Sept 24, 2011 23:57:29 GMT
bought a fiesta with the 1.25 zetec in it as a winter hack, all seems fine except within seconds of fireing it up revs rise to 3000 then hunts between 1200 & 3000rpm? ? can't find an airleak so stumped anyone any ideas?
theres more to life than mpg & to much power is just enough.
1.25 zetec huntingChasR
@chasr
Club Retro Rides Member 170
Sept 25, 2011 0:42:41 GMT
I would check two things. Your Idle Control Valve but more likely your Throttle Position Sensor.
Sept 25, 2011 1:36:49 GMT
an engine CANNOT rev without air - check your idle air control valve (IACV)
Sept 25, 2011 21:17:52 GMT
Had this sort of problem with our moms fiesta 1.25 zetec, it felt like the throttle cable was sticking, also misfired at higher revs, simple cleaning of the MAF solved it, it was one of those moments when you can't believe how clever you are
Sept 25, 2011 22:37:59 GMT
hope to check mon, i'm thinking idle air valve to.
bortaf
Sept 26, 2011 13:18:52 GMT
That's usually what it is, dam things allways clog up! if i had a penny for all the ICSV i'd cleaned out,,,,, i'd have £3.67p
R.I.P photobucket
Sept 26, 2011 22:28:12 GMT
@chasr
Sept 27, 2011 8:23:16 GMT
After cleaning the MAF out (or trying it disconnected to see how it runs), I'd still check the TPS . Kas were known for shorting their TPS (contacts also going iffy), the 1.25 injection system is not all that different , causing a number of strange symptoms (silly high revs for a period of time being one).
Sept 27, 2011 23:14:21 GMT
thanks hope to get another go later in week its obviously something silly just acase of finding it?
