Aug 22, 2022 21:54:50 GMT
Good choice on the welder Looking at the above welds (I know you have improved now) you need more power, the welds are sitting on top. Up the power by a full number but leave the wire speed as recommended in the guide. Then with the pulse style welds you should get better penetration. A lump of copper is your best friend for thin stuff (a flattened bit of copper pipe will do) press this behind any holes/thin metal and it stops blowing holes in it. Well done for doing it - it's pretty frilly!
Aug 23, 2022 20:21:30 GMT
Good choice on the welder Looking at the above welds (I know you have improved now) you need more power, the welds are sitting on top. Up the power by a full number but leave the wire speed as recommended in the guide. Then with the pulse style welds you should get better penetration. A lump of copper is your best friend for thin stuff (a flattened bit of copper pipe will do) press this behind any holes/thin metal and it stops blowing holes in it. Well done for doing it - it's pretty frilly! At first I just set the welder to the settings in the booklet however what works on a test piece does not always work on a real job, I have also found that having a small gap when butt welding helps as I am effectively melting both edges simultaneously.
Aug 23, 2022 20:40:26 GMT
I find the book settings pretty perfect for good clean steel, as you say - you have to tweak it a bit for less good metal.
I would say be brave when fixing rust - don't try to 'just' trim it past the rust - chop it right back to good solid metal - easier to fix/weld and will last better in the long run.
Yes you normally need the thickness of metal as a gap as a general guide.
1959 Standard Ten Companionglenanderson
@glenanderson
Club Retro Rides Member 64
Aug 24, 2022 10:49:04 GMT
Ok, sorry I’m a bit late, but I’m in now. Bookmarked. 😃👍
Aug 24, 2022 11:52:28 GMT
If the whole car has a degree of surface rust (which is usually impossible to completely remove without blasting) I find it can help to have a mm or two of overlap then use a slightly higher current to burn through the old metal onto the new underneath.
Sept 13, 2022 19:59:06 GMT
Sept 13, 2022 20:15:26 GMT
Sept 13, 2022 20:29:06 GMT
Further evidence of the shunt, the inner flange of the original outer wing had been forced back leaving a scar in the scuttle just outboard of the hinge attachment hole, some of the spot welds on the bonnet front reinforcing had also broken.
Sept 15, 2022 20:43:55 GMT
Another picture of the scar.
Sept 16, 2022 7:18:50 GMT
At least it gives you a mark to line the wing up to 😁
Sept 26, 2022 20:00:29 GMT
Rain water leaking past the screen rubbers had collected in the corners and rotted through.
Sept 26, 2022 20:06:43 GMT
Oct 14, 2022 18:51:42 GMT
Oct 16, 2022 19:04:27 GMT
Oct 24, 2022 19:23:25 GMT
teaboy
Make tea, not war.
Oct 24, 2022 20:24:52 GMT
Top stuff, Daddy.
Oct 24, 2022 22:57:21 GMT
Lead loading in this day and age? I had thought that to be a lost art.
thomfr
Just discovered, bookmarked! Great work! Thom
73' Alfa Giulia Super 64' Volvo Duett 65' Volvo Duett 67' Volvo Amazon 123GT 09' Ford Focus 1.8 06' Citroen C4 Exclusive
Oct 31, 2022 18:48:23 GMT
Lead loading in this day and age? I had thought that to be a lost art. Just a little bit of lead in damp areas, I shall be using filler for profiling.
Oct 31, 2022 19:04:02 GMT
