Does your motor have siamesed inlet ports like an A-series? Thats the only real impediment I think to combining bike carbs and A-series motors. Thats what I'm trying to find out!!! ,.. sadly information isn't as readily available (in English) for these engines as it is for BL A-series!!
well, you can easily tell by looking at the area where the inlet manifold joins the cylinder head, (no dismantling required! ) if there are 4 separate inlet tracts then they're not siamesed (you're laughing), if there are 3 they are siamesed like an A (very awkward!) if there are two that means they are siamesed into 2 sets of two (manageable!) But looking at that picture with the 4 bike carbs, if your cylinder head is like his, each cyl has its own port so no problem.
Last Edit: Jul 8, 2005 21:12:28 GMT by Mr_Bo11ox
...Take the head off...?
Then the block...
Then accidently misplace them...And 'find' the lump and transmission from a Sunny/Pulsar GTi-R....
*n
well, you can easily tell by looking at the area where the inlet manifold joins the cylinder head, if there are 4 separate inlet tracts then they're not siamesed (you're laughing), if there are 3 they are siamesed like an A (very awkward!) if there are two that means they are siamesed into 2 sets of two (manageable!) I'll have a look tomorrow ,.. Although this page may answer the question : datsun1200.com/modules/nsections/index.php?op=viewarticle&artid=46I'm probably better off with throttle bodies and an emerald ECU (Even though I don't think computers should be in cars!! ) ,...
all the heads on that page are 'un-siamesed' so if yours are like those, lashing on 4 bike carbs should be (relatively) straightforward! Go for it! Get a megajolt EDIS-based ignition system on there too, it'll be ace! you say this engine is A-series based, well it looks a damn sight better than an A to me.
all the heads on that page are 'un-siamesed' so if yours are like those, lashing on 4 bike carbs should be (relatively) straightforward! Go for it! Get a megajolt EDIS-based ignition system on there too, it'll be ace! you say this engine is A-series based, well it looks a damn sight better than an A to me. Damn I've got a lot to learn about cylinder heads! ,.. I kind of paint in broad brushes, phat carbs, lumpy cam, good exhaust, higher compression ratio... jobs a goodun. I can see for this project I'm gonna need to actually KNOW some stuff! I was going to go distributorless ignition,.. but I've got to read up on that... in fact I've got to read up on a lot. In fact I don't know the first thing about injection in car engines, fuel/air mixture and jetting in weber/dell'orto I'm good with, but injection.... not the first clue. So do you run injection into carbs, using the ECU to control the rate of fuel, instead of jetting? Or do you run it direct into the combustion chamber and just use throttle bodies to control the rate of air going into the mixture?? Can I run Bike carbs with a mappable injection system?? Will I need expensive bit of ECU kit like the Emerald box for doing mappable injection? Dear god I have a lot to learn,.. maybe I should just stick with DCOE Webers I know where I am with them!
I'm just starting to look into injection systems as well. try looking at the megasquirt page www.megasquirt.info/ it is pretty good. There is also a mega jolt page picasso.org/mjlj/. Its a long way off me actually fitting stuff to anything but I'm trying to get my head around it all. I'm much more used to single cylinder two strokes with big carbs and no ignition advance at all!!!!
OK, Basic Hardware required: Engine Inlet manifold..... will need modifying to run bike carbs and throttle bodies. Throttle bodies(TB): these replace carbs, and have a set of Butterflies like carbs, and angled holes in the sides, into which the injectors fit. Along the top of the injectors runs a Fuel rail, which has a pressure regulator/damper and a feed and return line that needs to go back to the tank. This is fed at higher pressure than if using carbs. Injectors also have electrical connectors for wiring harness. (think of them as a solenoid valve, high pressure fuel, switched open or closed Via the ECU, sprays into the airflow with better atomisation than carbs) TB`s have a means of adjusting airflow through each butterfly and also a Throttle Postion Sensor TPS on the end of the butterfly shaft. probably also have vacuum take offs too. Because of the better atomisation, you can run slightly smaller dia too with TB`s ECU can run injection and ignition timing or just one or the other. With a fully mappaple system you can control exactly how much fuel, when it is supplied, and over what period relative to Crankshaft position For every 100 RPMs if you really want to ;D And also the ignition advance/retard at each of those points too.... It is even better with lairy Cams that wont usually idle, or carbs that fuel ok at the top end but Bog down off idle or foul the plugs etc. You also have full control of Warm up (Choke) in all weathers, and the possibility of controlling fuelling for boost etc.... different ignition maps to aid traction by softening the power delivery...... Yes there is a lot to learn, but it is well worth it, and to get started is relatively easy. Crank Trigger wheel Bike Throttle bodies with injectors TPS Etc Water Temp sensor Injection fuel pump Return line to tank Emerald or Megasquirt ECU Ability to make a decent wiring loom ;D If you want some Throttle bodies, I have some complete with fuel rail and TPS that would be Ideal on a 1400 the Emerald site is really good reading for research HTH Dom
Not wanting to hijack the thread but....... I've been considering fuel injection for the 1303. One of the problems with beetle induction is the length of the inlet tract (fuel dropping out) or so I have been told. When switching to injection would it work with one throttle body in place of the carb and injectors at the cylinder head end of the manifold or would it need to have throttle bodies at each side (as in twin carbs)? Does the porsche 914 have injection? Not clued up on them but a similar set up should work on a beetle shouldn't it?
If you want some Throttle bodies, I have some complete with fuel rail and TPS that would be Ideal on a 1400 the Emerald site is really good reading for research Thanks for the info,.. will have to read some more!,.. PM me details about the Throttle bodies,.. price etc. etc.
One of the problems with beetle induction is the length of the inlet tract (fuel dropping out) or so I have been told. When switching to injection would it work with one throttle body in place of the carb and injectors at the cylinder head end of the manifold? No reason why that wouldnt work, your 'fuel drop out' problem will not materialise if the injectors are sited near the head.
