carmad
Jun 27, 2008 16:00:38 GMT
has any one any pics of droop snoots magnums firenzas and vivas looking for some insparation for my new project weither to go full race replica or plain jane
Jun 27, 2008 16:16:38 GMT
Last Edit: Jun 27, 2008 16:18:12 GMT by leigh
carmad
Jun 27, 2008 18:20:50 GMT
love that last pic
harris66
drive it, break it, fix it and make it quicker!
Jun 27, 2008 18:27:37 GMT
my old wide arch, posted else where but again wont hurt ;D
1.2 corsa daily, 1.8t a4 avante, 6.3ltr austin a40....
carmad
Jun 27, 2008 18:59:11 GMT
my old wide arch, posted else where but again wont hurt ;D any one know where to get that kit?
harris66
Jun 27, 2008 19:06:55 GMT
not sure now, my panels were bought out of the vauxhall sportparts cat in the early 80s! i beleive the droop snoot group holds the moulds now for these and possibly makes them up to order, but not 100%
carmad
Jun 27, 2008 19:12:12 GMT
well i was gonna go steel wide arches but would like the dimensions to copy off
harris66
Jun 27, 2008 19:16:32 GMT
hmmm, there is another guy on here whome i think has fitted that kit to his hc estate, not sure who though, if some 1 else knows him could be of help maybe
Jun 27, 2008 19:20:11 GMT
I believe my mate can do most of that kit ..Last time I spoke to him he had the moulds for the front spoiler/wings but was waiting on the rear wings.. Next time I speak to him i'll see what the crack is
Jun 27, 2008 19:31:01 GMT
Last Edit: Jun 27, 2008 19:35:48 GMT by leigh
Jun 27, 2008 19:44:23 GMT
Jun 27, 2008 19:57:47 GMT
I am slightly confused by Viva coupés/Magnums/Firenzas. What's the difference?
Jun 27, 2008 20:11:19 GMT
I am slightly confused by Viva coupés/Magnums/Firenzas. What's the difference? That'll make two of us who are confused then.. ;D I'm led to believe that they all share the same 'HC' floorpan. The Viva coupe and Firenza( not snoot) are basically the same shell give or take the square/round headlight thing.. The Magnum I believe was basically a 4 door Viva shell but only came with the OHC engines.. whereas you could get a 1256cc Firenza I think. I'm sure somebody with hairy palms will be along shortly to tell us the real differences
Jun 27, 2008 21:24:41 GMT
Viva HC came in either a 2-door or 4-door saloon or 2-door estate & was initially avilable with the 1159cc ohv, or the 1600 or 2000cc ohc slant 4. After a year or so the engines were enlarged to 1256 ohv, and 1759 or 2259 ohc slant 4.
Firenza was the 2-door coupe version, with the same engine options (i think).
The Magnum was a later model, essentially re-badged Viva which had the larger 1759/2259 slant 4 engines only. When the Magnum was available i'm sure you could only get the Viva with the 1256 engine. Magnum also had a better spec interior, twin headlamps & Rostyle wheels (similar to the later Viva GLS). I'm not sure if the Magnum was available in the coupe bodyshell or not. It came as either a 2-door or a 4-door saloon for definate.
I'm fairly sure that the later base spec Viva E was also available in the coupe bodyshell with 1256cc engines only.
There was also the Viva Sports Hatch, which was a 2300cc Viva Estate with the droop snoot front on it. Then there was the Firenza droop snoot, also with the 2300cc engine and ZF 5-speed gearbox iirc. Both of these models were pretty rare.
So essentially the Magnum was the larger engined luxury Viva, which was only introduced a few years after production started. Kind of like same as the differences between the Mk1 Carlton & Viceroy, or the later Mk3 Carlton and Senator.
Jun 27, 2008 21:42:45 GMT
Well done Sooty lad , I knew somebody would know ;D
firenza pic request arthurbrown
@GUEST
Jun 27, 2008 22:49:53 GMT
Viva "E" coupes were done to use up unused firenza bodyshells.
They used to be 2 a penny round here when I was a lad. Where I lived, probably 75% of the local populace worked for or had connections to the plant at Luton (about 7 miles away), and they were available to employees at very very cheap rates.
I think you'll find the main difference is -
Opelscott has a Viva
Coggers has a Firenza
I have a Magnum ;D
Muuuuhahahahahahah
v8ade
V8 on open headers at full throttle "Heaven"
Jaguar xf SportBrake rover 820 Turbo vitesse
