Sept 22, 2011 14:32:20 GMT
I have a 1989 austin metro and its been running fine. a few days ago i ran out of fuel on the way to the garage and ever since it has just got a real bad lack of power and keeps cutting out. i have tried the obvious issues by replacing the fuel pump and filter. it ran well after this however yesterday it got really bad again and now struggles to go 40mph.
does anyone know of another fuel filter near the tank or something? really could do with the help.
cheers, Jordan.
Your SigPic is too big.
crazymonkey
ummm....what was I doing again???
Sept 22, 2011 16:23:24 GMT
have you cleaned the carb out? chances are if you ran out of fuel it may have sucked a bit of curse word into the carb.
whoever said dogs were man's best friend....obviously never heard of cable ties
Sept 22, 2011 20:56:34 GMT
As above.
Clean the carb out.
Doubt you have another filter, unless someone has fitted one.
Sept 23, 2011 13:47:52 GMT
rip the carb off, it's a VERY simple thing to play with, and you pretty much can't go wrong with it!
Hell, I've even reused gaskets, and they still work perfectly fine
Sept 28, 2011 22:28:03 GMT
Yeah sorted it now gaethe carb a good clean and gave it a fresh tank of fule runs perfect now no problems:) thanks all:)
