Siert
Oct 26, 2010 13:47:20 GMT
My 309 just passed its inspection today (and then the clutch cable broke while I was on my way from the inspection center to the winter storage place ). I'd be interested to see what the "unsatisfactionary modification" to your rear boot floor is On mine the vertical plates that are part of the body around where the rear axle sits are somewhat crusty.
stevek
Yorkshire and The Humber
Oct 26, 2010 16:45:35 GMT
Hi Siert, good on passing inspection. At least a clutch cable shouldn't be too bad, though annoying timing for it to happen. I had to be towed home in my Porsche by my housemates Radiant red Pink fiesta when the clutch cable went on that, how embarrassing. Have started to strip the interior out of the Pug to see the extent of the rust. This is the "unsatisfactory modification" ie rusty holes. Think he picked the wrong description. Which when properly attacked have become... Thats worse than expected, will continue investigation tomorrow to see how bad the rust around all 4 jacking points is (worse on rear jacking points). I would have got further with that today but I took the Porsche up for MOT too this afternoon. It failed too, bummer. -Steve-
Last Edit: Oct 26, 2010 16:46:16 GMT by stevek
stevek
Oct 29, 2010 21:38:44 GMT
So I've only just stumbled across this thread after reading your Porsche one! .... Has there been any updates on the 309... Do you still own them? Good work on the welding btw!
stevek
rlloyd91 - Woah epic thread revival! I still have both pugs, you may catch the odd glimps of them in my 924 thread, but there has been no progress on them. I pushed them from my mind and have simply ignored them I'm sorry to say. They are looking very sorry for them selves. There is a chance that I'll pick up with the welding and recommission the blue one next year. I'm getting more confident at welding which does make it a little less daunting to repair, but it would require a lot of work. Needless to say I will revive the thread if there is any notable progress. -Steve-
Hi, I’ve just found this thread. I used to own the blue pug and, I’m sorry to say, was responsible for the shocking spray painting! Would love to know the current status. Cheers; Howard
stevek
Feb 18, 2024 21:55:21 GMT
I’m at a point where one way or another this car has got to move, either for scrap or to my current house. Friends and family say scrap it and they’re probably right, but I’m reluctant. This video is from last April when it was mearly 16 years since it’s MOT ran out and 13 years since it last started. Just a charged battery and some fresh fuel in a pop bottle for it to suck on… oh and no exhaust fitted… I was quite impressed, the throttle was stuck at the carb but I later got that freed up ok too. As encouraging as that may seem it’s still a long way from being a car, lots of rust, and a whole bunch of other things. I’m not sure it’s saveable. Are these things retro yet? 😝 -Steve-
Last Edit: Feb 18, 2024 21:58:02 GMT by stevek
stevek
Feb 18, 2024 22:51:58 GMT
I’ve been poking around it a bit this last week too, if I can get it mobile enough to drive onto a trailer, and more critically up my quite steep driveway at this end, I may move it home. I can’t afford to spend much time or money on this right now but come summer I should be a bit more comfortable once I have sold the house where it’s currently sat.
It has been laid up with the back end up on stands, the fuel tank off and the rear drums off since the 2010 MOT fail!
I’ve jury rigged up a temp fuel tank, just a standard 5ltr petrol can with some hose fittings attached, which I have sat on the battery tray. I’ll run some jump leads to a battery in the passenger foot well. I have replaced the massively leaking fuel lines and have also got the front end up on stands today, this is so I can try putting it in gear and have a look at the stuck front brakes. I’ll chuck the exhaust back on it and have another go at starting it up later this week I think.
-Steve-
Last Edit: Feb 18, 2024 22:52:21 GMT by stevek
stevek
Feb 20, 2024 21:10:01 GMT
Ok so got a little further… First up I degreased and pressure washed the engine bay and wheel arches just so it’s wasn’t as grim to work on, it was full of oily dirt, cobwebs and rust, not nice. The exhaust is back on, it was only two bolts to the down pipe and two mounting rubber to push on so easy peasy. After a clean of the distributor cap it is now starting and idling nicely, and it runs up to temperature ok. The rad fan needed a bit of contact jiggling before it played ball but is fine now. The engine sounds as good as one of these rattly Simca units ever does. The alternator belt was loose and squealing so I put some tension on that which has sorted that, for now at least. The belt actually looks ok given it’s age. In fact I’ve jiggled/cleaned various contacts to wake things up. The lights were horribly dim but there is now a full compliment of adequately bright lights after swapping out a few dead bulbs. I know this was off task but it was easy and pleased me so yeah whatever. I have also had the front wheels off and loosened the callipers to get the discs out, they have been given a clean up with the grinder knot wheel before reassembling. While in there I was also able to push the calliper piston back in a little so at least they aren’t seized. If it wasn’t for the vast amount of welding it needs I think it would re-MOT fairly easily. For an MOT test it would need a couple of track control arm bushes, a track rod end and a set of tyres. But for my goal to simply make it mobile I think it’s just the rear brakes to reassemble. -Steve-
Last Edit: Feb 20, 2024 21:49:02 GMT by stevek
stevek
Feb 29, 2024 20:57:44 GMT
Done a little bit more… Jet washed the greenery off them both. It didn’t make much improvement, the paint is rubbish anyway. Removed and cleaned up the front discs on the gold one. One set of pads on the gold one have disintegrated from the backing plate and both rear shoes on the blue one have done the same. So £5 pads and £7.50 shoes acquired… Only fitted one pair of pads so far. Put the rear seats back in and rear bumper back on the blue one but can’t find the bumper bolts. I could do with a front exhaust section for the gold one so it sounds normal for moving it but at £40 for the cheapest it’s not worth it. I also need to find a way of moving them 4miles / 20min across Leeds. Hiring a trailer might be the way if it can rope my mate in for a tow vehicle. I should just scrap them really but I don’t feel like I’m done with them yet. -Steve-
Last Edit: Feb 29, 2024 21:36:07 GMT by stevek
stevek
Ran into a little unexpected puzzle. The hand break parts need swapping onto the new shoes. The pivots held in with spring clip washers were easy enough but the toothed automatic hand break adjuster looks tricky. It feels like hammering it out is more inclined to form more of a rivet head than driving it out. Any suggestions? Or just hit it harder? -Steve-
Last Edit: Mar 1, 2024 17:15:44 GMT by stevek
Ratchet
The user formerly known as Thomas
Ran into a little unexpected puzzle. The hand break parts need swapping onto the new shoes. The pivots held in with spring clip washers were easy enough but the toothed automatic hand break adjuster looks tricky. It feels like hammering it out is more inclined to form more of a rivet head than driving it out. Any suggestions? Or just hit it harder? -Steve- odd that they don't supply new rivets.. if i didnt have access to new ones or the means to make one what i would do is carefully file or grind round the outside of the head, to reduce the diameter, then hammer it through, alternativly cut the old shoe to release the pin then either reshape with a hammer, or file/grind the mushroomed end of the pin until it can fit through the hole in the new shoe, then peen over the rivet again
Last Edit: Mar 1, 2024 19:48:13 GMT by Ratchet
Competition is the law of the jungle, but cooperation is the law of civilization.
1971 vw beetle 1200 1978 international loadstar 1700 4x4 1987 landrover 110 1994 Yamaha FZR600r 2010 honda CBF100GT
