on this.
such a good looking imp.
May 23, 2014 23:03:44 GMT
I'm in the process of doing this to a hillman hunter atm. But its gonna be hard to match your imp.... Sick looking car! Pure floor pan scraping, deep dished, wickedness in white ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) love it
duk
Kinda New
Sept 11, 2014 22:39:07 GMT
Holy thread revival! Completely forgot about this thread as I don't visit RR much but found my car via google images and got here again ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) I still have the white Imp, still welding and fabricating most of the bodywork as nothing would fit with standard panels. Bar the roof and doors everything has received some sort of change now! It's taking far longer than expected as I just don't have the time to crack on properly but get bits done every now and then. It's actually still got functional suspension ![8D](//storage.proboards.com/forum/images/smiley/insane.png) albeit limited travel and just sits on coilovers upfront and spring/shocks at the rear. I still fully intend it being static and daily driven once complete ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png) ![](http://i59.tinypic.com/29pozna.jpg) My daily is now another imp which a few people may know (mainly from when I took it to the retro show at santa pod!) I've raised it again at the moment just for general ease and maintenance! Covered 2k in 2 months with little more than a loose alternator dash wire troublewise, who says classics can't be reliable ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Cheers Rob for the pic again! ![](http://i61.tinypic.com/11imzy1.jpg) ![](http://i59.tinypic.com/102ktub.jpg)
Last Edit: Sept 11, 2014 22:41:31 GMT by duk
Sept 11, 2014 22:56:06 GMT
Such cool cars! and slamming them just makes them even cooler!
Sept 12, 2014 9:04:46 GMT
Awesome cars!!! And the colour of the cream imps!!!! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) I've been looking for a colour for my car and that looks suitable
Sept 12, 2014 17:55:05 GMT
Wicked
Sept 13, 2014 14:30:41 GMT
I love it bud.I think I nearly bought your van a while back from the previous owner,I loved the number plate MR G,well that's me!!
duk
Kinda New
Sept 16, 2014 10:06:45 GMT
Cheers guys, the beige one seems to look a different colour in every photo I've taken! Gurns- the van is sat on the drive completely stripped of bits, its sorned but will be off to the scrapyard at some point. After rechecking the iva/sva or whatever the test is called these days it would've been impossible to keep the identity ![:(](//storage.proboards.com/forum/images/smiley/sad.png) I think I may have said it before somewhere but the van was properly rotten everywhere, crossmember welded to the body, cover sills with no inners at all etc!
Sept 16, 2014 14:13:33 GMT
I'm glad to see your cars on here.
I live in Billingly and keep seeing them about.
I be got the B3 Passat wagon
duk
Kinda New
Jun 15, 2016 13:01:10 GMT
Still not done, still not dead Beige one is now black, white one has the last rear wing to re-do as I wasn't happy the first time round, maybe next year who knows!
Jun 15, 2016 14:44:08 GMT
Love the progress on this car....the black one is awesome...love the Flying Tigers element.
JP
