Wow! Had a massive influx of work, I'm getting through it all so bear with me if you are awaiting a proof! Here is just some of the work: BBS 77mm Chrome centre cap: BBS 53mm Black centre with chrome text: Advan RCII Stickers for alloys: I forgot to take a pic of the 'Airbags are for Pussies' sticker, Cariyhunt, can you stick one up here once you've put it on your car? I'm almost out of Chrome vinyl so might struggle to do more chrome bits for a while (plus it's horrible to work with! lol) Thanks all, I'll keep going. Phil.
Last Edit: Aug 21, 2011 8:50:59 GMT by doninphi
Other things I've done: my bootlid vinyl: A friends car for his business, Park Painters: A J flag for my old Mx5 and topper for the rad cap (tho this bubbled in the middle when hot it didnt melt or ruin to my surprise!) Thanks for looking.
Aug 24, 2011 19:55:49 GMT
Mini AK47 silhouettes are now in the post to Lownslow, looked cool. Look forward to seeing them on your car Lownslow!
Aug 24, 2011 22:38:44 GMT
Are you able to make these? Not sure of exact size I will measure up tomorrow but think they are 50-55mm
I will with regards the design but not the colours, black rings yes, but do not have any charcoal.
Unless you changed the design a bit, the background could be silver, gold, pink, White, orange, blue, yellow, red, green... Etc...
Either that or make the whole thing black, and have the circles as holes, and the text black, kind of inverted if you will.
Let me know if you want some ideas makin up as examples for you to get a better idea what I mean.
Thanks Phil.
Aug 25, 2011 10:55:55 GMT
Blavk on silver is great Phil, let me know how much please 4 x 50mm, 4x 55m, 4x60mm as I'm not sure of the exact size till I get em measured. The are for my wheel centre caps on my spitfire btw.
Aug 25, 2011 15:14:27 GMT
PM sent
Aug 25, 2011 16:51:32 GMT
PM sent Replied!
Aug 25, 2011 16:52:14 GMT
Blavk on silver is great Phil, let me know how much please 4 x 50mm, 4x 55m, 4x60mm as I'm not sure of the exact size till I get em measured. The are for my wheel centre caps on my spitfire btw. Pm'd!
I'm getting happy reports from everyone who has received stickers! Woop! I must add these ARE NOT printed, they are vinyl cut, if you have a very complex design or layered colours if a BULK order is required, printed ones may be cheaper. Thats not to say they will be better however, colours on printed may fade, and will not be as vibrant in the first place. Hey ho, just pm me and I'll see what I can do. VAMBO's are almost done, looking very smart I might add!: (the white background will be FAR more apparent when you stick the sticker!)
vambo
Ratrods, Muscle Cars, Pornography and Death Metal!
Sept 5, 2011 21:11:29 GMT
VERY VERY VERY please with those!!! Highly recomended to everyone!
1970 Hillman Avenger 1980 Datsun 240K Skyline 1992 Volvo 240 Torslanda 1992 Toyota Hilux Turbo Bizzle 1995 Volvo 850 T5
can you do stick on number plates? fleabay ones are pretty expensive and limited on the design front...cheers
MaDSeB
Big things in small packages
how much would you be looking for www.madsebcustoms.co.uk in red font, to go across the back window, and two smaller ones for the sides both internally, sides approx 12"x1" and rear 24" by 1.5" (roughly)
can you do stick on number plates? fleabay ones are pretty expensive and limited on the design front...cheers Not considered it as I'd need to copy the original text and get it all measured up to be the right size. Could do yes, but will need to do some research to make it legal.
how much would you be looking for www.madsebcustoms.co.uk in red font, to go across the back window, and two smaller ones for the sides both internally, sides approx 12"x1" and rear 24" by 1.5" (roughly) Dependant upon how many you order it would be a max of £4 for the small and £6 per large 2" one. Pm me if you want some.
NOTICE: I am now back at work and in the throws of organising my department. Therefore massively busy again, so stickers will be on the back burner for me and orders may take a while.
Will still do em, but don't be in a hurry! I'll post up when a holiday is coming up again!
Thanks Phil.
Dec 22, 2011 12:51:42 GMT
Holidays and I've brought the cutter home, let me know if you need anything! Just a quick note, I'm not set up for big runs (costs too much) but more like small numbers and one offs. Ta.
Dec 22, 2011 12:54:29 GMT
can you do stick on number plates? fleabay ones are pretty expensive and limited on the design front...cheers Oops, missed this. I could yes, what's the cheapest you've seen one for me to try to beat? As a guestimate I'd be saying about a tenner each because of the time to lay it out etc... Although with tweaks I might be able to lower that. Also need to get in the right yellow, but fronts will be a doddle.
could you do a down and out sticker of a rear of a nova saloon
Jan 19, 2012 19:20:06 GMT
could you do a down and out sticker of a rear of a nova saloon Yep £3 each delivered, seen any before? Pm me an image if so, if not ill make one up.... Pm me if you're interested...
