Oct 19, 2011 20:17:57 GMT
I'm struggling to find a set of DB7 alloys for the Jag.
It's a 1992 4.0l XJ40 sovereign.
Does any one know the PCD or what other makes of vehicles wheels will fit?
markbognor
Club RR Member Number: 56
Oct 19, 2011 20:33:04 GMT
Jag is 5x4.75" which is often used on chevys. Which is also very close to BMW 5x120mm (its actually 5x120.6). Possibly close enough to not worry, and certainly wobble boltable.
Last Edit: Oct 19, 2011 20:33:40 GMT by markbognor
micrat
Building a Kanjo styled Cinquecento :)
Oct 19, 2011 21:09:53 GMT
^^^ what he said, i tried a mates e36 bmw alloys on my jag, for sh*ts and giggles, fitted ok as a trial, cant quote on offsets etc but stud pattern was there or thereabouts.
Ran chevy fit on my E28, to confirm.
.6mm is nothing. its like .3mm per stud? Factory tolerance on older wheels will be wider than that, especially with some wear and use. Use the correct nuts to fit the wheels assuming they are right for the stock studs...
Jag pattern is about the most common thing out there
Jaguar/Daimler (except some modern ones) BMW Vauxhall Ventora FE, VX 4/90 and some big Opels Chevrolet Oldsmobile (A, X & some B body) Pontiac except larger wagons etc. Buick A, X body Holden Some GMC light duty vehicles
And others...
And of course any aftermarket wheels designed to fit the above.
Assuming centrebore and offset are OK.
Last Edit: Oct 20, 2011 8:30:02 GMT by akku
Ads 19
My old r19
Oct 20, 2011 17:01:45 GMT
best wheels on a xj40 are the 5 spoke xjr 18" wheels just like a giant freelander rim. however as you say aston fits but look for some Gottis of a early amv8 they are 16" but are gorgeous!
petem
Oct 21, 2011 19:38:57 GMT
Beware of massive tramlining if you fit the 18" XJR rims though. I've got an early XJR with the 17"s and that tramlines like... a tram. All the geometry is perfect on mine (expensively perfect..) and it still likes sitting in ruts on the motorway.
'99 Legnum VR-4 Type S Ralliart
'79 Escort 1300 Sport - long term project.
dugong
One Of Us Will Live To Rue The Day We Met Each Other (Wire : 2008)
Oct 21, 2011 19:53:30 GMT
I've got a set of 15 x 6" KN Geminis in 5 x 120 flavour if you're interested. Had no luck selling them.
Last Edit: Oct 21, 2011 19:58:57 GMT by dugong
dbdb
Oct 21, 2011 22:42:15 GMT
It is BMW E39 alloy wheels which fit the XJ40.
uncle silvia
Datsun Club UK - Devon & Cornwall Rep
Oct 22, 2011 11:14:39 GMT
I used bmw e46 18" reps from eBay with no issues on my old Jaaaaaaaag!!
1981 KE70 Corolla - 1978 B310 Sunny Coupe - 1977 Pink Clubman Mini Shorty
VIP
Oct 22, 2011 11:46:49 GMT
Why haven't you bought these yet?
Oct 22, 2011 17:24:40 GMT
I saw the aston rims and by the time i refurb them and get some good tyres fitted I'm looking at over £1000. It's more than the car cost me in the first place! The deal didn't seem right to me so thats why i passed on them.
Oct 22, 2011 17:43:15 GMT
Thanks to all the great info i've received it has given me so many more options.
Just looking at some MV2's and a set of alpinas
Nov 22, 2021 15:58:10 GMT
Yeah E39 wheels fit XJ40s, but not so much other BMWs because of the centrebore (Jag is 73.8mm centrebore, most BMWs are 72.56mm, E39s are 74.1mm). You can get centrebores machined out if you need to though.
As others have said, 5x120 is within the manufacturing tolerances of 5x120.65 wheels.
I'm a basketweave man myself for XJ40s, and have picked up a set of Japan Racing JR9s which look similar to the 16" optional lattices, just in 17" instead. Not got them fitted yet, but they sat fine. 74.1mm centrebore.
Rich
Club RR Member Number: 160
Yeah E39 wheels fit XJ40s, but not so much other BMWs because of the centrebore (Jag is 73.8mm centrebore, most BMWs are 72.56mm, E39s are 74.1mm). You can get centrebores machined out if you need to though. As others have said, 5x120 is within the manufacturing tolerances of 5x120.65 wheels. I'm a basketweave man myself for XJ40s, and have picked up a set of Japan Racing JR9s which look similar to the 16" optional lattices, just in 17" instead. Not got them fitted yet, but they sat fine. 74.1mm centrebore. Actual thread is from 2011. A tyre retailer has bumped it.
So it is thanks for that!
