totti
Guten Abend! As time goes by..... Recently the Taunus let's me down again with electronic issues.... Did some testing and changed some parts...but:It doesn't work. Changed the ECU for a spare one....but it's broken,too So,this EFI stuff has to go!Back to carb and points! Had a carb and manifold from a donor Granada 2,8.... Needs some love :)Throttle is rusted solid! Today it started as the Express Van is in the paintshop!
Befor... After 30 min.... More to follow.... greet
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
melle
South West
It'll come out in the wash.
You can get very good money for that EFI set-up!
All your cars are cool. Carry on
75swb
Beta Tester
Club RR Member Number: 181
All your cars are cool. Carry on This! And really well written updates too
Excellent write up on a really lovely looking car, Have to agree with most of the previous comments, the "Mk 4 Cortina" was (personally) my least favourite of the series but in 2 door form is a really nice looking car, Loving the work you've done on it and looking forward to seeing future updates on this thread, Nigel
totti
Hi! Thanks for the kind words,much appreciated! I like this car a lot...and i own it for now 21 years.... The 2.8 EFI goes like stink in this car,much fun to drive!The carb will maybe kill some horses...but not much. Also i found a longer geared axle at the german "Hecktrieb" forum...it's a rare 3,45 !At the moment the OEM 3,89 is on tap.... Had a look into the case.... gears look good! Got some paint....ready for use! The carb was in the ultra sonic bath.... Another spare carb,too.Will put together one from the best parts from both.
Throttle shafts got some new bushings.... Greet
totti
Guten Morgen! Find time put together the carb-puzzle.... The cats are curious about what happens on the living room table.... Oscar! A cold beer helps... A very common problem is wear in the throttle segments....so i flipped one of the two...you can see the wear at the tooth on the left Had to grind it a little so it fits well... After setting it workes without play....perfect!And without new parts. After some beers ...ready to go! Greet
So you have a cat for the car.
In the box.
Cats do love a box.
totti
Hi! Fitted the carb.... Made a bracket for the gas cable out of this:A old hinge from a bed.... After some cutting and drilling..... Works fine! This will be the aircleaner....was on my bus years ago...! Or maybe the OEM one? If the Edelbrock is too noisy,maybe... Greet
totti
Apr 30, 2022 20:10:19 GMT
Guten Abend! Finished !! Testdrive!..........was a desaster Very low performance and fire spitting out of the carb....much too lean.Cleaned the jets again,but there is maybe some dirt left... Have to remove the carb again and clean the emulsion tubes.....but the are not simple to get out of the carb body.You have to remove these 2 plugs.... But:rear axle is without any noise and runs sweet. More to follow... Greet
