Carlos
Mar 17, 2010 19:28:43 GMT
Time for a clearout as I'm running out of space in the garage. Postage available on most things, just ask.
First of all the parts:
Rover V8 twin carb inlet manifold £5 Rover SD1 S1 central locking parts job lot (about 10 items) £5 Rover SD1 early S2 central locking control unit (new) £10 Rover SD1 rear grey leather headrests (VDP?) £10 Rover SD1 switches and misc elec tat and trim - £POA Rover SD1 V8 downpipe, n/s I think (new) £10 Rover SD1 jack £5
Rover V8 EFI Lucas fuel pressure regulator (new) £10 Seat Ibiza / VW Polo gearbox mounts and speedo sensor (085 box) £5 Seat Ibiza wiper switch (with MFA button on end) £3 Volvo 400 front brakes pads (for vented discs) £5 a set (2 sets available)
Vauxhall Carlton / Opel Rekord AP Lockheed 4 stud vented discs - new with some surface rust (part number BG2569) £15 Citroen BX parcel shelf with speakers £5 Mountney steering wheel bosses, tatty - fit something with a 17mm hex shaft (can anyone shed any light on this?) £5 each (2 slightly diff ones availabe) Astrali (or Mountney) steering wheel hub kit for Rover 2000, 2200 or 3500 (new) £10 Vauxhall Nova TD fan £5
JVC Ipod interface unit KS-PD100 (allows you to control ipod from HU) £20 Volvo 300 14" steelie with unused (but old) Pirelli tyre £5 Peugeot 106 front KYB shock (only 1) £5
Fuel pressure gauge £5
Meta immobilisor touch key (new) - bought for my TVR but not needed but will fit other cars with same system (Fiats, Alfas etc) £15
Tools
4 way wheel brace £3 Hub puller £5
Ball joint splitter (almost new) £5
Pair of old ramps - rusty but useable £FREE
Haynes manuals (all £4)
Triumph 2000, 2500 & 2.5 PI Ford Escort (FWD) Vauxhall Carlton (78-86) Rover 2000, 2300 & 2600 Ford Sierra (ohc, petrol) Austin / MG Montego 2.0
Might have some more to add soon as the clearout continues....
Cheers
Last Edit: Nov 1, 2010 22:09:53 GMT by Carlos
Carl -------------------------------- 1992 Peugeot 205 GTi 2.0 16v 2004 Volvo V50 T5 --------------------------------
Mar 17, 2010 20:08:46 GMT
You got any pics of the fuel pressure gauge?
Carlos
Mar 17, 2010 20:42:16 GMT
Here you go:
Mar 17, 2010 23:03:37 GMT
Price on postage for the carlton disks please. Are they front and what diameter are they? Cheers.
1987 Opel manta GT 2.0 16v 1976 Opel manta s project 1985 Opel Rekord E 2.2i 1992 Vauxhall Carlton 2.3TD 1989 Mercury Grand Marquis 2005 Landrover discovery 3
Ads 19
My old r19
Mar 18, 2010 14:09:37 GMT
Love rusty ramps! first dibs! i'll hang on to see what else you discover. go soton way on near weekly basis.
10mpg
Club RR Member Number: 204
Garage clearout10mpg
@10mpg
Club Retro Rides Member 204
Mar 18, 2010 19:00:51 GMT
What head units will the ipod interface work with..??
Carlos
Mar 19, 2010 14:19:11 GMT
Carlton discs are for the front. Will check size and postage when I can get out to the garage over the weekend (or try googling the part number will give you some info). However, someone else has first dibs, so depends whether he takes them or not - will let you know. Ramps are reserved for you w201lorinser. Might add some more stuff over the weekend, but depends on the weather!! Ipod interface info are here: www.jvcmobile.co.uk/press_ipod_ex.phpSome more Googling may reveal a proper list of models but I haven't got time at the mo. It's a good little piece of kit - works great with my other half's nano but the stereo in my new car has a USB port so no need for this any more. Makle sure your ipod is compatible though (info in link above)
Mar 19, 2010 19:23:57 GMT
Whats the hub puller ? slide hammer ? if it is ill be intrested and the joint splitter posted tho ? a few pics would be handy
Carlos
Mar 19, 2010 23:17:50 GMT
Hub puller is sold I'm afraid. Discs and ball joint splitter are reserved for now, but it's not a slide hammer one anyway. Some pics of some of the bits here: photobucket.com/CarlosV8Cheers
Carlos
Mar 22, 2010 13:09:46 GMT
Some more bits after a final sort out:
Rover V8 Lucas vacuum advance unit. probably from an SD1, part no marked on it 54420930 FR1. £5 Rover V8 under-manifold water pipe, bought from Rimmers for my SD1 but didn't fit, could be useful for other V8 applications £5
Rover v8 viscous coupling, part no ERC2849. Looks to be in good nick, but untested, hence price. £10 Rover SD1 spare wheel strap £2
Rover V8 thermostat housing with bypass pipe £5 Battery terminals - 2 pos and 2 neg. £1 each Sytec low pressure clear fuel filter (new, albeit with one out of the 6 adaptors damaged after I stood on it) £5 Beesting aerial £2
Single DIN gauge holder (takes 3 gauges but comes with 2 blanking plates) £2 2 x NGK V Groove spark plugs BPR6E (new) - bought years ago for my XR4x4, only needed 6 but had to buy 8. could save someone else a couple of quid. £2 Suzuki / Toyota fault code reader by Draper (3 wires the plug into diagnostic socket, and then gives an LED readout). Never used. £5 Volvo 850 T5 air mass meter, part no 0280217107. Came as a spare with my car but never tested, hence only £5 Suzuki Swift wheel nuts for steelies (16). £5 Volvo 360 GLT alloy centre cap. £1
LT77 gear stick £15
Rover V8 3.5 flapper ECU from SD1 for refurb only. £5
Richard Grant spoiler, part no FR41. No idea what it's for though. £10
Photobucket link has been updated with pics of most things. If you want any others then just shout.
Cheers
Last Edit: Nov 1, 2010 22:10:59 GMT by Carlos
Ads 19
My old r19
Mar 22, 2010 14:31:49 GMT
Din blanking plate too! when good for you to collect, probs be soton way wedneday sometime
Carlos
Mar 22, 2010 17:16:06 GMT
Ok buddy. I'm home from about 5.30pm, but if you need to collect in the day I can leave the stuff out if I can trust you to stick £2 through the door
hi mate has this gone??
if not ill def take it
Dan
'90 Audi B3 Coupe 2.3 Auto [gone] '92 Audi S4 Avant 2.2 AAN Turbo Auto [gone] '93 Audi 80 Avant 1.9TDi [gone] '96 Audi A4 Avant 2.6 Quattro [gone] '97 VW T4 1.9td LWB [gone] '03 Skoda Octavia 1.9TDi [gone] '05 VW T5 Shuttle LWB 1.9TDi '15 VW Caddy Maxi Kombi 1.6TDi
Carlos
Mar 23, 2010 13:46:11 GMT
Dan, nope still available. Can check postage tonight, but you're also more than welcome to pick it up if you want.
Mar 23, 2010 19:04:56 GMT
can you check post for me
ill def take it
Dan
Carlos
Mar 23, 2010 20:03:47 GMT
PM sent
Carlos
Mar 25, 2010 23:06:46 GMT
Bump
Carlos
BTTT
Carlos
Few more bits to add: Rover V8 flapper air flow meter £25
Rover V8 EFi loom complete with the injector resistor pack (few other EFi parts could also be negotiable if required for an EFI conversion) £25 Both of these were removed from a rusted out rangie last year, but were in good working order.
Citroen BX 16v (or TD) twin fan setup (IIRC this was a handy conversion for a 205 too) £15 Rover SD1 Vitesse alloys (2 or 3 available) £10 each
Last Edit: Nov 1, 2010 22:11:34 GMT by Carlos
Carlos
Apr 21, 2010 18:21:32 GMT
Bump before I start Ebaying
