ThePollitt
Fix up, look... at that car on eBay!
May 25, 2011 14:58:32 GMT
So, it looks like I'm going to go ahead and repair the Merc thanks to a technician mate who's offered up his services (though thanks do go out to all who've offered help). Before I get him down to do the job though, I was wondering if I have to skim the head? Is that something I'll only be able assess once the head is off? The car hasn't got hot or anything, in fact it's been a joy to drive apart from the oil loss. Cost is also a factor too. I'm not looking to cut corners, that said, if I can get away without skimming the head I will. What do you lot think? Chris
Last Edit: May 25, 2011 15:04:51 GMT by ThePollitt
May 25, 2011 15:05:08 GMT
Absolutely, it would be suicidal to do that whole job without it. It doesn't matter if it got hot or not, it can warp just unbolting it from the block. Get it pressure tested too.
Why you always bring me junk!
May 25, 2011 15:14:10 GMT
^ That is a little hardline.... it depends on if it is warped or not - the easy way is just to pull the head and check it. I would factor a skim into the cost from the start, but you might well be surprised that it doesn't need it.
Not all engines are the same so you just have to suck it and see by pulling the head.
- '80 Mk1 Vauxhall Cavalier Saloon, 3.0l 12v... in progress with some special plans ahead - '94 106 Rallye, Endurance Rally Car
May 25, 2011 15:20:41 GMT
I doubt it. The fact is, you crank head bolts up so tight that they will pull any twisted head down flat. Just make sure you torque them up again after a few hundred miles. Unless it's really noticeably not flat I wouldn't bother.
I've never had a second or third headgasket last as long as the original one though. Skimmed or unskimmed. I just don't think they're the same as the ones they put on in the factory.
May 25, 2011 15:21:45 GMT
What jasonb360 said. Check with a straight edge after you pulled it. That's the only way to tell. Everything else is reading tea leaves, so to say In the past I had heads that needed a skim - and some that didn't. Make sure you follow the untightening and tightening sequence as specified from the manufacturer! Should be in the workshop manual. If not, sent me a PM - I have one that covers the M103 straight six engine. [edit] In the factory I think they bolted down all head studs together at the same time, similar as can be seen here. I've always suspected this has something to do with it... But don't know of course: Cheers, Jan
bortaf
May 25, 2011 15:39:25 GMT
Just take it in the machine shop and get them tio check it with a decent straight edge, by decent i meen not some metal ruler you have laying about the place, the machine shop i use pay £140 for straight edge, there are straight edges and there are STRAIGHT edges. Sorry but pulling a warped head straight when torquing it down is plums, if it's warped it needs skimming, the whole head doesn't warp just the lower (hotter) few mm, i've had loads of cars come in that have been rebuilt without a skim and they all needed skimming to stop the HG blowing again, also never had to get a 3rd HG cos i do the job right first time, last engine i rebuilt did another 120 thousand miles more than on the origional HG (minicab). Another tip to keep in mind is never remove an alloy head when hot let it fully cool before removing it or it can warp whilst cooling unclamped, in fact i've seen worse warping due to this than with the usuall overheated/blown gasket, often meaning the once perfectly good head is scrap rather than reusable.
R.I.P photobucket
Do I HAVE to skim the head?HARDCORE
@hardcore
Club Retro Rides Member 190
May 25, 2011 15:42:37 GMT
I'm also in the 'no' camp (unless you can get it done without having to wait long / spend much money) Assuming the M103 is the same / similar head tolerances to a M104 the head bolts are VERY tight! Something like 50lbs then angle tightened 90deg twice (50lbs + 90deg + 90deg, leaving a bit of time in between) so unless it's warped to hell it 'should' pull down flat.. (not forgetting to do them in sequence) J-69 - I bow to your superior knowledge of engines (mine is generally weak) but how do you check after a few hundred miles if they're not torqued down to an absolute value initially?
bortaf
May 25, 2011 15:54:20 GMT
I'm also in the 'no' camp (unless you can get it done without having to wait long / spend much money) Assuming the M103 is the same / similar head tolerances to a M104 the head bolts are VERY tight! Something like 50lbs then angle tightened 90deg twice (50lbs + 90deg + 90deg, leaving a bit of time in between) so unless it's warped to hell it 'should' pull down flat.. (not forgetting to do them in sequence) J-69 - I bow to your superior knowledge of engines (mine is generally weak) but how do you check after a few hundred miles if they're not torqued down to an absolute value initially? Makes no odds how tight they are, i've just done a 1400 16v astra, they have 3 X 90 deg turns after the initial torque down and it came in needing another new HG and the head skimming cos the owner had just replaced the HG and not had it skimmed, it now runs perfect, has stopped using water and putting HCs into the header tank, you simply cannot clamp a warped head straight, at least not in my experiance.
R.I.P photobucket
May 25, 2011 16:44:52 GMT
1) If an engine uses stretch bolts then re-torquing is unneccessary, and could even cause trouble by fatiguing the bolts. Most - not all, but most - engines that specify a certain angle of tightening will use stretch bolts. You shouldn't re use stretch bolts.
2) If an engine uses stretch bolts then the maximum head clamping force is determined by the platis yeild point of the bolts. No point going beyond it, and you might end up snapping the bolts.
3) You can only tell if it's going to need skimming when the head is off. Causes for skimming are either warping, normally due to significant overheating after being run without coolant, or corrosion on the sealing faces caused by coolant without antifreeze. If it's warped then you might get away with it, if the block has warped in the same direction. Unlikely though.
There's a chance that the HG (assuming that that is indeed the problem) has failed simply due to old age - gasket materials can rot. The HG in the previous engine in my Imp failed due to that.
ims
Yaaaaaarrrrrrrrr
May 25, 2011 17:40:18 GMT
have to agree with bortaf 1000%
when youve gone to the costs of gaskets etc is it really worth saving a 30-50quid skim to have to whip the curse word apart again?
1993 Rs2o0o
May 25, 2011 18:38:02 GMT
personally chris for me it depends on the symptoms as to why your changing the HG.....loosing coolant,mixing,overheating,etc.....but if it were mine i'd get it skimmed due to the fact its getting on for 22/23 years old !!..while you're there mate bout time the grinder came out as i'm not feeling the wheelarch / tyre arguement ......lots of love the perm!!
300ce lowrider c220 track car c280 youngtimer S320 ...vip no 4 S430 .. 2 x slk 230 500se , E36 amg E 430 E55 amg Ml 320 C43 amg
May 25, 2011 19:06:33 GMT
M103 engines do use stretch bolts indeed. Mercedes supplies data on maximum stretch/length before a new bolt has to be used. Also, it's very important that you remove the chain tensioner COMPLETELY! from the engine and put it in AFTER the chain has been re-installed/the cam gear is back on the cam. If the tensioner isn't re-loaded correctly on these engines, the chain or cam can snap. If you allready knew that - ignore me please ;D
10mpg
Club RR Member Number: 204
Do I HAVE to skim the head?10mpg
@10mpg
Club Retro Rides Member 204
May 25, 2011 19:25:41 GMT
Why on earth would you skim a head that's flat? That's just madness, a head that's warped beyond tolerance needs skimming one that's flat or within tolerance doesn’t, it's that simple..
Get the head off check it for flatness any decent straight edge will do, you do not need a £140 straight edge, it's nice to have one, I have a proper surface table and a straight edge for such jobs but you can get something perfectly decent for £30-40 that's well up to the job of a head, It' doesn’t have to be perfectly flat either most heads have a 3-4 though tolerance corner to corner, more for straight sixes or V10 or12's..
I've built hundreds of engines from full race screamers to old TD sloggers, and I've never skimmed a head that checked out flat and smooth..
Remember also if you skim the heads there are many other jobs that might need doing, such as shortening pushrods or rasing rocker shafts in hydraulic tappet OHV engines to skimming intakes to match on V8s..
Some manufacturers esp on diesels supply many different thickness head gaskets to compensate for how much has been skimmed off and keep the CR in spec...
Last Edit: May 25, 2011 19:28:13 GMT by 10mpg
Lex
日本車 <3
May 25, 2011 19:36:29 GMT
My Rovers head is warped, had head gasket done and the guy only did a basic skimming of it himself, didn't send it off or anything. Ive been driving the hell out of that car since and never had a problem.
Resto-UKal
Yeah, get the angle grinder out, 9 inch one should do it, skim it ya self. What could go wrong??? ;D
But yeah, check it's flat or get an old school engineering place to check it, they'd prob do it for a cup of tea and some rough shag (tobacco....) then just get it skimmed if it needs it.
Do I HAVE to skim the head?ChasR
@chasr
Club Retro Rides Member 170
I would see what the machine shop has to say on the matter.
Saying 'my friend's has lasted this long' cannot be done since most engine failures will differ from car to car.
For instance, Hoops' brother Landy was said to be fine without a skim, 2 months later, he spent another wad of cash to get the head redone (on a 300TDi). Same for my old Midget 1500 (I got another engine cheaply in the end in a fresher state).
HGs failing differ from car to car too IMO, much down to how the owners have cared for it (not changing coolant etc.).
ThePollitt
Thanks for all the advice guys, it's all being taken on board. I think the plan will be to get it home and then strip it down myself (carefully, of course) and go from there. If it needs a skim, I'll get it done. Then my man can help me put it all back together. personally chris for me it depends on the symptoms as to why your changing the HG.....loosing coolant,mixing,overheating,etc.....but if it were mine i'd get it skimmed due to the fact its getting on for 22/23 years old !!..while you're there mate bout time the grinder came out as i'm not feeling the wheelarch / tyre arguement ......lots of love the perm!! It's still only an assumption that the HG has gone, it's not confirmed. The signs are all there though. *dropping coolant level *oil leak, though oil level doesn't seem to go down (presumably because the coolant is 'topping up' the oil) That said, the oil is still clean as a whistle, no mayo on the cap or dipstick, either. And the coolant (when it was there) was oil free. Weird. It's NEVER overheated though, so I should be a step ahead of a full meltdown. Who knows. All I know is that I'm bloody sick of cars. It's going into a specialist next week for a proper diagnosis (just to be sure) as that won't cost anything. If it is the HG (which I strongly suspect it is) I'll crack on with it. Bloody cars. Chris EDIT: And yes, if it comes out of this ordeal in one piece I'll crack on and get it lowered. Have a pic of a decent W126 for your troubles...
May 27, 2011 19:47:39 GMT
last engine I rebuilt did another 120 thousand miles more than on the origional HG Don't suppose you build 4agze engines do you? That sounds like the reliability I'm after
bortaf
May 28, 2011 11:07:56 GMT
last engine I rebuilt did another 120 thousand miles more than on the origional HG Don't suppose you build 4agze engines do you? That sounds like the reliability I'm after TBH i avoid modern stuff as often as possable ! but i do what comes in from regulars, mainly cab drivers who want a cheap job fitted inbetween the normal jobs whilst they are on holiday ect ;D that 120K took him 14 months , it's still going as well My old rover 420 leaked from the head externaly, when i took to the dealer they said Just whack another 90 deg on the head bolts nearest the leak that'll fix it needless to say i sold it and never owned a modern again ;D 8V iron heads for me from now on Not sure where you are Chris but my local place don't charge for a straight test, it only takes 30 seconds to do so only costs the fuel to get there check waterways for corrosion that's more likely to be a problem if antifreeze hasn't been used and could account for the water loss ? as the waterway basicly becomes larger than the gasket reinforcement and i seeps out usually when the engine is off and the water pressure is higher than the cylinder pressure and you get a steamy ex on a cold start.
R.I.P photobucket
May 28, 2011 11:51:06 GMT
In all honesty if I take a head off for any reason, I will nip it down to the machine shop and get it checked for warping. If it needs it skim it if it doesn't don't but for the sake of a couple of quid don't take the risk. My local machine shop will skim a head for £20 and as some headgaskets sets can cost upwards of £100 you really don't want to be doing the job more than once if you can avoid it.
