bortaf
If it's a turbo it probably has the epic pump, not the best for reliabilty and it will be fly by wire if it is and will go into LOS when a sensor goes down, ok if it's an external sensor but if it's one in the pump curing the problem can become epic ! try the pedal in case the poinometer has a durty track or burnt out track ? a good dose of switch cleaner might do the trick.
Last Edit: Jul 9, 2011 21:53:42 GMT by bortaf
R.I.P photobucket
...and it will be fly by wire if it is and will go into LOS when a sensor goes down... What's LOS?
Will not rev Deleted
@Deleted
if worst comes to worst I believe you can use the bosch pump on these engines and convert them back to drive with a throttle cable, not sure how you sort the fuelling for when on boost though, a good look on www.fordtransit.org would tell you the information you need..
bortaf
Jul 10, 2011 11:46:55 GMT
...and it will be fly by wire if it is and will go into LOS when a sensor goes down... What's LOS? Limited operations stratergy or limp home mode there's a couple of non leccy bosch pumps you can use to replace the epic but the are pretty rare (only 2 serial coded as far as I know) and cost a bit but cut out all the problems with the epic pump and get you back to good old manual control of the fueling and throttle. As said check the transit forum link out, there a good few threads on there about it with all the numbers you need
Last Edit: Jul 10, 2011 11:50:03 GMT by bortaf
R.I.P photobucket
Jul 10, 2011 11:51:25 GMT
^ so they do actually have a limp mode then? Wow! How do you tell the difference between LOS and normal operation? ;D
Jul 10, 2011 13:16:07 GMT
I used to work at an LDV dealer and whenever we had this we just threw a pedal on.
We even carried them as stock in the recovery vans.
