Jaguar XJ6 3.4.
It had terrible oil pressure, which I ignored, being 20 and skint. I couldn't ignore it after it popped a rod out on the A38 coming up the long hill out of Derby toward Belper! It went with a hell of a bang...
I borrowed an engine crane, spoke to some of my garage contacts and found another car as a donor. It took me about a week to get it all out and the new one back in.
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
tofufi
South West
First time was with help, and was to cure an oil leak from the flywheel seal. First time on my own was to upgrade from the old 1300 engine to a 1600 with twin carbs. Did it in a day, and then drove it 80 miles to uni in the evening. Out with the old: In with the new..
kevfromwales
the conrod's REALLY out the block now!
first time was my old purple ford 100e - 1600 crossflow powered
it suffered from the usual crossflow malady of dissapearing oil pressure, so after progressively smoking out most of north wales, I acquired a freebie 1600 kent from a clubmate's brother's old mk2 escrot rally car - I literally pulled it out of his coalshed with my little brother, dragged it up his driveway, and chucked it into the works D21 pickup truck - no sump, plugs, and various other ancillaries gone me and my mate steve the 'pool plopped it in over a weekend, and after tow starting it with my mates transit, and it lived again - funnily enough steve ended up with the car, so it must have made an impression!
first solo engine swap was pulling the perkins out of the truck, and replacing it with a 2.5 n/a iveco diesel - it was more complicated than ^^ that swap, but no major dramas (bar wiring it up, hanging the prop, chopping the sump...)
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
DutyFreeSaviour
First time was with my dad - Cortina Mk3 cam belt snapped on holiday - luckily near a cousin in Wiltshire - so we swapped it in a few days in his front garden...... Solo - Dolly Sprint - brother (no license etc...) was late for work - I had the dolly at my folks while I worked away. Rad hose was bulging so I knew I had to swap it out - note on dash to notify anyone wanting to move the car on the drive. Dad knew so all OK (so I thought). Bro drove it to work - it overheated - started OK to come home that evening but didn't make it. He had a mate tow it to my folks and left it back in place.... didn't say a word! I only twigged when I took the rad hose off - it was split badly, I chucked the new one on - engine fubar'd. He eventually admitted it...... but by then I'd sourced a replacement and swapped the thing out. Little b*st'rd
This one: To use as a spare for the green one. Still got it if anyone wants it! £50
My gold KP, out with the 1.0 2k, in with a 1.3 4k because it was cheap & out of a grass track race car! Took about 6 hours, but now I know more it's possible in less than 2..
Jul 28, 2011 11:04:58 GMT
My first engine removal was a couple of years ago with my 1500 Beetle. The 1500cc single port engine was still going pretty well but I pulled it out because I had bought a 1600cc twin port. All went well and was achieved over a weekend with one mate's help, giving a very useful improvement in power. On the evening that we got the motor in a very spirited night-time drive through the hills proved that the new engine was indeed working! The best part about installing used engines is that you don't have to run them in, so you can thrash it as soon as you're finished... ;D
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Jul 28, 2011 12:22:07 GMT
Ha ha. My first car engine swap was on a beetle too. A 1972 1300. My first car at age 17. The fabled no3 exhaust valve drop was my reason for the swap. Didn't half rattle !! Bought a 1200 lump for 40 notes and off we went.
jasonj
Jul 28, 2011 12:27:00 GMT
Mini 850 when I was 17 (1989). Knocking big end bearings so took it out and put an 1100 in.
Team Supercharged Opel Ascona 400. 294bhp - 235 lb/ft
Jul 28, 2011 12:34:32 GMT
First complete engine out job was a 1982 Yamaha RD125LC. Water pump/oil pump seal failed causing crank pressure issues which caused the overflow tubes to carry out there job. Unfortunately the previous owner had routed the overflow tubes close to the back tyre causing my first highside. All good fun as I was young and bounced rather well lol. Took the engine out and decided to split the cases and replace all the internal bearings and fit a new clutch. Ran like a charm after that until I gave it to my brother to store and it got nicked!
Jul 28, 2011 12:52:50 GMT
Mine was in 1974 and my father-in-laws Volvo 144E that had broken a piston at 300,000 miles . We didn't have a crane so stripped it down to a short block and lifted out by hand - rope around a fencing post and one on each end ! Rebore and crank grind later the car went on for another 200,000 miles making it 500,000 when sold - still in good condition.
Paul H
Jul 28, 2011 13:01:47 GMT
My dad always goes on about a story he heard about a Volvo engine. A friend of his fathers stripped down the engine in his Volvo and found the tolerances were still tighter after 300k wear than they were for a new contemporary Ford engine. Any truth in that? I don’t know.
aar0sc
Jul 28, 2011 13:40:04 GMT
Doing it now! I am 17 and it's on a '77 Spitfire 1500; I've just got a second hand engine from a scrappy, (DM....ESS - so it's from a 1500 Toledo. Which is ridiculously rare!) and have them both stripped down ready to swap. I'm switching because the old one drinks more oil than petrol and has multiple ominous rattles!
Jul 28, 2011 14:55:48 GMT
My first removal was a 1800cvh from a Sierra, it was my car that got rear ended in traffic. Great learning curve as it was just a simple removal, along with everything else i could sell.
First one back in that had to work was when i took the 1600 x-flow out the fiesta and put the 1100 back in, I had help and supervision but the sence of achevement was high ;D
Jul 28, 2011 15:10:44 GMT
only been the one so far, me and my friend took everything out his mini including the engine: so that we can do this:
Jul 28, 2011 15:22:26 GMT
i help a mate pull the engine out of his mini a few days back so he can paint it :L took us about 9 hours >_< seeing as neither of us had done it before
Nobody dies a virgin, because lifes curse word us ALL
Jul 28, 2011 15:36:21 GMT
Can't remember exactly how old I was, maybe 4 or 5, but I took the engine out of a 50cc bike on my own after I seized it up. First one on a car was a Mk3 Cavalier when I was about 8 or 9. It blew up when we were on holiday on the Gowa. Got recovered home, dad was working and I was on school holidays so I set off with a Haynes manual and got it out. IIRC the only bits my dad did was to undo the driveshaft nuts and then help me lift it out. He then directed me as I rebuilt it and helped me to refit it.
Jul 28, 2011 15:53:02 GMT
first ever one i did was in my Autograss mini last year, because i blew it up....
Jul 28, 2011 17:52:36 GMT
First removal - excluding the Suffolk Punch lawnmower - would be the engine in my Imp. It came out because it was rather tired.
Unfortuanetly, while replacing the gaskets on the replacement engine, I had unknowingly cracked the block. So the coolant leaked straight back out and oevr the driveway.
The second engine removal was of that engine with the cracked block - the original engine went back in again.
bl1300
Jul 28, 2011 18:37:50 GMT
Series 3 straight 6 landy. Reason distributor drive jammed and wrecked the engine. Took the engine out took to a specialist to be rebuilt and it came back burning more oil than the USA! That and bad "read not actually done but still charged" brake repairs was what made me decide never to let anyone else get there hands on my babies!
Current fleet.
