Aug 28, 2009 12:12:54 GMT
You can add a turbo to the standard engine by tapping the block etc for the oil feeds/ drain or just pick up a later 940 block and drop that in.
Your right that the turbo will end the strut tower but there are a few people who had modified manifolds to fit. I think the downpipe is also quite fun in order to make fit.
As for engine management, megasquirt is available with the volvos and quite a bit of support exists for it on turbobricks. Thats what I am running and it keeps the car going with 25-30 psi from the turbo.
Aug 28, 2009 14:21:33 GMT
Got it booked in for an MOT tomorrow! It's obviously going to fail, but I'm hoping that the damage isnt too bad
Aug 29, 2009 21:02:46 GMT
The MOT went suprisingly well! Obviously it failed, but not on much...................
Two small patches of welding, one at the front and one at the rear.
Old exhaust rubber doesn't suport the exhaust.
Windscreen FUBAR.
Front washer jets don't work.
Should be MOT'd by Friday ;D hopefully in time for the meet at Bruces! Fingerscrossed!
mym
Aug 29, 2009 21:08:07 GMT
judging by last accident in the sierra, i suggest you don't weld the diff in this
Aug 30, 2009 12:01:33 GMT
judging by last accident in the sierra, I suggest you don't weld the diff in this Where is the fun in that! Plus the accident was caused by me being a tit, not the welder. Welded diff are fine for road use, and I will have not hesitation getting the 360 diff welded.
conrad
Here to fix your cabin.......
Aug 30, 2009 13:12:13 GMT
judging by last accident in the sierra, I suggest you don't weld the diff in this Where is the fun in that! Plus the accident was caused by me being a tit, not the welder. Welded diff are fine for road use, and I will have not hesitation getting the 360 diff welded. that they are, just not fun for multi story car parks! or trying to do a 3 point turn in front of the police. oops. anyway... nice volvo
Aug 30, 2009 13:39:02 GMT
Should be MOT'd by Friday ;D hopefully in time for the meet at Bruces! Fingerscrossed! Bloody right! No fingers crossed about it, you WILL get the work done, you WILL get it through the MOT and you WILL be there next Sat ;D I've been out today buying food, charcoal, fire lighters & biscuits so your absence will be a fail of epic proportions
