the story...car seemed to struggle starting the past couple days. engine would turn over, but not fire up.
after a few turns of the key, would fire up, but die almost immediately.
try again, it starts and runs fine.
driving along for a bit, the car then loses power. foot off accelerator, engine cuts out.
pull over. same story as when i was starting it at the start of the journey.
called breakdown truck out, couldn't start it due to battery being flat. couldn't really do much else since i was in a lay-by and it was a dual-carriageway (apparently po-po get pissy)
so it's now sitting outside.
going to charge up the batt tomorrow and have a look round.
my dad seems to think it may be a fuel problem? so maybe fuel filter? as it works temperementally
any help, much appreciated as always. Car's a golf with a polo gt engine
Hmm, it's been raining a lot the last few days, hasn't it? tbh, I'd be looking at that fuel pump relay again first!
bl1300
Fuel sounds reasonably likely. As SOC said check the electrics in case they've got wet also a leak in the fuel system, especially when under load will cause similar symptoms.
Last Edit: Jul 8, 2011 20:33:35 GMT by bl1300
Current fleet.
Hmm, it's been raining a lot the last few days, hasn't it? tbh, I'd be looking at that fuel pump relay again first! that's my thoughts. but a relay can't be faulty can it? won't it either work or not work?
Water does funny things to electrics! It's just what I'd be checking first, because it sounds like an electrical fault (intermittant) and you already had trouble there. And no, I've seen faulty relays plenty of times ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
bl1300
Hmm, it's been raining a lot the last few days, hasn't it? tbh, I'd be looking at that fuel pump relay again first! that's my thoughts. but a relay can't be faulty can it? won't it either work or not work? Well it could be that the relay itself is fine, but wet contacts are giving an intermittent electrical contact causing it to play up. If it looks wet down there dry it out water and electrics really don't like each other
Current fleet.
murran
first rule of fault finding...... look at what was last disturbed! if i were you, id go over every part of the conversion and re-do anything you find is dodgy...... if there going to leave relays dangling around where they're guna get wet.... then god only knows what else you might find.
if you want this wiring diagram I printed off autodata then pm me your addy and i'll post it foc.
Last Edit: Jul 8, 2011 21:18:26 GMT by murran
yeh i was planning on redoing the wiring when i hand in my uni project
Tim
Hmm, it's been raining a lot the last few days, hasn't it? tbh, I'd be looking at that fuel pump relay again first! that's my thoughts. but a relay can't be faulty can it? won't it either work or not work? My ol;d civic used to do exactly this...faulty relay...got joints resoldered and it sorted it.
Jul 10, 2011 15:35:32 GMT
was the relay. annoyed since it was new 2 weeks ago! does anyone know what the other relay is for? the one on the right is the fuel pump ![](http://img641.imageshack.us/img641/3550/imag0416i.jpg)
Jul 10, 2011 16:34:51 GMT
take it out and see what has stopped working... ![???](//storage.proboards.com/forum/images/smiley/huh.png) ![???](//storage.proboards.com/forum/images/smiley/huh.png) ![???](//storage.proboards.com/forum/images/smiley/huh.png) ?
![](http://i248.photobucket.com/albums/gg172/kingsmith_2008/bug4sale006.jpg) 1995 mk3 cavalier 1.8i 1972 1200 beetle 2010 1.2 fiat 500 "sometime's" 2000 suzuki gsxr 600 srad
Jul 10, 2011 16:48:15 GMT
53 is normally a horn relay. Also, if your fuel pump relay burnt out, it isn't big enough... looks like a general puropse 15A thing to me, try and find a 30 or a 45A one next time.
Jul 10, 2011 19:36:54 GMT
The other relay in that pic is for the ecu Cheers Mark
Jul 10, 2011 19:48:50 GMT
take it out and see what has stopped working... ![???](//storage.proboards.com/forum/images/smiley/huh.png) ![???](//storage.proboards.com/forum/images/smiley/huh.png) ![???](//storage.proboards.com/forum/images/smiley/huh.png) ? well both of them are the same sort of relay, so I have just switched them for the time being. and everything seems to be working fine 53 is normally a horn relay. Also, if your fuel pump relay burnt out, it isn't big enough... looks like a general puropse 15A thing to me, try and find a 30 or a 45A one next time. the relay was a 40A one, exactly the same as the original (well the one that was in when I got the car) The other relay in that pic is for the ecu Cheers Mark but then surely the engine would not start when there is nothing in it? (or when there's a faulty one)
Jul 10, 2011 20:10:03 GMT
Just to clarify these are the 2 relays that sit next to the Ecu ? If so the ecu one should be a 5 pin relay ! Both should be 40 amp , Mark
Jul 10, 2011 20:38:22 GMT
Hmm. Was it a very cheap relay? I'd take the top off and have a look to see why it failed.
Jul 10, 2011 22:11:51 GMT
Just to clarify these are the 2 relays that sit next to the Ecu ? If so the ecu one should be a 5 pin relay ! Both should be 40 amp , Mark they're on a separate "mini-board" on their own in the scuttle panel, due to it being a conversion. i don't see how it's the ECU relay though. since the car runs without a relay being in the slot
Jul 10, 2011 22:12:19 GMT
Hmm. Was it a very cheap relay? I'd take the top off and have a look to see why it failed. it was just a standard one from eurocarparts
BiAS
Insert witty comment here
Club RR Member Number: 147
Jul 10, 2011 23:00:56 GMT
Mount (cable tie?) them the right way up, ie box at the top, plug at the bottom. Some of our minibus depts products at work were suffering electrical problems and I got sent out to investigate, turns out the folk building them were mounting the relays the other way up because it was easier. If they're the right way up and water gets in them it has a chance of draining out whereas upside down or on their side it corrodes the gubbins that make them work.
(car+wheels)-rideheight=WIN
Jul 10, 2011 23:05:09 GMT
How strange , ive 2 gts outside and have a wiring diagram in front of me , on a standard gt loom they are the fuel pump and ecu relays , the fuel pump one is 4 pin and the ecu one is 5 pin. Mark
