Rich
Club RR Member Number: 160
hood scoop/power bulgeRich
@foxmcintyre
Club Retro Rides Member 160
Aug 28, 2011 22:24:41 GMT
Last Edit: Aug 28, 2011 22:25:31 GMT by Rich
tsp
Aug 28, 2011 22:53:12 GMT
This is from a Delta Integrale
Aug 28, 2011 22:58:35 GMT
Slam bonnet onto engine. Cut out where the dents are.
I seem to remember this being the method advised most frequently by our own Hardcore, though I may be mistaken ;D
Copey
Aug 28, 2011 23:01:29 GMT
markbognor
Club RR Member Number: 56
hood scoop/power bulgemarkbognor
@markbognor
Club Retro Rides Member 56
Aug 28, 2011 23:02:06 GMT
Another vote for cutting out where clearence is required, then edging with that U shaped protection strip.
Copey
Aug 28, 2011 23:03:19 GMT
yeah, just holes and edging trim would look cool
Aug 28, 2011 23:13:13 GMT
..though only if the turbo was bigger than standard. The one on our AAZ engined Passat looks like a little garden snail
the one I made for the Volvo
Aug 29, 2011 11:25:10 GMT
the one you highlighted is called a camaro z28 hood scoop/cowl Actually it's a Torana SL/R 5000 scoop, which I'm pretty sure were different to the Camaro ones. The scoop was a factory option on the Torana as shown, and they were used on the touring cars. www.ebay.com.au/itm/torana-slr-5000-bonnet-scoop-/130534056264
RobinJI
Aug 29, 2011 12:01:09 GMT
I guess the stealth way of doing it would be to use a 1Z exhaust manifold and an injection petrol inlet manifold. That would hang the turbo downwards, and the inlet would be at the side of the engine instead of over the top.
As for a bulge, how big does it need to be? something like the ones used on the rover 220s would be pretty subtle if it's big enough.
Aug 29, 2011 12:34:54 GMT
How about the scoop off the Kia Sedona?
Rich
@foxmcintyre
Aug 29, 2011 20:06:10 GMT
..though only if the turbo was bigger than standard. The one on our AAZ engined Passat looks like a little garden snail Mine has a K03, but I may be upgrading to a KKK as said friend has that on his engine now but is going bigger again! May just do this for now though.. I guess the stealth way of doing it would be to use a 1Z exhaust manifold and an injection petrol inlet manifold. That would hang the turbo downwards, and the inlet would be at the side of the engine instead of over the top. As for a bulge, how big does it need to be? something like the ones used on the rover 220s would be pretty subtle if it's big enough. Even the petrol inlet would interfere I think. Thought about the 220 bulge but too small. How about the scoop off the Kia Sedona? Spotted that today, will look into it. Either that, or a scooby scoop turned backwards!! ;D
RobinJI
Aug 29, 2011 20:13:09 GMT
Mine has a K03, but I may be upgrading to a KKK as said friend has that on his engine now but is going bigger again! May just do this for now though.. Your K03 is a KKK, KKK is the make K03 is the model. Any idea whick KKK model your looking at getting?
Rich
@foxmcintyre
Aug 29, 2011 20:18:31 GMT
Mine has a K03, but I may be upgrading to a KKK as said friend has that on his engine now but is going bigger again! May just do this for now though.. Your K03 is a KKK, KKK is the make K03 is the model. Any idea whick KKK model your looking at getting? Oh.. err.. its a bigger one than the K03 mine has.. lol! Will take a look tomorrow, gotta finish off fitting the AAZ in mateys!
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
hood scoop/power bulgespiny
@spiny
Club Retro Rides Member 167
Aug 29, 2011 21:03:46 GMT
pug 209 automatics had a 'bulge' , though how many are about these days is the question
conrad
Here to fix your cabin.......
Aug 29, 2011 23:35:04 GMT
..though only if the turbo was bigger than standard. The one on our AAZ engined Passat looks like a little garden snail You'd be better off with a snail towing the car! I have an AAZ engined passat too and the turbo does nothing. Useless tiny thing
Aug 30, 2011 14:49:54 GMT
howabout a "mustang" scoop? Selling mine ;)PM if interested
Rich
@foxmcintyre
Aug 31, 2011 19:56:53 GMT
howabout a "mustang" scoop? Selling mine ;)PM if interested Could work.. PM sent!
Aug 31, 2011 21:08:01 GMT
..though only if the turbo was bigger than standard. The one on our AAZ engined Passat looks like a little garden snail You'd be better off with a snail towing the car! I have an AAZ engined passat too and the turbo does nothing. Useless tiny thing Indeed. Being the 'Umwelt' model, I was under the impression that the turbo is there for a more complete/leaner combustion rather than power. I may be wrong though. All I know is that it is ickle and the car will happily sit at beyond 90 (private roads and all that) but take an approximate eternity to get there.
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
hood scoop/power bulgeToolsnTrack
@overdrive
Club Retro Rides Member 134
4 inch lift with a z28 scoop. (granted its now fitted on a z28...)
