Dec 27, 2009 13:34:33 GMT
Hi
i wonder if anyomne can give me any help
I'm not too familiar with a live rear end as ive been used to indipendent stuff
i need to remove the halfshafts from the axel to repalce the seal to diff and generally inspect internals however i can remove shafts!!
ive undone what i think is 4 bolts holding shaft to the axel case in but they will not budge at all!!!, i can find any info on the net and seem to be stuck, ive probably missed something simple.
ive tryed a bar to get them out with no avail, i thought they would just slide out easily?
any help apprieciated
cheers
Dec 27, 2009 13:40:21 GMT
a picture maybe of help, but if you have removed the bolts holding it to the case it may just be seized, have u tried with a chisel in between the 2 surfaces?
1984 gtm coupe 1979 mini clubman estate pickup 1990 mini racing green 1996 mini sprite 1992 maestro 500 van 1995 fiat cinquecento
B-8-D
down to one car!!
Dec 27, 2009 13:40:29 GMT
slidehammer.... si
The Doctor
Club RR Member Number: 48
Dec 27, 2009 13:41:46 GMT
I think a slide hammer is your answer: if english halfshafts are the same as the Japanese I have, they can be very stuck, even if they only are held in by the bearing on the halfshaft //edit: to slow, beaten to it
Last Edit: Dec 27, 2009 13:42:25 GMT by The Doctor
v8ian
Dec 27, 2009 14:03:04 GMT
Slide hammer is what you need, in the past I have used ad old drum reversed and hit with a FBH, normally ends up damaging the drum, you will find the bearings will partially rusted in its seat, it is feasable the shaft has possibly never been out of the axle.
Last Edit: Dec 27, 2009 14:05:55 GMT by v8ian
nizzer
Dec 27, 2009 16:42:00 GMT
ive used an old steel wheel before and belted the back of that to get a shaft out. just bear in mind your gonna damage whatever your gonna hit!
ezzysi
Dec 27, 2009 16:47:48 GMT
As above ^^ worked for me a few times on live ford axles.
1991 Mk2 Golf Gti 8v 2005 Passat tdi (daily) 1971 Mk1 Escort 2004 Touran (her's)
Dec 27, 2009 17:01:01 GMT
thanks lads, ill give the advice given a try tommorow, hopefully comes out but probably have to get a rebuild kit for it if the bearings are stuck to the shaft, cant be a bad thing though
thanks for the help
