brc76
Jan 21, 2012 22:49:30 GMT
Having a weekend at home playing with the K70 and the splitty, Cleaned up some of the welding I did back in november, then started chipping out all the sound deadening from the drivers side floor to reveal.... Chop chop also cleaned up some of the underside and found a nice hole in the chassis leg to match the one that was on the NS... at least I know the best way to tackle it tomorrow! place your bets on how much metal gets in tomorrow!
al67
Nice to see you back on the project. Looks like you're having a great time with it!! do you have a time scale in mind for the car? al.
Yo, looks like some great works going on here. Any chance of making the pics a bit bigger so we can see better? I think you can set the size prior to uploading in Photobucket, (might not be able to do it retrospectively like)
brc76
Jan 22, 2012 18:04:47 GMT
So managed to replace 3 out of the 4 floor sections today, Pretty happy with the patch to the top of the chassis rail and the replaced sections of the floor that I got done, Just need to do the corner and then that's done, then just a small patch at the front corner of the sill and that corner is done and the wing can go back on. need to tidy up some of the welds but happy days.
Last Edit: Jan 22, 2012 18:05:34 GMT by brc76
brc76
Jan 22, 2012 18:24:42 GMT
Rather than sort out all the links again, I've created a new album with larger pics if anyone would like to see! s736.photobucket.com/albums/xx6/D_R_Payne/LargeK70/and while I'm at it, I will show you the next project... 2 owners, 152000 miles, needs a little patching here and there but an absolute hoot on a wet road. there is also a little helper too.
Last Edit: Jan 22, 2012 18:30:08 GMT by brc76
brc76
Big weekend working on the K70, Finished drivers floor, OS inner wheel arch, OS chassis rail, fitted OS wing back on, cleaned up welds, de-rusted drivers door, POR15, fixed OS doors alignment. Then, I fixed the drivers seat so the cover was attached to the base again. Thought I would make a start on the back "half" of the car. Took out rear seat squab and back. More rust. Yay. Stripped of the bitumen from under the seat and footwells. More rust. Also found that this Is mostly filler. the chunk missing came out in one lump. Mojo lost. retreated indoors.
mirafioriman
My next project.......
It will look better next time and you'll start formulating a cunning repair plan
bullyboy
Let's humppa!
Ouch dude .... There has been some serious filling going on back in the day ;D
Till rust do us apart.
brc76
Forgot to mention the highlight of taking out the rear seat, from 1946!
al67
Every cloud and all that. al.
brc76
Mar 17, 2012 22:57:44 GMT
Spent the day stripping the engine bay and derusting the last bits ready for paint = Good Moved the car around so I could start working on the rear end = Good started looking around the rear properly = BAD
I made a 1 hole 18in long and about 5in wide just by poking a screwdriver in the boot, The rear cross bar is not even remotely savable. This is not mentioning the two dozen or so other holes or crust. My mate decided that it's almost too far gone to save.
I will sleep on it and look again in the morning.
MonzaPhil
Think like a man of action, act like a man of thought
Mar 17, 2012 23:04:23 GMT
Almost too far to save isn't too far to save, press on!
Seriously though, things always look worse before they look better, don't lose heart just approach it in a methodical way and keep sight of how you want it to be.
Good luck!
This is now a clicky linky!
al67
Do things look better this morning?
If I can be of any help, give me a shout.
79cord
Mar 18, 2012 10:21:54 GMT
The corrosion /filler at the back certainly does look gut-wrenching. But it was cheering to see the front progress and sort of back together after to work that had gone on there.
brc76
Mar 18, 2012 21:17:02 GMT
Last Edit: Mar 18, 2012 21:26:24 GMT by brc76
mirafioriman
Mar 18, 2012 22:53:13 GMT
Great work there. It looks much better already with the area cleaned up and the rot cut out. Nice progress
brc76
Mar 19, 2012 22:13:38 GMT
Every time I look at this car I get worried that it's too much, and then get on with it anyway!
I read the thread from the start, and everyone has made such complimentary comments and offered enthusiasm, it would be like the equivalent of a slap in the face for all if I gave up on it.
So I'm going to keep at it. The worst that happens is that I get curse word off with it and leave it be for a few weeks now and then. Now lets get on and order some metal.
MonzaPhil
Mar 19, 2012 22:19:59 GMT
Yay, you know it makes sense.
brc76
Apr 13, 2012 19:50:57 GMT
So made a few panels over the last week, let in some sections and tonight put a lot together. but the biggie was the cross member not too bad! Made a re-enforcement behind and under the towing eye, pretty much replacing what was there from the factory. 70% welded in place, Got some little corrections to make, but clean it up tomorrow. I'm most happy!
al67
Apr 13, 2012 20:15:30 GMT
Nice one!
