Sept 15, 2011 18:44:35 GMT
Is there any alternative to the electric assist on the column as on Corsa B/C?
I know about electric/hydraulic systems - I just wondered if there was anything out there that was similar to the later Corsa setup?
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
Sept 15, 2011 19:18:57 GMT
I did read somewhere that The MG tf has the same powersteering as the corsa, eBay has some half the price of a corsa one.
Last Edit: Sept 15, 2011 19:22:46 GMT by Maizetina
1961 FORD POPULAR 100e 2.0 dohc Mk1 2dr Ford cortina
Sept 15, 2011 21:03:17 GMT
Fiat Siecento has electric column power steering.
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
Sept 15, 2011 21:06:10 GMT
Like so
Sept 15, 2011 21:53:57 GMT
Loads in my local breaker if you need one...
Koos
Sept 16, 2011 6:17:42 GMT
What's the problem with the Corsa one, out of interest? Too pricey?
I've got a Corsa one with an adjustable trigger module going spare if you're looking for one!
Joe
Sept 16, 2011 9:37:30 GMT
Thanks for all the above guys. Does anyone know if the MGF or Sceicento units have an individual ECU like the Corsa?
Like I said - I was just wondering. Corsa ones do tend to be more expensive that i'd expect.
Turns out one of the guys in the GTM OC has the MGF setup in his Libra.
@joe76. Typical. I drove past Hereford 2 days ago. I'll pm you.
Phil
Sept 16, 2011 18:05:28 GMT
Sept 16, 2011 18:58:16 GMT
Neighbour bought a written off Punto - had been stolen and power steering column removed. No other damage !
Paul H
Sept 17, 2011 13:24:31 GMT
mate at work has just has his other half's punto column in at work to repair an intermittent fault on it
all the web guides state the the relay (2x) contact burn out, but he found a snapped wiring contact and all the relay/pcb connection joints were dry joints
Changed the relays anyway's £18 ebay, but then you have to recalibrate the motor sensors etc using the fiat software and a modified em137 cable
at the end of the day maybe the corsa ones are more reliable
MX5 mk1 - now Turbo'd Austin A35 van Suzuki SJ 16v
Sept 17, 2011 19:46:27 GMT
I think the Corsa one's all jumped up in price when the Escort boys started to fit them to the Mk1&2's....
Sept 18, 2011 17:48:11 GMT
Just checked out teh Corsa parts on ebay! They want more than you would get on the bridge just for the steering set up. Next abandoned Corsa i see is coming with me!
Sept 18, 2011 18:00:47 GMT
seen an mg one on a 205 yesterday
mk2cossie
Club RR Member Number: 77
Sept 19, 2011 19:02:25 GMT
depends if you want to replace a PAS rack to a non PAS quick rack and have some assistance you can just use an electric powered hydraulic pump to feed a conventional PAS rack. saxos/106, merc a class and some of the later astras use them. can be mounted wherever there is space, just need wiring up and the pipes making up for the hydraulic side of things ;D
