Apr 18, 2010 23:16:00 GMT
Ok, I'm just flicking through some old autocar mags (august 1954 to be exact) and reading the write up on the rover P4 60, and it says it has a free wheel unit fitted to the gearbox allowing the option of clutchless gear changes when the engine isn't under load I.e when freewheeling.
Anyone know anything about these units?? How they work? Anyone used one??
Oh, and I now want a rover P4 :-D anyone know what to lookout for on one?
Cheers
coop
10mpg
Club RR Member Number: 204
Rover p4 freewheel?? Explain??10mpg
@10mpg
Club Retro Rides Member 204
Apr 18, 2010 23:35:02 GMT
The freewheel was supposed to be a fuel/transmission saving device, which when engaged basically meant that if the road speed exceeded the engine speed it 'freewheeled' effectively cutting out the drive and allowing the car to run with the ..
it fitted as far as I remember fitted only to the earlier cars, I've been in one but never driven one with one fitted...
early cars had hydro mechanical brakes, again no experience of these but i'm told they were cr4p unless adjusted spot on..
Most of my time spent with them has been with the latter 100's 90's and 110's you either get a 4 pot from the lad rover stable or rovers own 6 pot inlet over exhaust lump which is lovely smooth and completely delicious
they all rot well but are made of awesome quality steel so last very well if looked after and are on a stupidly strong separate chassis so fundamentally they are super strong..
All but the very last 110's have ally doors boot and bonnet so no rust problems there but they still can corrode and collect dents like you wouldn't believe...
Just got a 100 in to restore for a customer, so feeling right at home now...
Last Edit: Apr 18, 2010 23:37:19 GMT by 10mpg
Apr 18, 2010 23:56:57 GMT
Thank you sir.
So what your saying is, go for a 6 pot, check for rot but don't worry about a bit of surface rust as steel is thick and slow rusting, expect some dents on ally pannels an all but mint cars and do a disc converson?
May have to go look on evilbay now, what's a good guide price for a half decent, useble but not mint one?
Just been thinking, I've never had a British car!
british cars are the best
10mpg
@10mpg
all the later ones have discs on the front anyway, you're unlikely to come across an early car to be honest the 75's and the cyclops are hugely collectable..
I love the 6 pots and i'd only run a 6 out of choice, but don't discount the 4 pot land rover powered ones, sure they are coarse compared to the 6 but they are super cheap to run (except mpg obv) and they do lug along alright..
Prices are very variable, but 3-4k should get you a nice slightly scruffy round the edges but mechanically spot on car, rough runners £1500-2k projects in the £100's and minters up to 10k and beyond..
I'd aviod a 105R with the roverdrive automatic as they are a bit problematic and spares are super rare, mind you I've only ever seen one for sale so again your unlikely to find one, crazy 2 speed automatic 'box with automatically engaging overdrive on both gears, giving it the choice (when it felt like it) of 4 gears..
also the front trunnions must be oiled not greased or they jolly pain in the backside up something chronic, and are horrid to sort, check they are not sloppy or seized solid..
Last Edit: Apr 19, 2010 8:54:17 GMT by 10mpg
I had a Saab 95 (V4 version) that had freewheel and loved it. You could change from 4th to 1st at 70mph without the clutch and nothing happened until the car slowed down enough for the gear to match engine speed. Great in traffic. On the Saab the freewheel was a legacy from the earlier 2 stroke engine where it could seize on long downhills due to no lubricating oil in fuel being spashed around.
Paul H
i thought P4 panels were alloy?
or is that just some of the panels?
kevfromwales
the conrod's REALLY out the block now!
just while we're on P4's - does anybody know of any interesting engine swaps for the 4 cylinder ones?? also, apart from the rot, and the front suspension - anything other to look out for (we're not talking about a restoration here!!)
- kev
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Davenger
It's only metal
Club RR Member Number: 140
Rover p4 freewheel?? Explain??Davenger
@dminifreak
Club Retro Rides Member 140
Apr 19, 2010 10:11:09 GMT
Well, Jools Hollands JET 1 replica has a Jag lump in it. No idea how difficult the swap would be though
kevfromwales
Apr 19, 2010 10:20:42 GMT
was thinking more along the lines of bolting directly to the stock rover box? - possibly a shared bellhousing pattern with some later rover lump?
- kfw
Apr 19, 2010 10:31:27 GMT
^^ Kev, cos it's a land-rover 2 1/4 engine, maybe the adapter plates you can get to fit other engines into a landy might work?
(ps, looks like we may have the same plan.... lolz)
Apr 19, 2010 10:34:40 GMT
^^ Yes, Perkins Prima ftw! ;D
miaspa
Apr 19, 2010 10:35:58 GMT
Not sure on what engines swap in but would keep the six pot used to run a 100 as a daily if you can live with 16mpg they are sweet engines. Chops the coils up front, the two I owned had saggy bums so no lowering to the rear suspension needed.
I took the head off a rotten 105s and ran it with twin SU's but mpg really suffered but would happily cruise all day long exceeding motorway speeds.
Happy memomories going out to clubs and gigs easily sitting six in comfort.
Doors, bonnet and boot lid are alloy on all up to 100, 110's and 90's are all steel.
Steering gets really heavy with Radials fitted, parking on a hot day was a real workout.
Found my flashing Pao again.
rob0r
East of England
Club RR Member Number: 104
Rover p4 freewheel?? Explain??rob0r
@rob0r
Club Retro Rides Member 104
Apr 19, 2010 11:59:04 GMT
P4s are a real option for me (having a few sitting around the place), must take a look at them one day... Incase this thread needs photos here's one of my dad's
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
Apr 19, 2010 15:51:16 GMT
The only other cars I know with freewheels is the saab 96/95. Is a bit surreal driving and not have any braking effect from the engine.
But you can change down and up without using the clutch. I think anyway, I ripped my engine and gearbox out to fit something bigger.
EDIT: I am not exactly sure how it worked, there was a wheel in the gearbox which would freewheel one way and lock instantly the other.
It was like a very sophisticated bike hub.
Last Edit: Apr 19, 2010 15:52:46 GMT by trogdor
Sept 14, 2010 18:42:37 GMT
just picked up a p4 (75) and now i know what the free wheel bit is lol........ thinking of changing engine too, not sure about keeping the original box though !! cant seem to find anything about sticking an v8 into one though.......banger tend to go ford v6
loving the dub
Sept 14, 2010 18:43:38 GMT
banger boys i mean't lol
loving the dub
Steve
Making progress in small, easy to handle chunks of awesome
Sept 14, 2010 18:53:33 GMT
In theory, if the gearbox shares the same bellhousing pattern as the Land-Rovers, then you have the option of an adaptor plate for the Rover V8 to bolt on ;D or if your one of those special peeps that likes to be completely different.....a 200TDi out of a Defender would fit
Sept 14, 2010 19:06:43 GMT
Freewheel is odd at first, and downright scary if you're in something with all-drum brakes and no engine braking! I've driven two-stroke Saabs and Wartburgs with Freewheel - as has been mentioned, it was to stop the engine seizing as two-strokes get no oil feed with the throttle shut.
Rover P4s are magnificent. There's one that regularly turns up at Bromley Pageant with a Rover V8 in it.
