Also in the mail yesterday. The replacement ring and pinion gears ordered Friday. Quick delivery. Interesting to see the ring gear is cast ally, and the pinion is nylon/plastic/prayer material. Three days online training and a London training meeting I am running means probably only getting to it over the weekend. It would be very cool if that was the only issue with it. I need to drain the oil in the motor as well and refresh oil and filter if it gets to run. Pretty new parts.
Last Edit: Nov 15, 2022 11:13:41 GMT by grizz
Nov 15, 2022 12:12:09 GMT
If the lights come on then it shows the safety switches are all made. The Countax we have, which is basically identical except it's a 15hp single, has the seat one and one on the footbrake.
The starter solenoid was goosed on ours, but I managed to use a boggo Lucas one I had in the stores after swapping some terminals around. The genuine Countax solenoid was pretty dear.
Nov 15, 2022 12:57:45 GMT
If the lights come on then it shows the safety switches are all made. The Countax we have, which is basically identical except it's a 15hp single, has the seat one and one on the footbrake. The starter solenoid was goosed on ours, but I managed to use a boggo Lucas one I had in the stores after swapping some terminals around. The genuine Countax solenoid was pretty dear. Paul Y will be posting a carburettor out here, battery can be scrounged. Starter did not engage or click when I turned the key. Still hopeful though.
Nov 16, 2022 20:23:39 GMT
Three days at home with. Key Account Management training had me climbing the walls. Only George kept me amused. He's such a dickhead. So today we got a full hours lunch break. And when they closed the Teams meeting down for lunch, my plan was already made. Down to the garage. Pull out the Westwood Spears and Reapers tractor and dismantle the top to get to the flywheel. A multitude of tools needed. Bit of hammering to release the flywheel from the drive shaft. Removed the shaft key, known also sometimes as a Woodruf key. Important not to lose this little guy. Got the flywheel off. The ring gear was riveted in four places. So mr grinder brought into service. Punched out all four. Reassembled after cleaning with the screws and nyloc nuts supplied in the service kit. Reassembly looked decent. At which point it was time to go back to class. I would get back after work, just pulled a canvas over it all as the weather forecast was for a lot more rain. More in a bit for those who like the whole story.
Nov 17, 2022 18:00:40 GMT
So reassembly. In the pinion gear, the carrier needs one of these little spring loaded pins inserted, after some struggling I ground it down very slightly and a hammer completed the job. Result. Cover had me stumped, until I looked at a photo taken earlier. The mesh spins on the inside, it looks so wrong. . And of course the scrap. Good enough reason to struggle or fail to start. So I thought I would chance it straight away. See if it would start. Video: More tomorrow I guess. .
Good work Rian, Stupid question, it doesn't have a fuel cut off does it ?? Get a decent battery on it and you're more than half way there, Nigel
Paul Y
Nov 18, 2022 10:49:14 GMT
On my tractor you need to depress the clutch to make it spring into life.... Good work Sir. P.
Nov 18, 2022 16:40:12 GMT
Good work Rian, Stupid question, it doesn't have a fuel cut off does it ?? Get a decent battery on it and you're more than half way there, Nigel Hi Nigel, Fuel tap yes. 32AH 310A battery ordered this afternoon.
Nov 18, 2022 16:40:54 GMT
Nov 18, 2022 16:42:12 GMT
On my tractor you need to depress the clutch to make it spring into life.... Good work Sir. P. On this one the seat switch is deactivated, and you still need to depress the foot pedal as well. Hope I am not missing something very obvious.
Nov 18, 2022 17:01:33 GMT
So after changing the starter and ring gears, failing to get it started, I checked the usual suspects. Fuel pours out after the pancake filter Sparkplug cleaned and dry. Airfilter horrendously dirty, cleaned and removed. At lunchtime I drove the 6 miles to my nearest Toolstation for some βEasystartβ came back and tried it before the next online session started. Put out a fire. Laughed and tried again. So I pulled the cup off the bottom of the carburettor to find it pretty bad. Wire brush and wipe out later, removing 28 years worth of crud and rust. Reassembled, twice. BECAUSE. Then tried starting it again because that is what I do. Failed again, possibly no fuel getting through. No further fires. But also a dry plug. So I decided to walk away as it was getting dark, despite the lights in the carport. Once back in the house a quick search showed that complete carburettors can be had for Β£11.99 delivered. Seriously, even if I were working for minimum wage, my time and frustration, spent on a possible rebuild, just is not worth the effort. So after speaking to a human I ordered a replacement part. Tonight, on the way home I stopped at my local motorfactors to see if they had a battery to replace the very tired on that came with the tractor, in fact, they had twoβ¦β¦ priced at Β£70.00 So I smiled and walked outside, ordered one online for less. Battery is less than 24 hour delivery. Unfortunately the spares shop is one down from the Fish and Chip shop. The smell of freshly fried chips and vinegar permeates the air late afternoonβ¦β¦ So I promptly spent Β£2.40 of the savings made on the battery on a bag of chips to eat on the way home. Friday night. Waiting for the courier to get here with the V-Twin carburettor that Paul Y sent over yesterday. Maybe start to play with it tomorrow. I know the FRANKENTRACTOR is missing a few bits. Lets see what we can get done though. Later.
Last Edit: Nov 18, 2022 17:04:53 GMT by grizz
Nov 18, 2022 19:59:56 GMT
good call on the chips
Nov 18, 2022 20:23:24 GMT
good call on the chips Of course it is. Alwys π
Nov 20, 2022 22:22:52 GMT
I had a similarly gunked up carb on mine. I did get it running after a clean out, but itβs not exactly easy to get going. Looking at the price of replacements I think Iβll just get a new one. I need a battery too, as I donβt have anything thatβs the right kind of size to fit in the available space.
jimi
But also a dry plug. We obviously have different definitions of a dry plug π
Frankenhealey
Club RR Member Number: 15
Nov 21, 2022 12:14:17 GMT
I need a battery too, as I donβt have anything thatβs the right kind of size to fit in the available space. Of course you do! Remove the bonnet and use the pat. pending Acme Oversize Battery Fitting System**. Another benefit is that it looks reet country ** Two bits of wood and a bungee strap
Nov 21, 2022 13:21:39 GMT
Itβs genius tips like this βοΈthat keep me coming back here. π€£π
Nov 21, 2022 14:38:25 GMT
I had a similarly gunked up carb on mine. I did get it running after a clean out, but itβs not exactly easy to get going. Looking at the price of replacements I think Iβll just get a new one. I need a battery too, as I donβt have anything thatβs the right kind of size to fit in the available space. At Β£12.00 deliveredβ¦. A complete carb for the Hopemobile was cheap.
Nov 21, 2022 15:22:23 GMT
But also a dry plug. We obviously have different definitions of a dry plug π LOL ! You saw right through me. Yes, it was wet, and there is spark, but they were not working in unison to give a running motor. The last flooded plug I saw was fuel flowing out the plug hole on a Bohlens mower craigrk had bought that got locked.
