simes
Jun 13, 2011 20:52:20 GMT
Keep up the good work. My fathers one has looked pretty much like this for the last 5 years. Although there has been some progress, it has been very slow!
Simes
205Mi16 - 262 cams, Jenvey Throttle Bodies, Emerald managment blah blah...... E91 320D MSport Honda NC30 Vespa 300GTS
Jun 18, 2011 20:03:53 GMT
Ooh lovely, that's an early one. Jealous. Todays progress, axle refurb. They looked to be pretty good, king pins are fine, I have a recent ish invoice for having them sorted, so it was just a case of cleaning them up a bit. Crusty, covered in underseal and grease. A while later, following some aggression with a twist knot wire wheel in the grinder, and a load of degreaser. And front Then spring cans and a few other bits. Started masking up in the oven.. Etch primer on.. Rust preventative primer Then on with the shiny shiny. I wanted to get the chassis painted too, but time got the better of me, it'll be next weekend for that now. The mini doesn't quite know what to make of it all.
1989 Mini MG 1275 ~ 1987 VW Polo ~ 1989 Citroen 2CV ~ 1998 VW T4 ~ 2006 Volvo XC70
Jun 18, 2011 20:05:31 GMT
Nice work. Amazing how quickly they can turn into a pile of bits, though mine was welded to the chassis in places too... Seriously, doesn't look too bad considering how they can go. Good luck with getting it all back together again! Not sure if you're a member of 2CVGB yet, but it's THE club to be in (well, if you like 2CVs!) and we've got a rather spiffing new website. www.2cvgb.co.uk (plug, plug, sorry!) Cheers, it's ok, could be worse! I'm on International 2CV friends, haven't seen the need to join 2CVGB just yet, plus it costs money
Jun 26, 2011 18:03:36 GMT
Update time.. I got sick of giving myself a hernia every time I moved the engine, so I gave it some wheels. You can do it if you B&Q it.. A bit of hacking and welding later.. I was seriously considering mounting the engine on the trolley and fitting the body over it, but someone pointed out that due to the wheel size, the speedo would be out, so I decided not to bother. In other news, Got the chassis cleaned up and repainted. I don't have a before pic, but it was smothered in underseal. Cleaned off the worst of that, and set about removing any flaky or dodgy looking paint. Discovered some funny foamy type rubberised paint on the inside floor section, which made me think it might just be an original Citroen chassis.. This confirmed my suspicions.. I shone a torch inside one of the top holes, and it looked like it had been brush painted INSIDE and waxoyled.. which was a bit mystifying until I realised that someone had cut off the lower belly pan, painted inside, then welded it up again! I goes against the laws of physics for an original chassis to stay this good.. I then soaked the whole thing in Gunk degreaser, to remove any remaining underseal residue Prepped and hung up in le Auvergne. Etched.. Stone chipped the inner floor section.. Primed.. Painted I set my gun to pinpoint setting and squirted some chassis black right up the legs It'll be getting thoroughly drowned in Waxoyl as well, so should last a few years yet. That's all for now, I know you're all on the edge of your seats, but you'll have to wait til next weekend..
luckygti
I need to try harder!
Jun 26, 2011 18:20:19 GMT
Looking good. Need to go back and do this all to my 205 eventually! Looking forward to seeing the body mods
Jun 26, 2011 18:26:23 GMT
Crikey. Very unusual for a late chassis to survive so well. Clearly cutting the bottom off and painting the inside was a good strategy!
75nut
Jun 27, 2011 13:16:16 GMT
Loving it, why wait for next weekend, crack on, we have light evenings and everyfink!!!
90 Alfa 75 3.0 V6 Cloverleaf 79 MGB Roadster 88 Saab 900i Convertible 94 MK1 MX5 1.6 05 Volvo V70
any updates, as i am really feeling the 2cv love
1939 Francis Barnett Powerbike 1971 Honda C90 1992 Mitsubishi Lancer 1.5 GLX 1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van
Jul 17, 2011 10:34:31 GMT
Really enjoying this thread, I think 2CV's are cracking little motors, (I always remember sitting in one years ago in a scrappy's that had striped "deck chair" seats !!) Please keep the updates coming, the standard of workmanship going into it is inspiring, :-)
Aug 28, 2011 21:36:03 GMT
Not updated this for a while, got a little done, not as much as I would have hoped but works been very busy and had a lot of other shiz going down. Started on the body. Got it on it's side Mmm crusty Started stripping old underseal, mud, stonechip, and paint. With the assistance of FIRE Bare metalled the rear section of the underside Found a couple of bits needing a tickle from the metal fairy. Put a bit of etch over it to protect it before I do the welding. Modified the track rod ends to make greasing a bit easier Cleaned up the engine Before Loads of Gunk, and alloy cleaner later.. Also painted up the heat exchangers and other bits n bobs, I'm yet to build it all up.
Aug 28, 2011 21:40:06 GMT
Wanted to get all the rust around the boot floor area sorted today, so started with the worst bit, at the back. Started with this.. First thing was to remove the chassis leg brackets I then made a repair patch.. I then cut out the area I found when I cut away the corroded area, that there were more delights underneath. The two layers under the boot floor needed cutting out, new peices making and welding in before I could go further. Inner repaired Outer repaired I then offered up the repair section, clamped it in place, and tack welded it all round. Then I seam welded it, doing 10mm at a time Plug welded the rear edge The brackets were a bit past thier best so new ones were made And welded on. I took a lot of measurements prior to removing them, to ensure they went back in the right place. Front of the spare wheel well was pitted and holed, so cut it out And new section made and welded in. I cut a swage section from to soon-to-be ex floorpan, and welded it in. There was a hole either side of the well at the rear. Both repaired Primed repaired areas using anti corrosive primer More next week if I have any energy after work. Thanks for reading.
mirafioriman
My next project.......
Aug 28, 2011 23:01:14 GMT
Nice work. This is going to be a lovely 2CV
Not updated this for a while, got a little done, not as much as I would have hoped but works been very busy and had a lot of other shiz going down. Found a couple of bits needing a tickle from the metal fairy. Peter, I'm intrigued how you got this so clean without blasting it, any details on the knotwheel setup? Is it expensive to do/time consuming?
eternaloptimist
Top work!
Aug 29, 2011 21:34:33 GMT
Aug 29, 2011 21:35:50 GMT
Thanks for the encouraging comments, does help with the old enthusiasm..
Aug 29, 2011 23:40:36 GMT
Awesome. Roughly how many wheels did you get through for the back end of the car? I'm guessing you're using air tools right? Still unsure if I should go this root or the soda blast root. Love the attention to detail
I used one and a half, and about 20 80 grit da discs. The wire wheels last for ages.
Sept 4, 2011 16:35:37 GMT
Sept 4, 2011 19:29:41 GMT
Great work, bookmarked now
