bortaf
Sept 4, 2011 13:24:16 GMT
the extra width is why the diesel type 9 has the long input shaft and the deeper B/H and why you need a 4 cyl box for the FWD flywheel. wonder if you could run a normal type 9 with a machined down/petrol/fwd flywheel? Thats what I said, FWD flywheel petrol type 9 (4cylinder one) no machining needed ? but the starter is in a differant place in the petrol B/H and not sure what fits, I have it all mocked up but not got any further with it, I will say that flywhhel makes the RWD pull better on the move but then in a loaded P100 weighing in at ni-on 2.5T you need all teh stored kinetic energy you can get, especialy towing as well, something to think about if towing ?
Last Edit: Sept 4, 2011 13:24:59 GMT by bortaf
R.I.P photobucket
Sept 9, 2011 13:43:40 GMT
Hello i have swopped a diesel crank into my xflow block--so messed around with the sumps of both ---the s.african xflow is not diesel block --its straight xflow .You can bolt up either ones sump to the other ---BUT the end covers are unique to each engine as are sump gaskets --even the diesel all have several differant ones.I think your best way is to just chop the wings off and have the sump welded --easy enough as its a steel one ---all the others are alloy..Which is exactly why i used it on my hybrid to get the big wing and cut the base off to reshape and deepen for just over 5 l oil capacityTHe sieera diesel uses its own one piece gasket nothing like any xflow one.
conrad
Here to fix your cabin.......
Sept 9, 2011 23:34:56 GMT
Right that explains it then I'm using an escort tdi engine 90bhp I think stock. . Intercooled 1.8 td is 90 but beware the normal non intercooled one is still only 75 same as the sierra and escort van
Sept 10, 2011 10:16:19 GMT
Thats the one ive got with th intercooler on it
conrad
Sept 10, 2011 11:03:27 GMT
Yay more powers so!!
Sept 20, 2011 15:19:11 GMT
now the crossflow lead is good as that is what just came out will have to drain it and try mondeo sump may be a pain if I have to do the crank seal as I don't really want to strip much :/ cheers all You manage to sort your sump problem out?
