pork
iv started this blog for you comments and criticsim to help me along the way I'm not a mechanic and have done everything by reading sites like this  this is the first time iv attempted anything like this so its a 'learn as I build' car any help appreciated heres the car from when I got it  new grill  got some polo 6n coilovers from ebay  had to drill out top hole to fit the hub  welded on washers for strenght   this needed sticking on lathe to fit top mount  drilled oput to 14mm  assembled  fitted  the backs needed a lot more to make them fit. as its my daily driver I had to do the mods to the shocks so the car wasnt off the road for to long. hacksawed old bush off as its to big for the axle mounts and the stut hits the axle  brought a universal bush kit from superflex  needed trimming to fit  welded it all on     fitted   better!   now its to low for passengers, I added some lightness to the car   removed bump strips  this helped  betterer!  wheels needed lick of paint as were really rusty, so sanded primered and painted black till I sort some proper wheels out later   next added some ooommmph cbr600 carbs   made stabilizing vessle for vacuum for the brakes and dizzy  tapped manifold  fitted with free high temp air fittings from work ;D   a quick vid off when I first started it up, still needs setting up properly though
Last Edit: Oct 6, 2011 15:20:20 GMT by pork
crazymonkey
ummm....what was I doing again???
love the sound of it  and those coilovers do the trick pretty damn well.
whoever said dogs were man's best friend....obviously never heard of cable ties
pork
Cheers. Carbs still need a lot off fiddling with. Gotta put stacks on too. Coilivers help loads. Big go kart !
markbognor
Club RR Member Number: 56
Seems to be an influx of new members from the MSC recently. Good stuff. Loving the car Pork keep up the good work!
pork
Hahah. It's a case of 'long time listener, first time caller' with this site.
Got few more things to come, just gotta get paid.
pork
Got this in post today and fitted. Filter king fpr. Done the job just fine, now fuel doesn't curse word out all over the place, which is nice!
Awesome stuff so far, the vacuum tank thing is cool love the fittings on it. Keep up the good work!
pork
Gotta love free stuff!!
Speedle
awesome work dude, if you need to know anything about tuning options and what parts fit k10's let me know. I was actually the first person on MSC to properly fit CBR carbs to a k10 with a custom manifold. Ed Proved the concept I executed it  Also the common MR2 seats I did first Very old picture;  Ended up with twin webber DCNF 36's which were a lot better on power and fuel, coupled with a k11 nismo 4-2-1 made to fit and straight through stainless exhaust;  This was a very tame 0-60 run i did, didn't even push it  but I had it doing 0-60 in around 6.8 seconds. all on a MA10s engine  98bhp
pork
Nice!! Pretty much a beginer when it comes to tuning!
Would like go know what I can do to the head, and cam and where to get the work done. It's a 1.0l 4 speed. Iv read a bit about it being a low comp head but Havnt a clue??!!?
BiAS
Insert witty comment here
Club RR Member Number: 147
Nice work squire! Bike carbs are for winners - Fact  Easiest head option is the 1.2 head with a skim to bring the compression up as it has the biggest ports as standard. Valves are the same size in all the standard heads. 1.2 cam is also higher lift/longer duration. HTH
(car+wheels)-rideheight=WIN
pork
Cheers. Il be on the lookout then for one of those.
BiAS
PS MA10 port  MA12 port  Bike carbs:
pork
Remember seeing your old micra on msc. Very nice!
Speedle
Personally I'd recommend a MA10s Head which is the higher compression ma10 head found on the 5 speeds (that alone is a 5bhp increase on a stock k10) or if you can an MA12s head found on the later 1.2 with all the EGR (Exhaust gas recirculation) curse word on them. the later ma12s heads are much better machined compared to the run of the mill ma12 heads as they have to compensate for the addition of EGR and 2 cats they chucked on the last k10's  it's easy to spot an EGR k10 as they will have a CAT on the manifold and a f**king sh*t ton of usless pipes on them. That said the hitachi carbs on the later k10's is basically a single point injection system and very efficient on fuel Look into finding autograss websites and forums as k10's are used heavily for autograss racing and you can get some great bargains on heads, manifolds and all kinds of uprated parts for the k10
Last Edit: Aug 4, 2011 16:02:52 GMT by Speedle
pork
Nice one. Il have a look about. No old parts you got lying about have you?
Speedle
Aug 16, 2011 13:00:44 GMT |
Nice one. Il have a look about. No old parts you got lying about have you?  Afraid not mate all the best parts I had where on my last k10 when it left
Davey
Diesel all the things
Aug 16, 2011 14:50:57 GMT |
Commented on the micra forum but gonna comment again here, looks really smart and the engine looks like a whole lotta fun.
K11 Micra x3 - Mk3 astra - Seat Marbella - Mk6 Escort estate - B5 Passat - Alfa 156 estate - E36 compact Mk2 MR2 T-bar - E46 328i - Skoda Superb - Fiat seicento - 6n2 Polo - 6n polo 1.6 - Mk1 GS300 EU8 civic type S - MG ZT cdti - R56 MINI Cooper S - Audi A3 8p - Jaguar XF (X250)
valman
Aug 16, 2011 15:00:05 GMT |
awesome k10 dude! is that as low as it goes with the coilovers? as I'm going to be buying a k11 (once insurance pull their finger out and tell me how much more it is to insure) and i know its the same fitting procedure coilover wise on k10 as k11, just wanted to know if they were wound all the way down or not?  also did you have any problems with heat when welding the new bottom mounts onto the rear coilovers? as i know welding when theres still fluid in them can be quite dangerous cheers!
pork
Aug 17, 2011 19:50:24 GMT |
Nah, goes stupid low! Got at least another 3 inches I could drop it by, but I'd never get it off the driveway!! I think the k11 suspension is like a corsa on the back, separate spring and shock. From what Iv read the corsa b fronts go on with very little mods, drill out one whole 2mm I think. All the insides had to come out to weld too
