bstardchild
Club RR Member Number: 71
Feb 16, 2023 20:33:35 GMT
Great unit - those things are really hard to find at a good price
You made the right decision to do it yourself - finding people to do work at a good std is quite hard these days - especially paint and bodywork
Really enjoying a good old fashioned forum build thread - good luck with it
namless
Club RR Member Number: 26
Feb 16, 2023 20:49:00 GMT
Great build thread! Bookmarked
teaboy
Make tea, not war.
Feb 16, 2023 21:43:08 GMT
Nice shed and nice work on the car.
Feb 16, 2023 21:43:18 GMT
Great work!
mouse
Feb 16, 2023 21:57:04 GMT
This thread sums up what Retro Rides is for me, people in sheds doing things for themselves. Really looking forward to all the pictures.
Feb 16, 2023 23:06:55 GMT
Thanks for the replies motivates me to do more. So moving forward after the smooth bay. You probably noticed I smoothed over all of the holes for the brake and clutch servo. I sourced an early Lada 2101 master cylinder as they do not use a servo and after many hours using google chrome on translate and drive2.ru (russias car bible) I got in contact with a company called garage1970 or whatever the Russian translation is as they where halfway through building a reverse servo kit so that the servos could be reverse mounted into the car and not in the engine bay. After a lot of Google translates it was finally paid for and a month or so later the kit arrived. The kit wasn't very complete so I had to do a few modifications. For starters the bracket to mount it onto the bulkhead was missing. But I made my own in the end as they didn't want to send the part unless I buy something else. Okay fair enough. Secondly they used a threaded rod for some reason to connect from the pedal to the master cylinder so you could hear the threads as they rubbed against the seals. Not ideal so I smoothed the threads so that it no longer grinded against the dust seals. And then the pedals had no stoppers for there rest position so the pedals would just jump around freely so I made a stopper for the clutch pedal after realising the brake light switch acted as one for the brake pedal. Once this was solved it was time to move onto the steering. Funnily enough having my second lada I have actually never driven one yet so I can't vouch for it but I know everyone complained about how the bad the steering was so I replaced the steering box with a Toyota yaris mk2 rack. I bought the kit from speedfreakworkshop in Russia. It came with everything needed to fit but to save money I ordered it without the steering rack planning to buy one in the future. Which turned out difficult because I needed a LHD rack which I ended up sourcing from Lithuania. For some reason I am unable to upload pictures now. Maybe poor signal but I will edit this post later when I get some signal.
Last Edit: Feb 17, 2023 15:25:22 GMT by thommass
dazee
Feb 17, 2023 11:33:03 GMT
Good progress keep at it, I like your 'can do' approach.
Bookmarked!
I'm going to try to find a workshop once I have moved back to Newbury, I'm hoping some of your good fortune bleeds through to me...
As regard to your welding, and your attitude to just get on with it, I was once told "you cannot learn to swim unless you get in the water". Thin steel plate seems to be the hardest thing to learn on, so you're doing a great job!
Feb 21, 2023 20:55:56 GMT
Feb 21, 2023 21:00:57 GMT
Feb 21, 2023 21:05:53 GMT
Last Edit: Feb 21, 2023 21:09:13 GMT by thommass
Feb 21, 2023 21:18:11 GMT
Last Edit: Feb 21, 2023 21:18:56 GMT by thommass
Feb 21, 2023 21:27:50 GMT
Feb 21, 2023 21:36:56 GMT
Last Edit: Feb 21, 2023 21:39:20 GMT by thommass
Feb 21, 2023 21:45:49 GMT
Last Edit: Feb 21, 2023 21:47:12 GMT by thommass
Feb 21, 2023 21:55:10 GMT
Feb 21, 2023 21:57:52 GMT
Last Edit: Feb 21, 2023 22:04:40 GMT by thommass
Feb 21, 2023 22:16:27 GMT
Last Edit: Feb 21, 2023 22:19:00 GMT by thommass
Feb 21, 2023 22:21:36 GMT
Feb 21, 2023 22:25:14 GMT
Last Edit: Feb 21, 2023 22:34:52 GMT by thommass
