May 13, 2010 20:46:08 GMT
Think they're about the same height and width but I'm not sure how deep the Vauxhall one is, being only for a 1.5 You'd probably do better performance-wise with the Sierra one, case of what fits where
--Phil
steve
Likes 'em old!!
May 13, 2010 22:55:34 GMT
Love this project mate, hats off to you, and the fiat and daewoo sleepers are just Look forward to seeing it at some shows when its done.
Currently driving - 1969 Viva Deluxe
May 13, 2010 23:26:05 GMT
Glad I'm not the only one not getting much done.......
carmad
May 14, 2010 20:14:15 GMT
Glad I'm not the only one not getting much done....... Bet ya were just busting to post that after the greef I gave ya for swaping wheels
carmad
stand alone ecu ordered
Prop shaft measured
Rubber engine mounts bought
New turbo and manifold on it's way
LSD ordered
mojo restored
Good stuff, hard to beat a box full of mojo. I'm really looking forward to seeing this done man
carmad
Oct 30, 2010 19:08:14 GMT
who was it on here that was doing polybushes for any car ? the time has come to order them
Last Edit: Oct 30, 2010 19:08:59 GMT by carmad
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
Oct 30, 2010 19:18:49 GMT
Coggers. He's your man
carmad
Oct 30, 2010 20:31:39 GMT
thats the boy
coggers could you pm me if your still at it ?
Oct 30, 2010 21:00:47 GMT
He's not on here much any more dude I'll give him a shout for you
Serious Thread . . . I've just read the whole lot! Some good original work going on there, I wish I had a shed like that! I'm over the water next week and picking up a load of bits for my Chevanne while I'm there, I might have to give you a shout next time I'm over and come and look at this beastie! Bizarrely I was talking to a guy yesterday that has a load of brand new old stock genuine viva parts, inc new wings etc, so if you get stuck for anything give me a shout as he may have it. Good luck with it
I think it was coggers, via the Viva forum, that pointed me in the direction of my superflex polybushes. Think the droopsnoot group get a 15% discount if you sign up to their forum. Should be a relevent thread for purchases.
Or, as I did, Motorsport World also have a discount if you buy from then. In the end the full car, excluding AR bar, came to just under £400. Although I accidentally got the full set of polybushes for the shocks even though I had brand new shocks to put on anyway, so could've got it lower
Project Diary1975 Viva / 1988 T25 Camper / 1989 Mini / 1991 MX5 / 1992 Mini / 1994 Saab 9000 / 1997 Saab 9000 / 2008 Saab 9-5
carmad
Oct 31, 2010 15:52:22 GMT
Serious Thread . . . I've just read the whole lot! Some good original work going on there, I wish I had a shed like that! I'm over the water next week and picking up a load of bits for my Chevanne while I'm there, I might have to give you a shout next time I'm over and come and look at this beastie! Bizarrely I was talking to a guy yesterday that has a load of brand new old stock genuine viva parts, inc new wings etc, so if you get stuck for anything give me a shout as he may have it. Good luck with it your more than welcome were are you staying ?? but i must warn you the shed i share is like a time warp once you go in you come out its dark lol
Oct 31, 2010 17:48:14 GMT
hi mate what are you doing about the miss match with the clutch and thrust bearing gap? did you check out the frontera turbo inter cooler by the way it fit's in nicely ot sure i have a pic of it on my thread ill take a few and some measurements if you like mike
carmad
Oct 31, 2010 18:11:33 GMT
the clutch / thrust bearing on this car are hydrolic omega items and standard vxr 6 bolt flywheel
Last Edit: Oct 31, 2010 18:12:00 GMT by carmad
Oct 31, 2010 19:27:26 GMT
i need bushes for mine. I wonder if superpro make them- they are cheaper than superflex and available in the UK for you fellas.
You could share some of your Mojo with leigh!
ah then your useing the vxr "pot" type flywheel then? thought i read something about calton clutch on here somewhere
carmad
same friction plate 18 spline
only omega ones 3 mm bigger in diameter
when i started this thread i was going to use a 8 valve block with a red top head
now i am using an eco wrec with a turbo
the only real difference is omega is hydrolic carlton is cable
and the ratios
i think the 2.5 v6 omega one will take more abuse than a 1.8 carlton one
as for the flywheel yes for the time being it will be a std vxr one
yer thats where i came unstuck as i used the calton flywheel as well and its a little on the short side
carmad
yer thats where I came unstuck as I used the calton flywheel as well and its a little on the short side are calton fly wheels not 6 stud and your using a red top turbo ?
