Aug 23, 2011 19:59:43 GMT
Hi
issue 2 with new car:
just wondered if anyone had a idea where to start looking for a issue i have, the battery light on the dash stays on until i accelerate then goes off
but tonight it was flashing dimly on tick over and going off when i pressed the accelerator
i know it will be a simple thing i just over looked
Aug 23, 2011 20:20:33 GMT
Have you checked the tension of the alternator belt as a starting point?
Aug 23, 2011 20:26:10 GMT
will check that in the morning make sure everything is right. there is no noise coming from it so will check it out
Aug 23, 2011 20:30:51 GMT
It won't always make a noise when it's slipping. I don't know if it's a V or or ribbed belt on a B3, but the V belt on my mk1 Fiesta is awful for slipping and keeping the correct tension if it's a bit old..
rodharris83
Day Dreamer...
Club RR Member Number: 4
B3 1.6td Battery Lightrodharris83
@rodharris83
Club Retro Rides Member 4
Aug 25, 2011 12:35:31 GMT
Deffinately sounds alternator related to me. Had a smnilar problem with a Mk2 Golf
bortaf
Aug 25, 2011 13:37:39 GMT
get a meter on the battery i recon the alt is on the way out, mayby brushes or the diode on the way out.
R.I.P photobucket
Sept 21, 2011 19:51:53 GMT
right then
new a;ternatort today £90 fitted it tonight and re tensioned up the belt ect but it all back together and started the car
still had to press the accelerator to turn the battery light off and then on tick over it was still them dimly flickering at me.
when i turn the lights on the light stops flickering
also there is no difference in putting fan and heated windows on
the battery is also fully cvharged according to the battery tester i have
have i wasted £90 on this? where else can i look for this?
cheers
Ben
spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
B3 1.6td Battery Lightspiny
@spiny
Club Retro Rides Member 167
Sept 22, 2011 12:55:12 GMT
check the battery voltage with the meter with the engine off, it should be pretty much exactly 12.0v then run the engine and check the battery voltage with it running, it should be 13ish at idle, and 13-14v with some revs.
that'll rule out the alt at least
bortaf
Sept 22, 2011 13:38:47 GMT
If i tested a battery and it showed 12V i'd class it as goosed (and so would my tester) personly, a battery should sit at 12.5 to 12.8 idealy when off, i'd say you have a duff alt off the shelf IF the battery shows to be healthy ? have a read here www.alternatorparts.com/understanding_alternators.htm
R.I.P photobucket
spiny
Wiki Admin
@spiny
Sept 22, 2011 13:40:55 GMT
If I tested a battery and it showed 12V i'd class it as goosed (and so would my tester) personly, a battery should sit at 12.5 to 12.8 idealy when off, i'd say you have a duff alt off the shelf IF the battery shows to be healthy ? have a read here www.alternatorparts.com/understanding_alternators.htmreally? the battery in my daily shows 12.0 and seems happy enough.
bortaf
Sept 22, 2011 14:33:34 GMT
Yes really, my tester shows 12V as "check battery" a good battery will float at 12.8 ish. edit sorry that sounded a but short didn't it not ment that way
Last Edit: Sept 22, 2011 20:59:18 GMT by bortaf
R.I.P photobucket
