Mar 27, 2011 18:15:35 GMT
N reg Volvo 850 estate automatic in smart dark metallic blue. Good bodywork. Runs and drives ok but auto trans makes nasty noise when in reverse. £250 which is no more than scrap value so you can't lose even if it conks out on you. Comfy cloth heated seats. Decent sounds. AC etc PM me by monday evening if interested or its off with its cat , bat and petrol and off to the weighbridge.
Last Edit: Mar 29, 2011 1:37:29 GMT by datman
75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 86 Datsun Vanette van 98 Electric Citroen Berlingo 00 Electric Peugeot Partner 02 Electric Citroen Berlingo 04 Berlingo Multispace petrol 07 Land Rover 130 15 Nissan E-NV200 15 Fiat Ducato
Mar 28, 2011 10:27:56 GMT
Tax? MOT? is it the turbo?
Mar 28, 2011 12:13:57 GMT
mot ran out yesterday tax sent back by people i bought it off. bit of an engine oil leak by look of it, near the top because bulkhead is quite oily non turbo 216,000 miles can't see anything obvious it would fail an MOT on.
Mar 28, 2011 17:57:31 GMT
I've found out what the noise is...
NOT THE GEARBOX! Its the starter motor engaging when put into reverse, which must mean a short between inhibit circuit and starter circuit !
Decided to still see if anyone wants car , although now an easier fix. But I am very tempted to fix this myself now!
Last Edit: Mar 28, 2011 19:59:16 GMT by datman
Update, no response here so spent a few hours investigating the electrical fault.. found it (eventually) two wires chafed together inside plastic harness conduit. Withdrawn from sale as I will probably put this through MOT and use as my daily now.
