DutyFreeSaviour
THIS is the one you were talking about...... good to see it getting back together. Will be a nippy little motor once out there again. Looking forward to seeing the Derby next too
Good luck
John
berendd
Aug 21, 2009 11:08:00 GMT
I'll make the links in my sig work..
derby is in a project topic somewhere..
Aug 21, 2009 11:45:45 GMT
Nice work there Berend, engine is looking good.
Current: 1983 Volkswagen 1200 Mexico 2021 Kia Niro Hybrid ----- Former: 1989 Volkswagen Jetta 1990 Volkswagen Golf Madison 1996 Volkswagen Golf Wagon Happy Hour 2006 Fiat Panda 100HP 2006 Toyota Avensis Wagon
berendd
Sept 11, 2009 11:14:43 GMT
the engine runs.. but the carb floods..
still some work to do but down to some details..
berendd
Sept 22, 2009 7:55:47 GMT
The original Carb was FUBARred, so tried to find a replacement or parts.. well that turned out to be impossible, even the dealer couldn't help me on parts for that Denso carb.. seems to be rarer than hen's teeth.. So went to pick up a carb at a friend of mine which seemed to fit to a monopoint injection manifold I had laying around. Take a Suzuki Swift MK2 monopoint injection manifold and a Weber carb off a Volvo 340 Length is about right, width is a bit off Made the holes a bit bigger to give room to the throttle valves to open, and drilled and tapped to m8 holes. When at RR08 we obviously did a trip to Halfords and I took a box of (INBUS) Hex bolts.. they fitted perfectly.. exact fit INBUS bolts Have to make a gasket for the carb, but I have some paper laying around.. And errm Mark succes cleaning your shed, there's Alumuminium everywhere.. Maybe I add some Alu tonight when flowing the manifold.. hopefully the swift will run with this carb and it's on the road again after 3 months or so.. So I can continue my projects.. Although I heard Mark about getting a nearly free Hanomag camper that obviously needed somewhere to be stored dry.. and had some work ;D
Siert
Sept 22, 2009 10:17:13 GMT
Hanomag camper = seriously cool!!!
berendd
Sept 22, 2009 20:02:48 GMT
berendd
Sept 28, 2009 7:48:17 GMT
and it runs... things left to do connect fuel pump properly get some decent hose clamps weld a bracket for the throttle cable sort out a choke cable (was auto choke) find and modify air filter adjust co level mount bumper and hood drive it again after 5 months
DutyFreeSaviour
Sept 28, 2009 15:12:51 GMT
Good to see you guys this weekend. Glad it's all up n firing on all cylinders. Will be visiting more often now you've got proper tea Good luck fella.
berendd
Sept 28, 2009 15:16:01 GMT
thomas has got the tea...
I've got some chinish jasmin tea though, need to sort a watercooker and coffee machine and a place to put them..
you're allways welcome!
Hi,
I got side skirt from mk1 Gti if you want them. I broke my car up and some of the parts are left over.
Let me know if you would like to take it.
Cheers Atchi
Building roof chopped, screen raked '68 Mini with G13B 1.3 16v Gti engine with LSD, Yamaha R1 carbs. As well as mk1 Suzuki Swift Gti AWD with a turbo. Drives PHEV Outlander but wishing my mk1 Swift Gti or mk2 CRX Vt were still with me!
berendd
did a longer testrun yesterday...
suddenly a rattle started and didn't stop..
rattle came from the bell housing so I guess the clutch has come off...
engine out is planned for satrday
berendd
Oct 12, 2009 12:01:03 GMT
forgot to tighten the flywheel bolts so ripped the engine out last saturday, fixed it, used some locktite and put it back together... @sunday I made a bracket for the throttle cable and now I can do the vroomm vrooom's from behind the steering wheel.. today I ordered a new choke cable.. to do: make bracket for throttle cablereplace front bumper, headlight and bonnet mount choke cable wire fuel pump bodge air filter on wash and drive
berendd
to do: make bracket for throttle cablereplace front bumper, headlight and bonnet mount choke cable wire fuel pumpbodge air filter on wash and drive tried to set it up, cos it only runs with the choke applied, but no succes on that platform.. maybe drive it to a weber specialist when I'm ready and do a decent setup/jetting on the carb.
berendd
unfortunately I couldn't get it to run properly with the weber carb, so decided to make some bike carbs fit.. had a flange made by a mate with a plasma cutter, now to source some pipe and weld together... ain't gonna make rr10 :-(
PhoenixCapri
West Midlands
Club RR Member Number: 91
1986 Suzuki Swift GSPhoenixCapri
@phoenixescort
Club Retro Rides Member 91
Jul 14, 2010 11:39:29 GMT
Shame it was a nice conversion with the weber too (though looks like you broke through into a chamber which could be giving you a big air leak depending what that little brass fitting is connected to - unless its meant to have a hole there?) Did you re-jet it for your engine? If not I bet it was running MASSIVELY rich - hence why it'd be impossible to get it to run, I'd be surprised if it didn't flood itself at idle. It'd probably need different float settings too, and you're fuel pump may well have been delivering the wrong amount of fuel. Plus those carbs do like to have a plastic spacer between the carb and manifold, it prvents fuel evapouration and reduces the rick of foaming - I'd give it another go to be honest, should only take a couple of hours to get it running right. It'll be a damn sight easier to get it going right on that than bike carbs! Good luck with it
berendd
Jul 21, 2010 14:32:49 GMT
I guess indeed it was running very rich, but I haven't got a clue where to get different jets..
As this carb was from a volvo 340 1.4 which is quite tame, I guessed it would work on a 1300cc suzuki engine which has a wilder cam as the volvo..
Also I wanted to put it on bike carbs anyway in the near future.
