May 29, 2018 11:27:32 GMT
Ooooohhhhh- tell us more about those driveshafts? re they datsun based? If you don't have the rubber doughnut couplings how are you taking up the shock loads - have you changed over to a sprung centre clutch disc? I like them top hats too!!! Great car- I have seeing classic cars evolve constantly on this forum
MR TIKI
TIKI,style from a different angle!
May 29, 2018 12:20:02 GMT
Ooooohhhhh- tell us more about those driveshafts? re they datsun based? If you don't have the rubber doughnut couplings how are you taking up the shock loads - have you changed over to a sprung centre clutch disc? I like them top hats too!!! Great car- I have seeing classic cars evolve constantly on this forum The shafts have biult in dampers with springs to assist and support,they were made and extensively tested by a friend.I believe they are Marina based with custom components machined to fit. Sprung centre clutch is on the to do list along with Spax or protechs to complete the new set up.
Last Edit: May 29, 2018 12:43:52 GMT by MR TIKI
Boldly driving faster than a tin worm can wiggle.
MR TIKI
May 29, 2018 19:27:50 GMT
Top Hats.... Before After these are machined from one solid piece to fit over the damper and inside the spring with only the necessary room for fit and function.
May 29, 2018 20:58:13 GMT
Cool. So you say the driveshafts have a built in damper? How so? I can see the spring to help keep them extended, I guess to stop the inner axle from falling out of the diff head. But is there some sort of torsional damper built into the splined section?
Those top hats are so simple and clean. I presume the damper shaft length is the same so do you use check straps to stop the springs from dislodging at the top when the wheel drops over a light 'jump' sort of thing or when the car is jacked up?
MR TIKI
Cool. So you say the driveshafts have a built in damper? How so? I can see the spring to help keep them extended, I guess to stop the inner axle from falling out of the diff head. But is there some sort of torsional damper built into the splined section? Those top hats are so simple and clean. I presume the damper shaft length is the same so do you use check straps to stop the springs from dislodging at the top when the wheel drops over a light 'jump' sort of thing or when the car is jacked up? My understanding is that they are splined with an interal spring,the external spring as you say helps to keep everything in place.with twin ujs it helps to counter the torque into the trans axle,a sprung plate clutch ie; Morris 1000 will help relieve additional preasure on the gearbox.so far they are proving to do a brilliant job with no vibrations,if anything they appear much smoother than running donuts. The Top Hats are brilliantly simple,you presume correctly the dampers are unchanged.for piece of mind straps will be fitted although it would appear they are not vital,under load and enthusiastic cornering they haven't presented any issues yet,its not like anything can travel far. A new clutch plate is on it's way and will be modified to do the job,over the next few weeks I intend to set the car up and then just enjoy it through the summer.
Last Edit: May 30, 2018 7:14:06 GMT by MR TIKI
MR TIKI
It's a big day tomorrow,the plan is to take the engine out for the first time since the rebuild some 3 years ago,replace the standard clutch with a reworked sprung plate for a Morris 1000,fix the thermostat housing coolant leak,fit some check straps and have it back on the road by late lunch.... ๐No pressure,Game-on!!
Without having to trawl back through 14 pages.. what does the brass door chime button do? I like the quote.
MR TIKI
Without having to trawl back through 14 pages.. what does the brass door chime button do? I like the quote. ๐Ah yes,That's a new addition and a bit of interactive fun for the little and big kids to play with,it triggers the Klaxon horn you can see to right of the engine bay.
MR TIKI
It's a big day tomorrow,the plan is to take the engine out for the first time since the rebuild some 3 years ago,replace the standard clutch with a reworked sprung plate for a Morris 1000,fix the thermostat housing coolant leak,fit some check straps and have it back on the road by late lunch.... ๐No pressure,Game-on!! After a 10 o'clock start and a break for lunch it was back on the road 4pm....... With help from a good friend we divided up the jobs and got stuck in We had a couple of captive nuts break away which slowed us down some what and then we got to the release bearing that had totally released itself from it's housing! Luckily I was in the right place and in the best company to have a new one fabricated while I cracked on with the rest of the jobs,ie;the leak,clean up and pipework. Everything then went together with relative ease,our celebration was only momentarily hindered by a high pitched grinding noise on start up which was totally my own fault because I left the stone guard in place and folded it under the fly wheel!! (see picture above) It didn't take long to sort out and with seamless gear changes and no high pitch grinding it was back on the road in time for an early dinner rather than a late lunch,it turned out to be a great day in fantastic company and we ended up doing a lot more than we set out to do,so Win-win. We were both able to make it to the Walton on Bridge breakfast club on Sunday too,which had a great turnout too and one of the best ever I think. The check straps can wait for another day.....
Last Edit: Jun 5, 2018 21:18:00 GMT by MR TIKI
MR TIKI
Out and about with the Heathrow chapter of the Imp club,if you like your big engineering then the Kempton steam pump museum is a must. It was also a great opportunity to try out my new seats.๐
This car has to be like a favourite child or pet, you just keep getting pleasure from it.
And every time you take it out, it makes people smile.
Good job on getting it sorted, out and used.
MR TIKI
Jun 26, 2018 22:47:23 GMT
This car has to be like a favourite child or pet, you just keep getting pleasure from it. ๐Hadn't thought about it like that before,but after 19 years and more transitions than I care to count it is like one of the family.๐ฟ
MR TIKI
Jul 12, 2018 20:49:33 GMT
๐this has just come to my attention on 'the book of face'. It's the second time the Tiki-mobile appeared in Custom Car magazine,once back in May 2005 I think it was and now in August 2018. Thanks for the compliment CC!
MR TIKI
Jul 22, 2018 16:11:51 GMT
๐when your new clutch resembles a propulsion unit from something out of Star Wars.......
Last Edit: Jul 22, 2018 16:12:46 GMT by MR TIKI
MR TIKI
Sept 30, 2018 20:57:48 GMT
๐Baked beans and pop rivets..... The old Cherry Bomb has been showing it's age recently,the honeycomb core has broken up and holes have started to appear along the barrel. It has put in a good performance having been dinked and knocked off on numerous occasions,to be honest it owes me nothing because that is pretty much what it cost second hand,but I thought it deserved a patch while I look for a replacement.๐ I have to say,It's rather loud and I fear it will be setting off car alarms if I venture into indoor car parks......
Last Edit: Oct 1, 2018 5:58:40 GMT by MR TIKI
MR TIKI
Last Edit: Jan 27, 2019 10:38:07 GMT by MR TIKI
MR TIKI
Feb 25, 2019 18:13:55 GMT
Woody in the hot seat at WBBC
Last Edit: Feb 25, 2019 18:15:43 GMT by MR TIKI
faiz
Feb 25, 2019 19:36:22 GMT
This is so cool! Really like these but I've never actually seen one in real life.
bazzateer
Imping along sans Vogue
Woody in the hot seat at WBBC Is that the one that tried to eat me at yours a few years back?
MR TIKI
Woody in the hot seat at WBBC Is that the one that tried to eat me at yours a few years back? Hello Sir,did the leg ever grow back?๐คฃ No,the old fella is long gone,This is Woody,we've put him in the space Maverick used to take up.this one is even more of a custard head than Mav was.life just isn't right without an EBT.๐
