It's that time of year and Bstardchild has asked me to help organise RR attendance since he's unable to get on here at the moment. If you want to come PM yours and your passengers details as soon as possible, the deadline for cheques to ARRIVE is the 18th of March and details are needed in advance to this. My advice is to get it sorted ASAP to avoid disappointment.
Normally the Retro Rides group go on the Saturday. Please read the following very carefully as I'm just a third party passing on details to Ian! It's a fantastic day, this will be my 3rd or 4th year running.
RAF Marham Charity Track Day Weekend
Most of you should know the drill by now but heres a summary of what it's all about
RAF Marham have again invited PH forum users to a Charity Track Day Weekend on
Saturday 24th and Sunday 25th April 2010.
PH's who want to do both days is not a problem I know several do.
Please note - There will again be dedicated sessions for drifting on the day the ABS group attend (very likely to be Sat) (non drifters as previously can take advantage of the quiet track conditions when the drifters are on track) we hope to make some small changes to ensure the cones stay in place - Filled with concrete should ensure that they are given a wide berth :laughs:
So that's all the stuff you know so now READ BELOW
This is going to seem really fussy or rigid but it's going to have to be - sorry that's just the way it needs to be - if you can't comply with my policies below don't ask to come to the event
So message me with your details points 1 - 9 please be nice and format the information properly with caps and lower case as you would expect if you were co-ordinating the attendance of nearly 200 cars and people. I can just copy and paste it into the database.
Should you chose not to format the data properly you might want to understand the next statement and what effect it can have
You are responsible for the data - if I have to re-type it because it's formatted badly you should know I am dyslexic and what that means.
I'm not responsible for any errors in transposing data that result in your security checks failing and your entry being rejected before the event
(Plus it really creates a shed load of uneccessary work for me..... so just play nice - please)
Example
PH
1. Child, Brian
2. 18 Trackday Road, Northampton NN18 1P
3. 01973 212223
4. 12/01/65 (UK Date format DD/MM/YY please none of this US format stuff)
5. Northampton
6. GB01458965
7. Track - Opel Monza GSE, Tow - BMW 740
8. Track - B5 GSE, Tow - A3 OCD
9. Sat & Sunday
Then follow with additional drivers or passengers as required 1-6 for all please
On reciept of your details I will add your details to the database and respond with an email detiling where to send the cheque or Postal order to Note - PAYMENT by Cheque/Postal Order (in £ sterling please) payable to Service Funds RAF Marham - No cash by post please.
Please do not send cheque just beacuse you've been before and know my address - wait for my email confirming I have your details or it could all go pear shaped.
Once the cheque is sent don't bombard me with emails requesting confirmation that I have received the cheque - if 200 people do that it's a nightmare
I will confirm reciept of the cheque closer to the event with enough time so that if one or two did go missing in the post we can sort it out before I have to pass the payments onto Marham.
RAF Marham would like to invite you to a Charity Track Day Weekend on
The track uses a combination of the airfield's main runway and taxiways
resulting in a track that is around 3 miles long consisting of wide, smooth
tarmac and concrete with lots of safe run offs. There will be approx 1
mile of the main runway in use with many sweeping curves and chicanes along
the taxiways.
The Track Days will run from around 9am to 4:30pm on both days, split into
either 30 or 60-minute sessions depending on numbers of participants. All
the necessary facilities, such as toilets, catering, drinks, marshalling,
medical and fire cover to support the event will be on hand. The
atmosphere and event is relaxed, enjoyable and safe.
All participants who will be going onto the track, either as driver or
passenger, will need a helmet. Race suits are not needed, but natural fibre
clothes with full sleeves and legs are strongly recommended. Cars must be
safe and in road-worthy condition, with normal seat belts as a minimum, and
a fire extinguisher secured safely in the car (a plumbed in system is not
necessary). If the car is driven to the event then it must have valid
insurance, road tax and MOT. For those driving open or soft top cars,
irrespective of whether the hood is raised or lowered, it is strongly
recommended that appropriate extra rollover protection is properly fitted
to the car, unless the car's windscreen structure was specifically designed
to provide such protection.
Please note, due to lack of space, only vehicles driving on the event, and
tow vehicles where applicable, will be allowed access - all passengers must
arrive in participating vehicles.
Note we now have to implement a noise limit to reduce impact on local
residential areas. No unsilenced exhaust systems will be permitted. A
noise limit of 105 dB will be enforced (measured at 0.5m and 45 degree
angle from exhaust exit at 2/3 of max rpm). Cars exceeding this limit will
not be permitted on track.
Sharing a car is permitted (i.e. alternating drivers between sessions) and
drivers are allowed to carry one passenger in the car onto the track, but
passengers must also comply with regard to helmet and clothing and be over
16 years of age. All drivers and passengers will be required to sign a
disclaimer. Spectating is not a possibility unless the individual is
coming to assist someone who is driving - the reason for this is quite
simple - the event insurance premiums and Health & Safety requirements go
through the roof astronomically otherwise, so by restricting it to
participants and assistants, it makes the event manageable, safer, more
relaxed and enjoyable and importantly keeps the cost down to you.
Prices:
Single day - £70 for car and first driver. Additional drivers or
passengers are an additional £10 each.
(e.g. Car and 1 driver, £70; Car and driver plus 1 additional driver or
passenger, £80; etc)
Full weekend pass - £120 for car and first driver for the weekend.
Additional drivers or passengers are an additional £10 each for the
weekend.
(e.g. Car and 1 driver, £120; Car and driver plus 1 additional driver or
passenger, £130; etc)
Payment must be made in advance, cheques need to be made payable to Service
Funds RAF Marham and of course signed and dated. We are expecting a high
number of participants so it is advisable to get your name down early.
Please note cheques may not be cashed until 2-3 weeks after the entry
deadline, please ensure sufficient funds are available in your account.
It is important to note that the track does attract stones. The track will
be swept prior to the event to minimise stones but if you drive directly
behind the car in front along the main straights your car could be subject
to stone chips. If you’re worried about this it is advisable to fit bonnet
protection or drive with this in mind throughout the event.
PLEASE NOTE: RAF Marham is a front line operational air base and as such,
any operational commitments on that weekend would lead to the Track Day
being cancelled. This is however quite unlikely but prior notice will be
given and any money paid up front would be fully reimbursed.
Important:
For security reasons, every person entering the Base including all
passengers must be security vetted in advance. Everyone entering the Base
will be required to present Photo ID. Your forum organiser requires the
following details and payment from drivers and passengers by Thursday 18th
March 2010 to allow time for the security team to check everyone. The
details required are listed below and it must be stressed that they will be
held in the strictest of confidence. Please note that after this date, only
changes to vehicle details will be permitted.
Required details:
PAYMENT by Cheque/Postal Order payable to Service Funds RAF Marham
Forum - ie PH (not a Marham requirement - just to help me manange 3 forums)
Full Name (Surname, Forename) YOUR REAL NAME NOT FORUM ID
Full postal address
Tel No.
Date of Birth
Place of Birth
Passport No. (if possible)
Car make and model (of both track car and tow vehicle if your car is
trailored)
Car registration (of both track car and tow vehicle if your car is
trailored)
Day you are attending: Sat/Sun or both
Don't forget all the money raised goes to some very worthwhile charities
and causes!
the taxiways.
Prices:
weekend.
Important:
Required details:
Full postal address
Tel No.
Date of Birth
Place of Birth
trailored)
trailored)
and causes!
Example
PH
1. Child, Brian
3. 01973 212223
5. Northampton
6. GB01458965
9. Sat & Sunday
