Nov 14, 2011 11:24:40 GMT
Strange considering it was running and riding fine before Compession doesnt suddenly dissapear. Unless one of the rings has shattered... In which case id just pull the barrel off and see whats going on in there...
Nov 14, 2011 13:45:01 GMT
Yeah thats probably the next step. It was running fine before yeah, but this bike has never followed logic and it sparked before i had a crash, a crash shouldnt stop it sparking, but it did!
I might take it off tonight and have a look.
jonw
Can open a Mouse with a File
Nov 14, 2011 15:40:18 GMT
It should still run with a slight compression leak. Sounds like too much fuel or oil to me.
Will it run on easystart??
Suzuki SV650R The good Triumph T20 The Bad BMW G650GS The Ugly Matchless G12CSR The Smokey Toyota Hybrid One pint or Two?
Ingredients of this post Spam Drunken Rambling of author Bad spelling Drunken ramblings of inner voices Occasional pointless comments Vile beef trimming they won't even use in stock cubes
Nov 14, 2011 18:52:32 GMT
Before you start pulling it apart whip off the air inlet hose to the carb and almost fully cover the inlet side of the carb with your hand whilst kicking it over - that will make it drag a bit more fuel through and may just get it to start.
Last Edit: Nov 14, 2011 18:55:56 GMT by dodgerover
Nov 14, 2011 22:54:04 GMT
It should still run with a slight compression leak. Sounds like too much fuel or oil to me. Will it run on easystart?? No it doesnt, dodgerover, i'l give that a go when i can!
Before you start pulling it apart whip off the air inlet hose to the carb and almost fully cover the inlet side of the carb with your hand whilst kicking it over - that will make it drag a bit more fuel through and may just get it to start. these things are case inducted... So might be a curse word to do , But if he can get his hand down there while kicking its gotta be worth a go... Does the choke/ enrichment circuit work on the carb?
Nov 15, 2011 18:01:01 GMT
Theres a choke lever, though i havent rigged it up yet. I'll give the bike some attention hopefully tomorrow, ive got a lot on at the moment!
Nov 16, 2011 19:39:15 GMT
^^^ thats really not helping you mate....
Nov 16, 2011 20:23:53 GMT
^^^ thats really not helping you mate.... I was going to say the same thing... I remember my old gp needing full choke to get running , Then half choke till warm.. Get it hooked up. Ya never know....
Nov 17, 2011 17:38:59 GMT
Well i have been pulling it out by hand, but its not making any difference, not even a cough.
jonw
Nov 18, 2011 13:50:57 GMT
Hmmm... obvious questions, but please humor me.
Are the plugs gapped correctly? Do the plugs come out wet after you try to start? Do the plugs smell of petrol? Are the plugs oily? Can you hear an inlet suck? Can you feel a blow from the exhaust? Is the petrol / oil Fresh? If you try to bump it does it fire???
Nov 18, 2011 17:34:05 GMT
Yes
They appear to, yes.
Yes
Are the plugs oily?
don't appear to be
Not sure, i'll have to give that one a look
I get blow when the exhaust is off, ive not tried it with it on. Another thing to try.
Both petrol and oil are fresh.
No clutch rigged up as of yet because I left the cover off for stator work, i'll try that at some point.
I'll give it my full attention on the weekend! i havent had time in the evenings.
Nov 19, 2011 18:55:00 GMT
Righty, Did a tiny bit of work on the bike, in-between building up a drive shaft for the mini. First things first, got the seat on: Much comfier than before, tidies the bike up too. Didnt cost me anything, and including glueing, probably only took me an hour. Not perfect, but pleased overall! Tried to photograph what looked like a compression leak, not sure how clear these photos are: I tried the palm over the carb trick, i did get fuel on my palm, but not much at all, barely misted it, this a sign of something?
Nov 19, 2011 20:02:13 GMT
Hi, those rings look fine, theres obviously a bit of blow by but not enough to stop it running, are you 110% sure that the timing is correct and the woodruff key is in properly?
Nov 19, 2011 20:07:01 GMT
If the woodruff key is the thing that holds the flywheel in place, then yes thats in properly.
Tell you what, i'll time it again tomorrow and get a second opinion from my dad.
Nov 19, 2011 20:47:16 GMT
These are a lovely wee bike, I have I'll break if you need any thing.
Nov 19, 2011 21:19:40 GMT
Just looking at those pictures again it looks very very wet up the exhaust port, has it by any chance filled the crankcase with fuel? If it has it will just soak the plug instantly. Whereabouts are you i'm pretty certain I could have the damn thing going in about an hour....Last thing i can remember having so much trouble with was a worn out YZ 490 which required a tow (2 up to stop the back wheel locking) from a transit to wake from its slumbers
Last Edit: Nov 19, 2011 21:22:00 GMT by dodgerover
Nov 19, 2011 21:36:39 GMT
I agree, piston looks worn but servicable, and bike probably needs a damn good bump starting (mine always did when flooded...)
These are a lovely wee bike, I have I'll break if you need any thing. Is that you saying you're breaking one? Just looking at those pictures again it looks very very wet up the exhaust port, has it by any chance filled the crankcase with fuel? If it has it will just soak the plug instantly. Whereabouts are you i'm pretty certain I could have the damn thing going in about an hour....Last thing I can remember having so much trouble with was a worn out YZ 490 which required a tow (2 up to stop the back wheel locking) from a transit to wake from its slumbers 'damn thing' Ahaha, I think my frustration is spreading. I'm near farnham in surrey, no doubt miles away from you. I hope I'm not being totally useless, my dads had british bikes and never had such a problem so its no doubt flummoxing him too. Tomorrow i'll probably gap the points again, get the clutch installed and see if it will bumpstart!
^^^^^ Yea, have on I am breaking, thes seat, exhaust and back wheel are gone already. So if you need anything I do you a good deal
